I need a manual for a mistral split system air conditioner model GZ1002B E3
  • 95 Answers
SOURCE: Error C5 LG Art Cool Split System Air Conditioner
Probably a capacitor in the either the compressor or outdoor fan. Don't know if they are dual capacitor or each has it's own. This is just according to the other posts on this site. I would call in a tech to have a look at it. Should be able to diagnose this in about 10 minutes.
Posted on Jun 09, 2008
  • 400 Answers
SOURCE: Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Posted on Mar 05, 2009
  • 81 Answers
SOURCE: Need to know what the icons stand for on remote
Generally all the symbols on each unit are the same. The snowflake does cooling, the sun does heating, the fan does fan only mode, the water droplet does dehumidify and the arrows means automatic mode. The increasing bars refers to the fan speed.
Mat
Posted on Jul 17, 2009
Johnny Reb
SOURCE: Remove and relocate split air conditioner
The simplest way of explaining this is as per the following. On your outdoor compressor unit there should be two pipes, one smaller diameter [high pressure] and a larger diameter pipe [low pressure]. Turn your A/C on inside the house and then shut off the smaller diameter pipe. Run the unit for a around 3 to 4 minutes and then check if the cooling is reducing from the unit inside the house. When you feel room temperature air [not cool] being emitted from the indoor unit shut off the larger diameter pipe and turn off unit. Isolate electrics, disconnect A/C piping and immediately seal the piping with good quality tape to prevent egress of dirt. When re-installing a quick purge of gas is usually only required to clear the lines if they were sealed properly and kept clean. Ideally running a vacuum pump is recommended but if care was taken then it may not be needed, as in many of my installations.
Posted on Nov 13, 2009
SOURCE: Mistral Air-con split system shows F6 fault! What does it mean?
F6 INDICATION MAY MEAN THAT THERE IS A PROBLEM WITH THE BLOWER MOTOR. WHEN THE BLOWER MOTOR GETS HEATED UP (WHEN ITS WINDING BECOMES WEAK) THIS MAY HAPPEN. SO U GET UR BLOWER MOTOR AND PCB BOARD CHECKED.
Posted on Dec 31, 2009
What is e3 when I turn my pye split system on
E3 on an some brands of air conditioners means faulty indoor coil thermistor, either mice have chewed through the cable or the thermistor itself is stuffed.
Good luck
Feb 13, 2015 | Heating & Cooling
Manual for mistral air conditioner model GZ-1002B-E3
http://www.service-aerconditionat.ro/Manual_Aer_conditionat_Galanz.pdf
Jun 29, 2013 | Heating & Cooling
My sairon split system ac unit does nothing and comes up with e3 on the display
if split ac display shows e3 what is the solution for that problem
Dec 10, 2010 | Heating & Cooling
My remote control will not turn on. The timer function comes on but nothing happens. model GZ-1002B-E3 mistral MSS2.6
take your chellphone and open the camera,then take the control and push any button in front of the chellphone.if the remote is ok you see a light blinking.if you didnt see the light the eye of the small plate have the problem.
Dec 09, 2009 | Hitachi RAS-09UH Air Conditioner
Nov 23, 2009 | Heating & Cooling
Low refrigerant?
never of you have no leak but if every thing is working and it is not cooling them you may need to do that...
Nov 08, 2009 | LG Art Cool LA1000PR Air Conditioner
Mistral mss15 aircon will not operate on heat setting , not sure if it is being set properly because cannot understand remote control symbols
My Mistral was working yesterday (on heat) now it won't. Just sits there as if warming up but actually blows out freezing air - on "sun" mode.
Jul 12, 2009 | Sanyo 24KS32A Cool Mini Split Air...
I have a Toyo Aircon TA 12C(H)S air conditioner that shows E3 on the readout and nothing will come on. Any ideas what the error codes mean?
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. E3 means low pressure of refrigerant. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck to you!
Jul 03, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
