Question about Wahl Health & Beauty
How do I Put my Wahl model number cbto inside back together
SOURCE: walh pocket pro
I had the spring between the inner blade and outer blade. I simply moved the spring to under the inner blade and it worked.
Posted on Nov 05, 2008
  • 3 Answers
SOURCE: I took my Wahl clippers apart to clean ......
Okay I fixed mine. this is I what I did and it works now take the big blade and put it on a table, take the little blade and put on top of the big blade if you look closely at the big blade you can see where the little blade went, make sure you allign the blades. next take the white thing dont know what you call it bit it rotates the blades put that on the little blade, take the gold piece align with holes to the big blade and take the silver piece allign with holes and then put the screws back in. when you put it on the clipper make sure the white piece goes in the hole that rotates the blades and sould go in fine
Posted on Jun 20, 2009
  • 10 Answers
SOURCE: can i get detailed instructions to reassemble
Same problem here. Wish there was instructions online somewhere.
Posted on Jan 03, 2011
  • 4 Answers
SOURCE: HOW DO I PUT MY WAHL HAIR TRIMMER BLADES BACK TOGETHER
well the smaller blade sits on plastic piece that is coming out of the clipper, having the inside of blade towards you. then larger blade ,the inside of that faces smaller blade,and align them to where you can see smaller teeth thru larger ones put screw back in and tighten. then oil them.
Posted on May 26, 2012
  • 242 Answers
SOURCE: Who to reassemble a Wahl model cbto
Go to WHAL.com ..Use serial number and search for schematics to your model This will save time for you..
Posted on Apr 05, 2015
Apr 05, 2015 | Wahl Health & Beauty
How to put my wahl 5 star detailer back together
my back piece where the scruess atach broke help please where can i buy a new back piece
Sep 26, 2012 | Wahl 8081
I took off the head of the wahl clipper model # 5537n and now i cant put it back
I fixed mine same model what you do is take the big blade lay it on its backside all the increases face up and take the black pieace attach it so the bottom part with the open hole is face down allign inside and place this on the creases with blades backside together then hold against clippers attach screws and wolla
Jan 15, 2012 | Health & Beauty
Nov 10, 2011 | Wahl 9854400 Hair Trimmer
How do reassemble the blade for Wahl 8552
I had the same problem with the Wahl Pro Series Rechargeable model 8552, and called Wahl service. Here is what I learned:
Never unscrew the screws on a Wahl blade (they use those funky nonstandard screws to deter you) -- that's the main thing. The whole blade assembly is supposed to come off by pulling it up and off from the teeth.
But, if you did it (as I did), you can put it back together this way:
1. Place the large blade down on the table (Wahl logo down), and place the small blade on top of it (if you look carefully, you will see how it lines up).
2. Insert the spring points into the two holes of the white plastic part (on mine, the spring kept slipping out and I finally used a drop of superglue on each hole until it would stay in long enough to complete the assembly). Place that piece on top of the small blade (see photo).
3. The bent metal piece with the two screw holes then gets placed on top of the large blade, with the center ridge of the bent piece over the straight center portion of the spring -- so that you have to hold it in your hand and push it together against the spring in order to align the holes of the entire thing. As you are holding that, put the screws in from below and tighten. It's awkward and if you are like me, it will take several tries before you can get it all lined up correctly and tightened. The photo below is what the final assembly looks like before snapping it onto the clipper.
3. Clip it in: At the top of the assembly in the photo below, notice the small bent metal piece that will fit into the back of your clipper in the hole. Once you fit that properly, push the whole assembly down onto the clipper until it snaps into place.
Aug 03, 2010 | Wahl Health & Beauty
I took the bland off of my wahl model 9860-1101. And the pin spring came out and I don't know how to put the pin sring back in. How to I put it back together?
Your best bet is to send it to www.mannyssharpening.com Contact mannyssharpening@yahoo.com they are a Wahl Dealer they have all the parts for Wahl clippers.
Mar 13, 2010 | Wahl 9916-800 Groomsman Beard Trimmer
Jun 08, 2009 | Wahl 8550
Health & Beauty Logo
115 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
