My remote does not operate the aircon.
Remote is new.aircon can be operated manually
  • 27 Answers
Batteries ?! If you have a digital camera use it to look at the infra red bulb on the a/c remote whilst you are pressing buttons on the remote. Digital cameras pick up the i/r light and it will show up brightly on your camera screen. If there's no light then the batteries are duff , in the wrong way round, or have dirty contacts. If there IS light then check the a/c unit itself. The i/red receiver lens could be dirty on the a/c unit itself.
Posted on Dec 04, 2016
I have a 2004 lancer Es when I turn the aircon on after 15 minutes of driving I cant change the gears the aircon works fine but renders the gears useless and have to turn it off to continue to drive
There is no relationship between the air conditioning system and the gear box in the vehicle.
The engine operates the aircon compressor via the serpentine belt from the crankshaft pulley and if the aircon is operating normally the aircom compressor will not be faulty either.
If you are having problems with the gearbox it has nothing to do with the aircon system. The issue will be with the gearbox itself.
Dec 27, 2015 | 2004 Mitsubishi Lancer
LG aircon operation light flashes 8 times and then shifts to timer light flashes 4times and then back again to operation light but aircon is not operating.
jz on the aircon manuly on inside the front door.lift the front on the indoor unit there the on/off button,jz press it.don't use remote it can help u
Apr 20, 2014 | LG Heating & Cooling
My airwell aircon won't respond to my remote, my
HOW TO INSTALL BATTERIES Remove the lid in the rear part of the remote control unit.
Insert two AAA alkaline batteries of 1,5 V-DC. Make sure the batteries point in the direction marked in the battery compartment.
The batteries last about six months. Depending on how much you use the remote control unit. Remove the batteries if you do not use the remote control unit for more than one month. Press the +, -, SET and CLEAR buttons together after batteries replacement.
(This operation allows you to reset correctly all the programs. The remote control unit is to be set up again).Replace the batteries when the remote control unit lamp fails to light, or when the air conditioner does not receive the remote control unit signals.
The batteries of the remote control contain polluted substances exhausted batteries must be disposed according to the laws in force.
Jan 12, 2013 | Heating & Cooling
Remote does not turn on Panasonic CS-A28BKP5
Point the remote control IR LED at a digital camera such as your phone camera (The LED is usually on the top of the remote and is what is used to transmit a signal to the receiver board on the head unit). When you press any button on the remote, a purple flash from the LED should be seen on your camera screen. If not, you have a faulty remote. If you see one, you probably have a faulty receiver board and will need to replace it.
May 11, 2017 | Panasonic Heating & Cooling
Aircon no longer responds to remote handset
Open the front again and make sure that the operation selector is set to remote control. If it is, then I suspect that your remote sensor reciever on the aircon unit is bad. It is very simple to replace.
May 06, 2009 | Heating & Cooling
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
More than likely it is the remote sensor in the indoor unit. Then again I presume that it is the correct remote control. Sometimes a remote for one aircon may not communicate with another aircon even if they are the same brand.
Jan 24, 2009 | Heating & Cooling
My LG plasma gold ac's remote controler
If you lift the flap on your indoor air con there is a Emergency operation button on your right you can operate the aircon from there. Push once for 20 cooling and twice for 22 heating
But sounds like you need a new remote. If you want to know how to test the remote please let me know
Hope that helps
Nov 16, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
