Pc not always booting,
Motherboard was working in old case, relocated into new case, booted up shut down then tried to re-boot nothing. went thru complete instalation again rechecking all (still not booting). next day hit on button system starts ran until I shut it down, check the BIOS while running and set to default. after shut down system would not start, waited another day took MB out of case and tested (started up, shut down and started up again several times, checked MB and CPU for hot spots nothing. back into case started ok, shut down would not start up again. Came in this morning and hit switch started up ok (driving me nuts) the MB is a Foxcon winfast w/939 socket cpu, case and power supply or new.
  • 80 Answers
Blow out dirts on bord, then you pack the board to avoid any bridging with the cassing
Posted on Jul 20, 2009
Motherboard blinks once
hi
try another power supply
then check m.b if not working contact the vendor may be it failed
Dec 19, 2013 | Computers & Internet
How to fix a motherboard that does not turn on at all.
Make sure there is power at the outlet, surge suppressor, power strip. Be sure any connected UPS is on. Try again.
Remove any recently installed hardware and go for boot. If the PC boots, check to make sure that the new hardware does not overload the old power supply - if it does, replace with a higher capacity power supply and go for boot.
Open the PC. Look for indication of power - LEDs, fan, etc. Replace the power cord between the outlet and computer if one is available, and go for boot.
If possible, obtain a power supply tester to determine if the power supply has failed. Replace any failed Power Supply and go for boot.
Disconnect power. Disconnect all non-required cables and accessories. Leave only the power and data cables for power supply, boot drive, video card, mouse, memory and keyboard connected - everything else should be removed (with the exception of the small cables that go to the MoBo headers for LEDs, and switches on the case). Everything means both data and power cables. All controller cards should be removed as well unless using on-board or built-in controllers. Reconnect power and try for Boot.
Add devices, cables, etc one at a time to determine which is causing the fault. A PC that boots and shuts down shortly after could be an indication of overheating / over load. Clean dirt & dust from case, ventilation slots, etc. Make sure all fans spin freely - replace any that do not.
Those are some things to start working on.. hopefully, you'll find the problem and not have to go further. Good luck!
Aug 25, 2010 | Asrock 775VM800 Motherboard
Dell OYF 432 Motherboard won't boot. Starts to boot then trys again.
Try removing each ram stick one at a time,be sure to shut down the pc while removing/replacing memory. If that yields nothing,remove the cpu heatsink,clean it & apply new thermal grease. If that doesn't work, then the motherboard is done.
Mar 15, 2010 | Dell Computers & Internet
Computer wont start(Plz Help me ) Added Much Detail as possiable
start by removing everything, ram, any cards plugged in, drives etc. Then try and boot it. If the issue is still present, shut it down and remove the heatsink and cpu. I have known CPU's to be jolted out of their sockets after an impact. Take the heatsink off, lift the lever and remove the cpu. Check that all the pins are still aligned and straighten any bent pins then refit the cpu and lock the lever down. Refit the heatsink making sure that the heat transfer pad or heatsink paste is still present and lock it down. Plug the power cords and front panel wiring back in and try and boot it. If it boots, shut down and refit each item you removed one at a time, booting in between each item. If the issue arises again, the last item you fitted is the culprit. If you can refit everything and boot the system up, lady luck is with you. If you still cannot get it to boot after refitting the cpu, replace the mainboard. Sorry but without special gear, locating a fault like this on a mainboard is a real pain..
Dec 20, 2009 | Biostar G31-M7 TE Motherboard
Computer crashed. Computer specialist restored drive. now cannot boot windows. Used restore disk. Did not work. computer boots dos screen then shuts down. boots again then shuts down.
Sounds like a Windows issue. Depending on how valuable it is to you to get your data off the drive, I would suggest buying a new hard drive (they are fairly cheap these days), installing Windows on that. Word of advice: Remove your old drive when doing the Windows install, so as not to accidentally select the hard drive your data is on. Once you have Windows installed, shut down your computer, remove the power cord, and install your old drive on a separate IDE channel or SATA connection. If your PC still tries to boot to the old drive, change the boot order in your PC's BIOS.
Aug 10, 2009 | E-Machines eMachines Desktop PC
Sony vaio boot up in normal mode
boot to the repair partition and reinstall windows it sounds like a registry problem reinstalling should fix
Aug 02, 2009 | Acer Aspire One Netbook 8.9" Notebook
HP DV6500 will not boot
Motherboard is definitely bad then, you went thru all the steps that I would have done. Sounds to me like the voltage that is going thru the motherboard isn't being regulated properly cause some chips on the motherboard is bad and when there is to much voltage going thru then the laptop shutting off is a safety mechanism in place to avoid chips burning out on the board. Motherboard would have to be replaced.
Jun 10, 2009 | HP Pavilion DV6500Z Notebook
No boot
if you had received a cd with the card that contains drivers i would replace the old vga card and, assuming it boot s okay, load the CD. after this shut down, swap cards, then reboot.
Feb 07, 2009 | Abit KN8 SLi Motherboard
I have a DFI AM75-TC motherboard, 3beeps, no video
Hi richardbyers, three short beeps means there is a problem with your memory. (Base 64K memory failure). Unplug the power from the PC. Open the case & touch the bare metal on the case to discharge your self.
Remove the memory & reseat it. Leave the case opened & re-connect the power cord & try booting again. If you still hear three short beeps, shut the system down again as mentioned above. Gather some house hold alcohol & a couple cotton swabs. Drip a drop or two onto a cotton tip & wipe the memory's contacts, both sides & do not touch the contacts with your fingers during re-install or cleaning. Blow the memory slots out with canned air or use a clean paint brush. Insert the memory again & connect the power cord. Boot the PC. Try this first. If everything works out than good. If the problem does not clear its self let me know.
Good luck richardbyers!
Mike
Jan 06, 2009 | DFI AM75-TC Motherboard
Hah alright now the comp is not booting up! =[
I think that you should get someone local to help you through this - unless you are confident that you can do it yourself.
I suspect that you may be right about the motherboard.
Did you take all precautions as regards static electricity when working inside the case?
But before replacing the motherboard - try the hard drive in another computer and another computer's hard drive in this one. I say this because you said there was nothing from the hard drive and they do fail occasionally.
Obviously if the HD works in another computer then it is the motherboard and vice versa if another HD works in your computer. This will allow you to identify which component is faulty. I still think you are right about the MB though.
Hope you haven't thrown away those Video Cards! They might both be good.
Good luck.
May 13, 2008 | Computers & Internet
Computers & Internet Logo
265 people viewed this question
David Payne
David Payne
