Question about GE Refrigerators
Gshs6hgdbcss keypad combination to go to diagnostic mode?
Error on wc 7120 xerox 124-315
  1. Enter Diagnostic Mode ( UI Diagnostic Mode).
  2. At the Control Panel, press and hold the 0 key for 5 seconds, then press the Start button while still pressing the 0 key.
  3. Press buttons 6, 7, 8, and 9 on keypad and press Confirm.
  4. Press the Log In/Out button (button with Key symbol) on the Control Panel.
  5. Select System Settings.
  6. Select Common Settings.
  7. Select Maintenance/Diagnostics.
hen look at these 3 locations and see if they match, If they do not set them to match the machine speed.
Mar 12, 2013 | Office Equipment & Supplies
My numeric keypad has stopped working, including all of the keys around the numeric keys, the number lock is on. What do you suggest?
Have you tried booting up in safe mode to see if it does the same thing? Also check your keyboard to see if there is some type of key combination that locks or unlocks the numeric keypad. If so, usually you will have to hit the FN key or the ALT key or the CTRL key plus some other key to get it to toggle.
Mar 31, 2012 | Computers & Internet
My numeric keyboard is not working, the num lock is on.
Mar 31, 2012 | Toshiba Computers & Internet
I keep getting f2
Sorry to read about your problem, I hope this helps you out.
f2 is a defective keyboard/keypad issue, i suggest you contact a service company
Their is nothing you can do to stop the problem.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My dryer is stuck on "Control Lock"
See if you can get into the diagnostic mode. If not, you will need to replace the "user interface" on the machine. Here is a link to the part if you should need it.
ACTIVATING THE DIAGNOSTIC TEST MODE 1. Make sure that the dryer is in the "Standby" mode (plugged in and all of the indicators are off). 2. Press the following control panel keypad sequence all within 5 seconds: More Time-Less Time-More Time- Less Time. 3. All indicators on the console should now be illuminated with "88" showing in the "Estimated Time Remaining" display, if this test mode has been entered successfully.
Dec 26, 2010 | Whirlpool Duet Front Loading Dryer Rack...
What is the keyboard combination for Ñ in a
Alt+0241
On Windows, the Alt key functions as a modifier like the Shift key. To make special characters, hold down the Alt key and type in the numbers from the numeric keypad. Note that on the some small keyboards (e.g. laptop keybaords) the “numeric keypad” is found by pressing the NumLock key and then looking for the keys on your keyboard that double as numeric keypad keys when in NumLock mode.
Jun 23, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
My hottub want raise the temp above 89 on the control panel it says sl 89 i know it has three modes sleep mode econo and standard but how do i change the modes? the tub is a nordi sport
Some hot tub keypads have a 'mode' button. If yours doesn't try pressing 'warm/temp' followed by 'Jets'..... it's usually a combination of keys that changes the mode and this one springs to mind but I could be wrong.
Good luck,
Ian, from: http://hottub.synthasite.com
Jun 01, 2010 | Pool & Spa
I have a Precor EFX544, old, that won't display times correctly, counts down to 5 seconds then quits, any suggestions. When I do diagnostics, I get what I think reads Life 109?
In diagnostic mode you have 5 modes LED Diagnostics,Lift calibration number check, identify software version, heart rate diagnostic and keypad test. other than that I suspect that the upper console is going south. You can sent the upper console for repair. Contact National Gym Supply @ 1-800-496-7278 and they will give you pricing and address to send to.
May 19, 2010 | Precor EFX 546i Elliptical Version 4
My Xerox Copy centre C123 shows error code 124-315 pls help
Thats a weird one. The machine is detecting the wrong speeds.
Try this.
Then look at these 3 locations and see if they match, If they do not set them to match the machine speed.
  • [700-600]
  • [700-601]
  • [700-602]
Feb 11, 2010 | Xerox CopyCentre C123 Copier
Will not boot to Safe Mode
Try to boot from the Resource CD by selecting the <F12> key and select boot from CD/DVD drive. If you tried to run the "Diagnostics" option from the <F12> boot menu and it went to command prompt, there might be an issue with your hard drive or the "Diagnostics" partition is corrupted or missing. If all tests pass using the Resource CD, then your OS is probably hosed. As for the 9 LED light, that just indicates that your numeric keypad is enabled.
Oct 17, 2008 | Dell Latitude D510 Notebook
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
