Question about Caroma Home
Simply tell me how to remove flush button mechanism on 1984 duel flush caroma cistern ?
  • 34 Answers
SOURCE: Slow Flushing mechanism
Check the angle stop at the wall ( valve) if it more then a few years old the rubber inside sticks try turning it off and on a few times. Well first just make sure its open all the way to start. If both of those do not work It might have a screen at the opening of the preeure mechanism...check that the was no line trash caught in it from turning the water on and off. If none of these things work let me know and we can get more technical in find out whats wrong...heck you could have just gotten a bad one. The Plumbing company I worked for when I lived in houston had the contract with them to do there warranty work and boy did we do a lot of it .
Posted on Feb 04, 2009
whytfang
  • 170 Answers
SOURCE: I cant get to the washer to change it
Ok is this a standard toilet where the water reservoir tank is just bolted to the bowl with 2 or 3 bolts and is removed separately or is this an older style where the tank is elevated and connected by a long tube....at any rate...the flush assembly...usually just has the one large plastic or metal nut that retains the flush valve assembly....they get stuck in place afters a few years and just need a little coaxing...and have been APT/Home maintenance industry for 35 years in USA...I have never had a flush valve that needed to be unscrewed but that doesn't mean it isn't possible...so if I were a guessing man which I am generally not (I prefer to know exactly what I am talking about) just like I know that 99 percent of all threaded material in the USA requires them to be removed in a counterclockwise direction...
I hope this helps...if this is a different device altogether...maybe you could send a picture ....good luck....thanks for rating my effort.....the Fang.
Posted on Mar 29, 2009
  • 74 Answers
SOURCE: half flush doesn't stop running
Yes, If I remember correctly you need to replace the flush valves. I cant remember if there is just one or two valves but they need to be replaced. go to your nearest plumbing supply house (a home improvement store will not carry it) and get a new valve. This will fix your problem.
Posted on Apr 27, 2009
  • 129 Answers
SOURCE: i needs new valves for my dual flush, close
No I'm sorry they do not. You might try plumbing supply house in your area.
Posted on Sep 26, 2009
  • 2841 Answers
SOURCE: hi, i have a caroma duel flush toilet possibly 10
First make sure it is not overfilling. The water level must stop before it reaches the overflow pipe. If it continues to run it will overflow into the bowl and continue to run. Adjust the fill level to the mark inside the tank. Make sure nothing is getting under the flapper and holding it open. You replaced the flapper so we know that is not the problem. Just make sure the flapper is centered on the drain hole.
Posted on Jan 09, 2010
Caroma invisi cistern not flushing enough water
check the water level in the cistern
it should be about 3/4 " below the overflow pipe edge
May 25, 2017 | Caroma Home
How to remove button mechanism on 1984 carom a dual flush cistern to replace flush pipe rubber
Info on these old dunnies is hard to find. A lot of Fixya patrons weren't born in 1984. This thread may be of help
http://forums.whirlpool.net.au/archive/1393153
Dec 04, 2016 | Home
Where to buy parts for Fowler toilet cistern .
adjust the float
you are looking for the inlet valve or diaphragm
not as much fowler out here as caroma system parts
ebay
large hardware stores
plumber
Oct 30, 2016 | Home
When toilet is flushed and refills water leaks into the cistern.
Are you saying that water is running into the toilet bowl? If so, check the rubber flapper at the bottom, and the valve (tube standing up).
Mar 29, 2016 | Caroma Home
Cistern leak
The flapper valve(ball)seat is not sealing. Needs a new seat and flapperat bottom of tank. -Ned-
May 26, 2010 | Caroma CARAVELLE270ADAW-EL Caravelle...
How do I get the lid off a stylus toilet cistem
Solution I received " lever up the two flushing buttons with a fine blade screwdriver.
They may be a push fit on two plastic posts. Once off, they reveal a screw between them. Release this to remove the cistern lid. Make a note of the position of the buttons as they only fit one way round."
Feb 07, 2010 | Caroma 270W-RF Reflection Round Front...
Hi, i have a caroma duel flush toilet possibly 10 years old, it is leaking into the bowl and then constantly re filling, i replaced the washer/ring/ thing at the point where the water exits into the bowl...
Jan 09, 2010 | Caroma 270W-RF Reflection Round Front...
Home Logo
95 people viewed this question
Top Caroma Home Experts
john h
Ngoro
Ngoro
Are you a Caroma Home Expert? Answer questions, earn points and help others
