Question about Hardware & Accessories
My IIIWoods Outdoor 24-h74 digital Timer 3-c keeps shutting itself off f within 5 seconds of my resetting it. Why and what can I do to correct it.
  • 3600 Answers
SOURCE: timer won't turn off or on by itself
Pull the pin up wait and see if it comes on you will know then. Most do pull up but there are a few that have the pin that has to be shoved in. 90% however do have to be pulled up to set the timer for off and on.
Posted on Oct 02, 2009
Testimonial: "The problem was trying to decide if the pins up or down turned it on and off. I think I have it figured out now. UP (i think) makes it turn off & on."
  • 3 Answers
SOURCE: Westinghouse 3-Outlet Outdoor Heavy Duty Digital Photocell Timer This is the manual that you seek!
Posted on Jan 06, 2010
SOURCE: my 24 digital timer its
If plug-in timer does not display, then
1) Reset button has tripped > push reset with paper clip
2) power is off > plug something else in receptacle to check receptacle
3) timer is loose in receptacle > unplug timer, spread prongs a bit, and plug back in
4) timer has gone bad.
Except for a few Woods and Intermatic outdoor timers, plug-in timers have internal rechargeable battery. Battery is not replaceable so when battery goes bad, the timer is bad.
See other Woods plug-in timers:
59203 plug-in timer at Amazon for $12
If you buy a timer, save the instructions like gold so you don't have to write fixya next year looking for instruction that nobody can find.
Posted on Nov 19, 2010
SOURCE: I lost the instructions for
Check following link to identify timer and download manual:
Woods timers go by more than 1 number and are repackaged and sold under different brands >> a few older Woods timers and promotional timers don't have manual on line.
Posted on Dec 05, 2010
SOURCE: how do I reset my
Open following link to identify timer and download manual:
The reset button is small round button with R
I assume you push reset button with toothpick
The manual is unclear if you need to press another button at same time to reset timer
Manual says: If needed, pressing "R" will cancel the current setting,
pressing "R" a second time will undo the change.
Posted on Mar 27, 2011
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
display Abnormality / Protection control Abnormality
Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica
tion > 1 min after starting
operation Indoor fan operation
only • Internal / external cable connections
• Indoor / Outdoor PCB H14 Indoor intake air temperature sensor
abnormality Continue for 5 sec. - • Intake air temperature sensor (detec
tive or disconnected) H15 Outdoor compressor temperature sensor
abnormality Continue for 5 sec. - • Compressor temperature sensor
(detective or disconnected) H16 Outdoor Current Transformer open cir
cuit - - • Outdoor PCB
• IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance
continuously - • Indoor PCB
• Fan motor H23 Indoor heat exchanger temperature sen
sor abnormality Continue for 5 sec. O
(Cooling only) • Heat exchanger temperature sensor
(detective or disconnected) H24 Indoor heat exchanger temperature sen
sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor
(detective or disconnected) H27 Outdoor intake air temperature sensor
abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec
tive or disconnected) H28 Outdoor heat exchanger temperature
sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature
sensor (detective or disconnected) H30 Outdoor discharge air temperature sen
sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec
tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance
• Ventilation motor H51 Nozzle lock abnormality 2 times occurance
continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance
within 30 minutes - • Indoor PCB
• Fan motor H98 Indoor high pressure protection - - • Air filter dirty
• Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro
tection - - • Insufficient refrigerant
• Air filter dirty F11 Cooling / Heating cycle changeover
abnormality 4 times occurance
within 30 minutes - • 4-way valve
• V-coil F90 PFC control 4 times occurance
within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance
within 20 minutes - • No refrigerant
(3-way valve is closed) F93 Compressor rotation failure 4 times occurance
within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance
within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro
within 30 minutes - • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor) F97 Outdoor compressor overheating protec
within 10 minutes - • Insufficient refrigerant
• Compressor F98 Total running current protection 3 times occurance
within 20 minutes - • Excess refrigerant
• Improper heat radiation F99 Outdoor Direct Current (DC) peak detec
tion 7 times occurance
continuously - • Outdoor PCB
• Compressor
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
Oct 13, 2017 | Panasonic Heating & Cooling
Why is my IIIWoods 50013 outdoor 24 hour timer switching to OFF regardless of setting? How do I fix it?
First start with the reset button, clears out all past commands.
First the clock has to be set to the proper day and time, It might be in the 24 system versus AM and PM you can find this out by stepping through all the hours when the time comes on. To set clock press Set and see what is flashing, if it is the day, scroll to the right day and hit set, now time should flash scroll to right hour, press set, right minutes, press set, right seconds, press set; Now the clock should be set.
Next you do the programs you want again go through same process, hit program 1 should flash press set, now the days should flash, scroll through till you have the right combo of days, one day, all days of week, Sat, Sun, then last the whole week will flash, if that is the one you want then press set, now press set and the times should flash for hour.
pick the time you want to come on, hit set for hour, minute, second, then hit set again now hit the program button again and it should say off, go through the same steps and set hour, minute second then hit set for last time. In a few minutes it should change to reading the time on the screen. Then you have to wait and see if it works. To do a mini version, see if it will work get a lamp plug in set all the above but use a very short on off time like 4 or 5 mins, then you will know if it is going to work right. then set for the correct time. good luck hope it helps. If it all messes up just hit reset and start all over, REMEMBER it can't so anything until the time of day is set right that's the starting point.
Dec 04, 2016 | Hardware & Accessories
Kodak digital frame shuts off after 5 to 15 seconds
This sounds like a setting issue on the photo frame. You should check for a timer for screen time on the frames menu.
Jan 02, 2014 | Photography
How to open to repair Woods 24 Hour Digital Outdoor Timer with Photocell Mfr # 13660
1) Copy following link to identify timer, and select replacement if needed.
2) There is no reset button on this type of timer.
Nor is there a repair manual for $16 timers.
Generally people buy another timer since the timing chips and parts are delicate, easily damaged by power surge, and often quit working before 1 year warranty expires, and usually last a few years before no longer functioning. The photoeye sensor is often a failure point.
3) Check outlet for 80% rated voltage.
Check timer on different outlet.
Use circuit analyzer and test outlet for correct polarity and grounding.
Test and replace GFCI outlets as needed.
Dec 01, 2012 | Woods Outdoor Lighting Timer
IIIwoodS minuterie MODELE N1502 MANUAL
Copy following link to identify timer, and download instructions for 1 button timers, and other common timers.
If this is not your timer, then add a comment and describe timer in detail, and/or scroll through timers on link above and find same-similar timer and download that manual and see if it works for your timer.
Nov 28, 2012 | Woods Outdoor Photoelectric 24 Hour...
Procedure for resetting your lamp timer,
Use the Remote Commander to put the set into service mode to display the service menus.
1. TV must be in standby mode (Power off).
2. Press the following buttons on the Remote commander within a second of each other: DISPLAY ==> Channel 5 ==> Volume + ==> POWER. The first service menu (TV) displays.
To reset the Lamp Timer:
1. Press the JUMP button 3 times on the remote to get to the Panel OSD mode.
2. Next press the remote channel 2 button 9 times to get to the Lamp Timer mode.
3. Press the remote 3 button, mute, then enter to reset the timer to zero.
It will take 45-50 seconds for the timer to reset. After the timer is reset you can shut the TV off. The lamp timer will remain reset (no need to save).
Jun 30, 2011 | Sony Televison & Video
GE Indoor Outdoor Timer # 15306 the clock is working and the when the time for it to go on it goes on but when the time comes for it to shut off it does not trip the off switch. I then have to shut it down...
1) If analog dial keeps time, I can only guess that OFF tripper is not in position correctly, or tripper is worn or defective, or that manual override lever is defective. Trippers are made of softer metal so they wear down before other parts of timer.
2) Buy Tork P47 trippers to replace GE 15306 trippers
3) Open following link for GE timer resources:
4) 15306 is heavy-duty indoor-outdoor version of Tork 1800 series or 7200 series 120Volt analog timer that is sold online and at Home Depot under GE brand name.
5) You can buy new timer at Home Depot and return defective one in new package.
6) The on and off trippers are attached to the analog dial.
Dial rotates as time passes.
Trippers make physical contact with the manual override lever. The ON tripper pushes lever one direction and the OFF tripper moves lever other direction.
The override lever rotates a cam located on back of timer that opens and closes electrical contacts.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 02, 2011 | General Electric GE 56941 24-Hour Outdoor...
Will not keep proper time & looses program after one cycle. I came home tonight @ 0030 & even after installing a new battery in & reprogaming it today ,it was showing 0630am when I got home .
You posted under a popular timer sold with GE, Westek, and Utilitec brand names:
Open following link to identify timer for sure.
If you have different timer, hints below might apply.
1) I test timers, and some arrive defective, and some go bad within a year, but most last a few years.
2) To reset timer, unplug for several minutes, plug back in, and then re-program.
3) Move timer to plug on different circuit breaker and see if same problem occurs.
4) If you have another kind of timer in the house, move it to same plug as problem-timer and see if different timer also looses time.
5) Use circuit analyzer to check if circuit has problem. Circuit problems will affect timer electronics.
6) If timer is clean and new-looking: buy another one from Lowes or Home Depot or Target and then return defective one in new package.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Mar 01, 2011 | Woods Outdoor 7 Day Digital Two Outlet...
I have a Heavy Duty Westinghouse 3-Outlet Outdoor Digital Photocell Timer and the time keeps running slow. Does the unit need sunlight to run the clock or do I need to change the internal battery? I have...
1) No the timer has internal rechargeable battery.
Battery is not replaceable.
2) I test timers, 4-6% arrive defective. Most go bad within few years. Some last long time.
3) If you set timer to turn ON at dusk, and turn OFF 2 hours later, then reflected light or car lights can give photoeye feedback so timer thinks it's light. Timer turns off and resets. I don't know if this information applies to you.
4) Link shows timer and manual for Westinghouse
5) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any
Jan 13, 2011 | Heavy Duty Westinghouse 3-Outlet Outdoor ...
The unit is programmed to come on at 5:00 p.m. and go off at 11:30 p.m. It was wooking but now the lights won't come on.
Three things can cause lights not to come on:
1) Timer has gone bad.
Try resetting and reprogramming timer. Make sure you have correct mode.
I test timers. 4-6% arrive defective and most quit within a year or two.
Some go bad within a month.
If display does not show, then check battery.
Most timers have internal rechargeable battery that is not replaceable.
When rechargeable battery goes dead, timer is bad.
2) Light bulb burned out or lamp turned OFF.
3) Receptacle has no power. Plug lamp in directly and see if bulb comes on.
To see manual:
Dec 21, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
