Question about Home
How to remove button mechanism on1984 carom a dual flush cistern to replace flush pipe rubber ?
    Top Expert:
  • 45,620 Answers
Normally corma cister controls are just a clip in arrangement
the bridge that holds the controls press fits into the front and back of the tank walls
lift the whole assembly out then do the repair
Posted on Dec 04, 2016
How to remove button mechanism on 1984 carom a dual flush cistern to replace flush pipe rubber
Info on these old dunnies is hard to find. A lot of Fixya patrons weren't born in 1984. This thread may be of help
http://forums.whirlpool.net.au/archive/1393153
Dec 04, 2016 | Home
The dual flush cistern does not empty when the buttons are depressed. They have to be held down to clear the toilet bowl. How can I fix this?
cisterns never completely empty as the setting of the mechanism to close the valve is activated when it gets heavier than the water supporting it
try allowing more water into the cistern on a fill by adjusting the water level control
get a plumber in to clean out the sewerage pipes as there appears to be an obstruction in the line
Jun 13, 2015 | Home
I have a dual flush consort cistern N 81008, it keeps leaking into the pan after flushing .
You will need to replace the seal under the flush valve, need to dismantle cistern mechanism.
Oct 19, 2014 | Home
Twyford dual flush cistern
replace the whole control unit
There may be 2 problems
the small washer that shuts off the water flow when the level is reached may be swollen and not sealing properly
the section at the bottom has cracked at a thread level
so by replacing the unit you will eliminate both problems
to remove the unit, turn off the water tap, flush the system, holding the button down until all of the water has gone
remove the inlet pipe at the bottom of the cistern
undo the retaining nut under the cistern and lift the control unit out
there will be water in the bottom of the cistern so use old towels on the floor to soak up the water that will run out
Mar 23, 2017 | Home
Tavistock Vortex White Slimline Concealed Cistern | VOR790
the clear and the blue pipes control half and full flush. They should both be connected to the main cistern. The small button should give a half flush.
Mar 26, 2012 | Home
How do i fix a cistern that is continually leaking in to the toilet bowl? i have tried to open the cistern at the flush button unit but do not want to force open. tried twisting but is quite tight.
most modern toilets do not have an overflow pipe to outside instead they overflow into the bowl itself so have to adjust level so it does not overflow into return
Apr 02, 2010 | Toto Aquia II Dual Flush Toilet
Weak dual flush does not empty the toilet bowl.
well, yes... but apart from providing you with a forum in which to vent your frustration I'm not sure how you think we might help. I have the same problem with a dual flush cistern, but in my case I know that the root of the problem lies in the fact that the soil pipe leading from the bowl has insufficient fall (because the previous owner of my house moved the toilet further from the down pipe). Maybe something like this is contributing to your problem too?
Jan 21, 2010 | Duravit 0910100005 Happy D Toilet Cistern ...
Cannot remove top of cistern
There are some dual flush cisterns where you have to depress one button to reveal a cavity in the second button. Put a screwdriver in that cavity to lever out the second button, then release the first button and prise that out.
Underneath the buttons is a screw which must be unscrewed to release the cistern lid.
Not sure if this will apply to you... but if not, good luck anyway.
Oct 29, 2009 | Duravit 0910100005 Happy D Toilet Cistern ...
Slow Flushing mechanism
Check the angle stop at the wall ( valve) if it more then a few years old the rubber inside sticks try turning it off and on a few times. Well first just make sure its open all the way to start. If both of those do not work It might have a screen at the opening of the preeure mechanism...check that the was no line trash caught in it from turning the water on and off. If none of these things work let me know and we can get more technical in find out whats wrong...heck you could have just gotten a bad one. The Plumbing company I worked for when I lived in houston had the contract with them to do there warranty work and boy did we do a lot of it .
Feb 03, 2009 | Eljer Aqua-Saver 12" Two-Piece...
Home Logo
117 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
