Question about Craig Televison & Video
How do I connect my Craig 904 to my tv - Craig Televison & Video
My Craig High Def LCD TV has lost its signal when I connect my HDMI cable. Do I need to upgrade TV Software?
Chances are real good it's a bad HDMI cable. Try swapping it out with one you know works.
Aug 22, 2015 | Craig Televison & Video
My Craig TV is a year old, I have volume but no picture
contact craig to get warranty service,tell them its 11 months old
May 06, 2015 | Craig Televison & Video
Onn codes for craig cht 904
0163 0351 0697 0338 0509 0654 0468 0044
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window".
Feb 19, 2015 | Universal Televison & Video
How do I scan a Craig LED TV for digital channels?
If it is fairly new it should be able to scan for Digital Stations. Connect it to an antenna that you know works on another TV and you can go to www.TVFOOL.com and it will tell you what stations are available at your address and what type of antenna is needed.
Dec 03, 2014 | Craig Televison & Video
I accidently put the rca wires in the wrong audio input/output on my craig cd graphics karaoke player.Could this be why i have no sound?
The RCA outs are designed to send a signal to an external amplifier. That amplifier, in turn, sends the music signal to speakers.
The RCA inputs are designed to take audio signals from another device (like an ipod, CD Player, or computer) and play it through the Craig System speakers. If you sing into the microphone, the vocals will be mixed with the incoming music. However, in these cases, there won't be lyrics on the screen. If you play a karaoke DVD in a DVD player, connect the red, white and yellow RCA cables from the DVD out to the Craig Inputs, the lyrics should appear on the Craig screen while the music plays.
If you mistakenly plug RCA cables into the Craig Inputs and plug the other end into an amplifier's inputs, neither will produce any sound.
Using RCA outs is only necessary if you want to have louder music than the on-board Craig speakers can handle. Of course, you can run the yellow video cable to a TV RCA input to get a bigger lyrics window and the RED and White RCA to the TV RCA Red and White inputs to hear the music through the TV's speakers.
Aug 30, 2014 | Audio Players & Recorders
Craig
This TV cannot connect via HDMI. Electro help
Jul 19, 2014 | Craig Televison & Video
I want to connect my Craig electronics cht754 5.1 home theater with dvd to my emerson tv
It has nothing to do with how you hooked it up, It is just not compatible with that (TV) I hate to tell you,
Dec 02, 2012 | Audio Players & Recorders
Craig clc501 tv
you should contact the store, bring the tv and receipt see if you have a 1 yr warranty.
the tv has vga cable.connect to pc or laptop, you can watch tv shows,i have one still works. if you dont have the correct chords,the tv will not work. you need antenna to watch tv. you can order antenna from amazon. if you have cable you connect the silver part back of the tv, rotate you tv for signal.i t can be just need to rotate the tv for signal. i had to do that sometimes, signal can be bad in some parts of the house.
you can take it to best buy with charger,and vga chord, to testing, tos ee why your tv isnt working. they dont charge, .its free.
Jan 03, 2010 | Televison & Video
I have just brought a Ikasu f8l 904 but it has come without a manual does anyone know where I can get one so I can set up my tv.
If you just go to google and put in, manual for a Ikasu f8l 904, it gives you various options a few of then are so you can download the manual.
Dec 29, 2009 | Televison & Video
Televison & Video Logo
27 people viewed this question
Top Craig Televison & Video Experts
Raj Patel
Are you a Craig Televison and Video Expert? Answer questions, earn points and help others
