Question about Emerson Refrigerators
I have an Emerson Refrigerator Model No: CR286BSE and it out of nowhere it stopped working and know it is making a clicking noise and will not cool anything at all but the compressor gets hot.
When i leave it running the compressor gets hot.
    Habit-Forming:
  • 107 Answers
Your compressor is shot, I would recommend not letting it run, it could over heat and develop a leak, the refrigerant is extremely toxic, and if it ignites creates Phosgene gas which is incredibly dangerous. IF, you can find a compressor for the model it may be worth it to replace it, or buy a new one. Good Luck!
Posted on Dec 04, 2016
Cr286bse will not cycle compressor when inside warms
It's the thermostat, had the same issue, just stopped working out of now where, popped the arrow cover off, single screw. As soon as I was pulling it off, the fridge kicked on. I didn't check the wiring but will next time it goes out.
Jan 12, 2014 | Emerson Refrigerators
I have an Emerson Refrigerator Model No: CR286BSE that no longer workers after only two months.
Similar model Emerson compact fridge died in my wife's office after only a few months of use. I assumed it was the compressor, but there was no puncture or serious issue. Next thought: thermostat. I opened the thermostat inside the fridge (unplug everything first) and while it didn't turn on I saw that the wires and connectors seemed fine. On closer inspection the temperature control has a metal pin on a spring that SHOULD slide with the temperature control but seemed to not really move. It slid on a not-quite-circular mechanism but it didn't extend the spring or really change position. I turned the thermostat and forced the springed pin back to the top position (a small notch). This, apparently, is the natural "off" position. Release again and the pin slid normally with the thermostat. Plugged in the fridge and it began cooling quickly. I'll test it again later (I turned it off to let the coolant re-settle in case it had bubbles from me moving it around so much), but fingers crossed... this seemed to work.
In short, I think the fridge's thermostat has a faulty design that can slip so that turning the thermostat makes no difference to the temperature or output. Because the metal isn't touching the inner component the compressor just doesn't turn on. The fix took only a phillips screwdriver to open the thermostat box and I used a flathead screwdriver (you may be able to use your nails) to return the pin onto its wheel mechanism. I may be completely wrong, but it worked for me. :-)
Oct 24, 2013 | Emerson Refrigerators
Just bought a used westinghouse RJ275M fridge. It seems to work fine except for the noise - it has a low hum and rattling noise.
It can be compressor fan noise,may be motor getting overheated and causing noise.It has to be inspected.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Honeywell compact refrigerator model # 88031not cooling.
Honeywell compact refrigerator model # 88031 making a clicking noise, not cooling, interior light blinks, and the fans in back are not working properly....seems as if it's not getting full power. worked fine for about a year and justed stopped.
Mar 18, 2010 | Refrigerators
Making a clicking noise and not cooling
This could be a relay on the control board or the compressor is short cycling or both. You can use my assistance to help you resolve this or call a technician, this depends on you. I am very familiar with the Artica/Profile and know that if you can follow instructions and use a test meter we can get this fixed. I would like your complete model number so I can refer to the exact model you have. I will leave you contact information and a service manual and a web page to use with the diagnostics. This problem will not get better, Sea Breeze
Jan 26, 2010 | GE Profile Arctica Stainless Steel Top...
Maytag refrigerator clicking noise and stopped working
How long a period of time have you noticed this noise? If it just started and the refrigerator just stopped it could have entered its defrost cycle. When the defrost heaters come on you may hear the heat causing some expansion. After a few minutes(18-22) the defrost cycle ends and the refrigerator will restart.
May 30, 2008 | Jenn-Air JCD2389G Side by Side...
Ge side by side refrigerator
what is your serial #
Jan 06, 2008 | Refrigerators
Side by side stopped working but clicling noises every second two.
Ok the motherboard is malfunctioning. Ive observed this exact problem before. Replace the board and all will be normal again. If you keep lettig it click and click it may finally kill that relay that you descibed to me or even worse the compressor itself.
Dec 02, 2007 | GE GSL25JFR Brushed Steel Side by Side...
Refrigerators Logo
102 people viewed this question
Top Emerson Refrigerators Experts
John Tripp
John Tripp
Johnny 1000
Level 1 Expert
Are you an Emerson Refrigerator Expert? Answer questions, earn points and help others
