Noise in the back of my coal stove ???? - Heating & Cooling
Just bought a house with a Gibraltar SCR stove in it. I want to use this thing, but have never owned a stove and don't know how. What fuel? How to set the fuel in the stove, etc. Can you help?
Gibraltar makes coal, pellet and wood stoves. Stoves that burn wood pellets have a hopper and feeder auger that feeds pellets into the burning chamber. They also require electricity to work. From what I read online you should be able to burn wood in the stove but I believe the coal stoves have a smaller burning chamber.
Nov 28, 2017 | Heating & Cooling
I am looking for a manual for an Atlanta Stove Works Homesteader Model 340ADG wood/coal stove that has been installed in a house I just moved into but has never been used.
Hello John,
Here is a manual for your stove, you can also call the phone number # 340ADG Here's a bit of history about your stove; Atlanta Stove Works there's even a PDF about a slightly different stove on this site.
Good Luck!
Rich Lilja
Jan 10, 2017 | Home
I need instructions for placing ceramic coals on a Cannon inset gas fire 26730G
Go to the wed site I Think stoves own cannon you should be able to your make of fire and down load a manual show how to replace your coals
Dec 06, 2016 | Heating & Cooling
I have a new Buck STove Hybrid (coal and wood). The brick liners in the ceiling are loose and frequently are dislodged when feeding wood. Why is it designed this way.
I would suggest contacting the manufacturer at this link in order to get an answer to your question. Each stove manufacturer has their own way lining the stoves. Make sure you have your model number and serial number of your specific stove prior to calling the manufacturer so they can give you an informed answer. Good luck.
Do you have questions or comments
Jan 09, 2014 | Buck Stove Home
How do I use the stove. We bought a house with a anthrasite stove, but we do not have an idea how to start it
Not sure which model you have, Reading Stove Co makes the anthracite model. Here's a link to their website Click on the Coal Stove Safety Tips tab and look for your model under Owners Manuals.
I hope all of this will be helpful to you.
Mar 11, 2011 | Heating & Cooling
My Dimplex coal effect black stove won't work. The problem started quickly. One time it worked, next it didn't. I have changed the fuse so that isn't the problem. Although the stove is about 12...
My Dimplex coal effect black Problem with the Dimplex Compact Electric Flame Stove Heater My Dimplex coal effect black stove won\'t work. The problem started quickly. One time it worked, next it didn\'t. I have changed the fuse so that isn\'t the problem.Although the stove is about 2yaer old, I have only used it about five times as it is in my drawing room that I sit in rather infrequently.I do hope you will be able to advise me the source of the problem.Thank you. salvador -
Oct 31, 2010 | Ovens
After installing the pellet stove,the stove seems to 'burn up" the pellets to fast not creating a "coal bed ',no real heat is going in the house.It is a breckwell big E mod. 55'000 btu...
Not sure what is happening but if the pellets are burning too fast that tells me you have to set the air flow while they are burning. Even a wood stove will burn to fast if there is too much air . There should be a setting for the air flow on all stoves and some times it should be almost closed. if it continues i would contact the stove seller and ask them.
Sep 04, 2017 | Heating & Cooling
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
