Question about Coffee Makers & Espresso Machines
How do I set keep warm function on Krupa 321 coffee maker
SOURCE: coffee maker
get up at 659 am. seriously the pots have a 2 hour automatic turnoff feature for safety purposes-no fix.
Posted on May 05, 2008
  • 9 Answers
SOURCE: Funky Coffee Maker --isn't working
This is generally caused by a clog in one of the water lines ..Take the bakset out , and check for clogs in it that could be preventing it from dripping into the canister ... Next remove the filter and run a fairly strong vinegar solution through it followed by a rinse .You may need to do several pots of vinegar . Also check to make sure you are putting the right amount of H20 in your maker as it will evaporate some during brewing .. You may need to also go to a comercial cleaner to clean it out . You can also unplug it and tip upside down and hit it with some cold water from the hose on the sink . Lastly replace your filter (in the water chamber) In the case of this not working you may wish to contact the mfg for replacement .Or if there is no longer a warrenty you may wish to replace it .
Posted on Sep 16, 2008
  • 4 Answers
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Posted on Nov 15, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: how to clean the coffee maker & set warmer
In order:
1 and 2) Clean the coffeemaker by puring in 1/3 caraffe vinegar, and 2/3 caraffe water. Either use the self-clean light or brew it as if it were regular coffee - just press the on button and then press the self-clean button, and it will begin.
3)
The Automatic Shutoff Time can be programmed
anywhere from immediate shutoff
after completion of the brew cycle up to four
hours. When the coffeemaker shuts itself off,
two tones will sound. Four hours is the default
time. The 0:00 setting shuts the unit off immediately
after brewing is complete. To check the
current setting, press the “On/Off” button and
the Automatic Shutoff Time will be displayed.
To change the preset time, press and hold the
“On/Off” button until the red “power” light
begins to flash. This signals that you have
entered the “Set Automatic Shutoff” mode.
Press the “Hours” and “Minutes” buttons
to scroll forward through the digits until
desired time appears. The first setting which
appears is preset at “4:00” and the next
display will be “0:00”, since four hours is the
maximum Automatic Shutoff setting. Pressing
and holding either button will allow you to
scroll continuously, slowly at first, and then to
accelerate to the rate of about three digits per
second. As the desired time setting approaches,
release the button and then press repeatedly
to advance one digit at a time.
The Automatic Shutoff Time (ASO) may be
programmed either before or during coffee
brewing. You may also re-program the ASO
time when brewing has been completed. If you
do so, the Automatic Grind & Brew™ will automatically
account for any time that has already
elapsed after brewing. For example, if you set
the ASO for 40 minutes and 25 minutes have
already elapsed, the Grind & Brew™ will shut
off automatically after 15 minutes (40 minutes
minus the 25 elapsed equals 15 minutes).
-Tha Mp3 Doctor
Posted on Mar 28, 2009
SOURCE: Cuisinart DCC2000/how to set it to keep coffee warm for 4 hrs
From my Cuisinart DCC-2000 Series Manual: The AUTO OFF feature is used to shut off the coffeemaker at a preset time, anywhere from 0 to 4 hours.
To program the Variable AUTO OFF:
1. Turn the function knob to "Auto Off". Press and hold the "Hour" button for 2 seconds. The clock display will start blinking.
2. Program the coffeemaker to shut off from zero to four hours after brew cycle is finished by using the "Hour" and "Minute" buttons (see "TO SET THE TIME").
TO SET THE TIME:
1. Turn the function knob to "Clock".
a. SET HOUR: Press and hold the "Hour" button to scroll through numbers quickly. When number displayed approaches the desired setting, press and release (pulse) the button to advance one digit at a time. After setting the correct hour, the default will be the last time set unless power is shut off.
NOTE: When the number count passes 12, the PM light will be displayed on the LCD.
b. SET MINUTES: Press and hold the "Minute" button to scroll through numbers quickly. When number displayed approaches the disired setting, press and release (pulse) the button to advance one digit at a time. After setting the correct minute, the default will be the last time set unless power is shut off. To finish setting time, turn the FUNCTION KNOB to any other setting or simply wait until the numerals stop blinking.
(P.S. The picture of the coffeemaker shown above on this page is not the correct model I have as a DCC-2000. The picture shown has a coffee pot. The DCC2000 has a coffee reservoir and a dispensing lever for dispensing coffee into mug or cup.)
Posted on Jun 29, 2009
Can on/off red light be fixed on a krups 321. cofeemaker works
The bulb in the switch button will be faulty, it is not available separately from the switch and the switch is obsolete with no alternative part number supplied.
Sep 21, 2015 | Krups ProCafe 321 Coffee Maker
Our Delonghi Prima Donna always made hot coffee up until 2 weeks ago
Try first to heat the cups ,and then make the coffee.
Becouse the water for coffee and for hot water comes from the same way.
Apr 25, 2017 | DeLonghi Prima Donna Avante ESAM6700...
Will not start making coffee push start after 30 second message on screen err2 model kcm5340bo gerald larsen 1-630-323-3112
This is to do with an error in the warming plate function. You may be able to cure this error by completely unplugging the coffee maker from the mains lead and then plugging it back in and trying to brew. If this does not help I would suggest trying to contact the manufacturer to see if it is still under warranty.
Hope this helps and thank you for usinf FixYa
Aug 30, 2010 | Microwave Ovens
How do you set the clock and program to brew at a specific time?
To program the Auto On
1. Set the desired Brew-Start time.
a. Turn the FUNCTION KNOB to “Prog”.
b. Set the time you want coffee to begin
brewing by using the minute and hour
push-buttons. Follow the same instructions
you used to set the time of day, in
the To set the time section above.
2. Turn the FUNCTION knob to the “Auto On”
position. LCD will display the current time.
3. Lift and release the FLIP SWITCH. The
green indicator light will come on to remind
you that the programming function is in use.
At the programmed time, the red light will
come on as well, indicating that the brew
cycle is starting. Both lights will go off when
keep warm cycle ends.
NOTE: To reactivate the auto-on feature to
start brew cycle at the same time another day,
simply lift and release the FLIP SWITCH. The
green “auto-on” light will illuminate.
Aug 16, 2010 | Cuisinart DCC-1200 Coffee Maker
Brews finw but won't keep coffee hot
Could be the thermostat sensor, or the warm mode heating element, or the section of the control module for the warm mode. The details are model dependent.
If the coffee maker is out of warranty, it may not be worth servicing.
Jerry G.
May 12, 2010 | Hamilton Beach BrewStation 47224 Coffee...
TO SET THE TIME:
Jun 13, 2009 | Cuisinart Coffeemakers
Need assistance on how to program the timer for my cuisanart 12 cup coffee maker
The manual can be found here:
http://www.cuisinart.com/share/man/25_man.pdf
Mar 24, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Kitchenaid coffee pot won't brew coffee reads err2
An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears.
If it does reappear, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Their toll-free telephone number is 1-800-541-6390.
Mar 13, 2009 | KitchenAid KCM511 Coffee Maker
Nov 15, 2008 | Cuisinart Coffeemakers
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
