Question about Cameras
Hi I have a new elite7ti on a pro angler 14 was on water went to turn on nothing but beeps no screen at all battery fully charged only 2nd time used first time no probs appreciate the help cheers
  • Cameras Master
  • 5,412 Answers
What make of camera is this accessory attached to ?
Posted on Dec 04, 2016
Testimonial: "Hey thanks but it's a fish finder not a camera"
  • Tony Parsons
    Tony Parsons Dec 04, 2016
    In that case, why did you post it in a forum dealing with Photographic Equipment. The only connection I can see is with a fish-eye lens.
It is unlikely that the capacitor will have any charge on it so you should shake it gently to charge it up. You certainly can't do any harm by charging it, even if the capacitor did have any charge.
Feb 20, 2011 | Seiko Kinetic watch
My mobile problam is no display and no working
davidscott3 . I fully sympathise, dheerajsi506 , because the same happened to me today , 14 June 2010 .
First I put the SIM in the wrong way round.Then I forgot to load the battery . Charging the N 1661 went OK . Then I had no screen display no matter how many times I pressed the Power key in red . I tried holding it down a few seconds , nothing .Read the small manual several times . It does not always explain fully .
Eventually I went to my local Vodafone shop.The guy got it going in 2 seconds ! He did the same as I had tried .I have found before that my hands seem to interfere with new gadgets .It now works just fine .
I suggest you ask someone to try for you ,to get your luck back .
Jun 14, 2010 | Nokia 1661 Cell Phone
My bike has a new battery. I ran it a few weeks ago with no problem. Today, it started right up, and then died. When I tried to turn it over, it clicked, and then nothing. I push started it and rode it for...
Did you get your problem fixed. I have a similar one - new battery - started fine several times and now won't start without hooking the battery to either a jump or putting on a charger. If you can help - I am w8bnl at yahoo dot com. Tom - thanks
May 19, 2010 | 1995 Suzuki VS 800 Intruder
RC1 - New batteries fitted but display still blank.
Hi,Not nessarly shot.The stat uses low voltage from the equpitmemt also.You neea a volt meter to check.Remove stat from mounting plate.Check power at terminals RH&W or at RC&G they should read 24volt.If not check emergency switch off or fuse/breaker.
Apr 15, 2010 | Heating & Cooling
New camera with fully charged battery won't turn on
It may be something more serious, or your new batteries may be too low for the camera to work properly, but the problem you describe is frequently due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion buildups may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment, clean the contacts at both ends of the batteries, and reinstall them in the camera. Assuming that the batteries are fresh/fully charged, this takes care of about 90% of the startup problems. I hope it works for you.
Sep 06, 2009 | Samsung SL202 Digital Camera
Put new batteries in, camera bleeps three times & switches off
hi meeshfriel,
The battery might be damaged. try recharged the battery at least 2 hours maximum of 4 hours. If the problem persist it is your battery needs to be replaced......
Dec 14, 2008 | Samsung Digimax S800 Digital Camera
Powered off.
Any beeps when you turn it on? unplug everything and then plug it back in. Make sure the monitor connections are good and that you have it turned on. Again make sure it's turned on. Sometimes it's the simple stuff. Was the monitor working well before it failed? Do you have a video card?
Remove the battery, AC, count to ten and try one last time?
Jan 01, 2008 | Compaq Evo N610C Notebook
Wont turn on
Are you sure that your batteries were fully charged? I have the same issue when using shop bought aa batteries - or they don't last very long at all.
That 3 beeps and turning off is what should happen along with a "battery low" error message on the screen from experience.
When I bought the recommended charger and two batteries from Amazon - they lasted a lot longer. Search the website for the charger battery code suggested in the instructions.
Dec 16, 2007 | Samsung Digimax S730 Digital Camera
Dead phone but keypad flashes
replace the LCD + flexcable on the phone.
Aug 02, 2007 | Motorola Mobility RAZR V3
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
