Lost all my channels. How do I manually add channels. Auto search only finds and saves one channel. I am on an indoor antenna. I have to adjust it between changes all the time. I wanted to add.
    Top Expert:
  • Televison & ... Master
  • 51,494 Answers
Find out what you need to do to get an outdoor antenna installed. I Like the ones that have 360 degree coverage . Like AntennaWeb org
Posted on Dec 04, 2016
I want to save the channels and turn my antenna to another direction and scan I loose the channels that I had can I save them some how?
The only way that I solve this issue is to write down the channels available from one direction on paper. Do the scan in the second direction. Return the antenna to the first direction and then manually add the rest of the channels. Depending on the TV, you either type in the channel number with the remote control or find a Add Channel option in the TV Channel sub-menu.
At least with my TV that doesn't have an Add Channel option in the Channel section, going to a digital channel with the remote doesn't store the channel number if the signal isn't strong enough for the tuner to resolve. Analog channels can be added when the signal is poor.
If you know all of the local channels in each direction from AntennaWeb ( http://www.antennaweb.org ) or TvFool
( http://www.tvfool.com ), you can use that documentation to add the channels at each antenna direction.
I hope this helps. If you use an electronic antenna rotor with a remote control, you may be able to program turning the antenna automatically when you change the channel. Check the documentation for the device to program this.
(Note: on my TV that adds channels only when I type in the channel number, recorded digital channels can disappear from the list if if I visit a channel with poor signal strength. Until the antenna is directed towards that transmitter, I can't add the channel back into the list.)
Nov 03, 2017 | Televison & Video
Lost ABC channels on retune, how do I regain reception
Try manually entering the channel number. Many TV's have, besides autoscan, a way to manually add or remove channels.
(Besides, what is worth watching on ABC? (;^D)
Oct 21, 2014 | Televison & Video
Cant retune through dvd player
Sounds like a few things going on here... Your indoor antenna for one is probably not making it easy for you as an outdoor antenna will work a whole lot better. This is why it open picks up half the channels and they are pixelating. Also you may have faulty rf leads. Replace these.
Feb 25, 2014 | LG Televison & Video
Model VR-4625 wont pick up any channels with auto scan
Look to see correctly hooked and that in the menu the set is now not set to catv or cable but to air/antenna. If no antenna connected to set or if just indoor antenna you may not pickup on auto search--try to direct enter a known channel with the remote--if you get one you can in the set menu manually add to the memory the set has.
Nov 06, 2012 | Westinghouse LTV-19w6 Television
How do I add the HD channels picked up my HD antenna to the master channel list on my Visio TV?
Hello, with the set on, press the menu button, move the cursor down till the "Tuner" section is hi-lighted, click on it. Then the first selection is "Tuner Mode" click on it, the choose "Antenna" click on it. Then move to the "Auto Channel Scan" and click on it, and let it set all your channels. when done, just exit menu and change channels as desired. you can go to page 39 in your manual for these instructions: Tuner Mode
Select Cable or Antenna depending
upon which equipment you have
attached to the DTV / TV Input.
Auto Channel Search
Automatically search for TV channels
that are available in your area. Be
sure to first select the correct tuner
mode above. The TV will search for
analog and digital channels. When the
search is done, press EXIT to begin
watching your programs. thanks, Terry
Oct 09, 2012 | Vizio M220NV 22 in. LCD TV
How do I retune my Panasonic Viera TV?
Hello
To tune your Panasonic Plasma to on air TV channels do the following:
Connect the antenna connection to its antenna in at the back panel.
Automatically searches and adds available channels to the memory.
Select "ANT in"
Select Cable or Antenna Select "Auto"
Select a scanning mode
Auto channel setup
Select "Auto program"
Select "ANT in"
Select "Auto"
Select scanning mode (ALL channels/Analog only/Digital only
Start scanning the channels
Available channels (analog/digital) are automatically set.
All channels: Scans digital and analog channels
Analog only: Scans Analog channels only
Digital only: Scans Digital channels only
Confirm registered channels
If OK is not pressed after selecting "Apply", the channels will not be saved.
The channel will be saved when no operation is performed for 60 seconds and
the "Manual program" menu will also exit automatically.
If you perform scanning more than twice, previously saved channels are erased.
About broadcasting systems
Analog (NTSC): Conventional broadcasting
Digital (ATSC): New programming that allows you to view more channels
featuring high-quality video and sound
[Use "UP ' DOWN ' RIGHT ' LEFT] AND 'OK"] keys to selcet and proceed.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
FixYa: Thank you for choosing to chat with an expert. FixYa: Please describe your Flat Panel Televisions problem in detail so we can match you with the best expert for your needs. I have got a TV...
You will not find any channels with this old TV. All channels in the USA switched to digital 1 1/2 years ago. You will need to connect a digital converter box to get any channels.
Feb 27, 2011 | Zenith SY2768S TV
I get no stations on my tv
Use an Antenna that Provides Good Reception of All Channels
  • Most existing antennas used by consumers will provide good reception of DTV signals. (Before making any changes, try your existing antenna first to see of it allows you to receive all the stations you normally watch.)
  • For watching DTV signals, you will need an antenna that provides good reception of both VHF signals (channels 2-13) and UHF signals (channels 14-51) to reliably receive all of the digital signals broadcast in your area.
  • Many antennas are designed only for reception of either VHF or UHF signals (but not both). For example, the commonly used “rabbit ears” indoor antenna is only suitable for receiving VHF signals. To receive UHF signals, an indoor antenna should also include a wire loop or other feature for reception in that band.
  • The reception capabilities of TV antennas also vary considerably, so be sure to talk to retail consultants and look at information on the packaging and/or the Internet to make sure that any new antenna you may choose provides good reception of both VHF and UHF channels. In addition, if you use an indoor antenna and receive signals on VHF channels, you may need to use an antenna with amplification.
  • Many antennas currently being sold as “HDTV Antennas,” perform best at receiving UHF signals; some of these models state that they provide reception of signals on channels 7-13 but actually perform less well receiving those channels. If you obtain one of these antennas, be sure it provides good reception of all the VHF channels as well as the UHF channels.
  • To check for the DTV signals that are available at your location, use the DTV Reception Maps available at www.fcc.gov/mb/engineering/maps.
Check Your Connections
  • Check that your digital-to-analog converter box or digital television is connected properly. Make sure your antenna is connected to the antenna input of your digital-to-analog converter box or digital television. If using a digital-to-analog converter box, also ensure that the antenna output of your converter box is connected to the antenna input of your analog TV. Refer to the owner’s manuals of your components if you are unsure of the proper connections.
  • Ensure that your components are plugged in and have their power turned on.
  • If you have a digital-to-analog converter box, tune your analog TV to channel 3. You should see a set-up menu or picture displayed on your TV screen. If you do not see a set-up menu or picture, tune your TV to channel 4. If you still do not see a set-up menu or picture, recheck your connections.
Perform a Channel Scan
  • Digital-to-analog converter boxes and digital televisions have a button, usually on the remote control, that is labeled “set-up” or “menu” or some similar term. Press that button to access the set-up menu. Using the directional arrow buttons on your remote, scroll to the option that allows you to perform a “channel scan.” The channel scan will automatically search for digital broadcast channels that are available in your area. Consult the owner’s manual of your digital-to-analog converter box or digital television for detailed instructions on how to perform a channel scan for your device.
  • Once the channel scan is complete, you will be able to tune to the digital channels received by your antenna. You should perform a channel scan periodically to check whether additional digital channels have become available.
Adjust Your Antenna
  • Small adjustments to your antenna can make a big difference in the number of digital channels you can receive. If you have an indoor antenna, try elevating it and moving it closer to an exterior wall of your home. After adjusting your antenna, perform another channel scan to see if your reception is improved.
  • While adjusting your antenna, it may be helpful to access the “signal strength meter” on your digital-to-analog converter box or digital television to determine whether your adjustments are improving the signals’ strength. The signal strength meter is usually accessed through the menu feature on your remote control. Refer to the owner’s manual of your device for detailed instructions on how to access its signal strength meter. Remember to do another channel scan after you have adjusted your antenna.
  • Television stations broadcasting in digital use both the VHF band (channels 2-13) and UHF band (channels 14-51). Many indoor antennas use “rabbit ears” for the VHF band and a “loop” or “bow-tie” antenna for the UHF band. Make sure you are using an antenna that covers both the VHF and UHF bands and have connected it properly.
If You are Still Having Difficulty:
  • Until June 12, 2009, some stations will be operating at reduced power levels. If you are not receiving certain digital TV stations, this does not necessarily mean there is a problem with your antenna or digital-to-analog converter box or digital television. Check with the TV station to find out whether they are planning changes that will improve reception.
  • When an analog TV signal is weak or receives interference, static, snow, and distortion will often appear on the screen. Digital broadcasting will provide a clear picture; however, if the signal falls below a certain minimum strength, the picture can disappear. This “cliff effect” means that if you watch analog TV stations that have static and distortion, you may have to adjust or upgrade your antenna system.
  • Simple indoor antennas provide minimal performance that may not be suitable for your location. If you are unable to obtain satisfactory DTV reception with your current indoor antenna, you may wish to obtain an indoor antenna that includes features for better reception of UHF signals, as well as VHF, and/or an amplifier to boost the received signal (often referred to as an active indoor antenna).
  • Generally, an outdoor antenna will get better reception than an indoor antenna. However, the performance of outdoor antennas can degrade over time due to exposure to the weather. If you are having problems, check for loose or corroded wiring, broken antenna elements and that the antenna is pointed in the right direction.
  • Try to keep the length of wire between your antenna and digital-to-analog converter box or digital television as short as possible for best reception.
  • “Splitters” that are used to connect a single antenna to multiple digital-to-analog converter boxes or digital televisions reduce the amount of signal available to each device. If you are having problems, check whether reception is improved without the splitter. In some cases an “active” splitter that includes an amplifier can solve the problem.
  • If you are near a station’s broadcast tower, reception of that station, as well as other stations, can be impeded by strong signal “overload.” Consider using an “attenuator” or removing amplifiers to improve your reception.
  • If you decide to replace or upgrade your indoor or outdoor antenna, many types are available from electronics retail stores at a variety of prices. Websites such as www.antennaweb.org provide information on the locations of broadcast towers and the types of outdoor antennas appropriate for the stations you wish to receive. If you need assistance with upgrading your antenna system, check with a local antenna retailer or antenna installer.
Hope it may helps:
Regards:
VOTIT
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
No channels on list
You have to search for the channels. Go to your setup menu, and go to setup, then select TV, then do auto channel search. It may or may not have to be set on tuner to get to the TV options.
Jun 30, 2008 | Olevia LT32HVM 32 in. LCD Television
Channels only up to 20
unfortuatly not your gonna need to get an original remote from http://www.vcrremotecontrols.com and the part # for zenith is 924-10042 and cost 29.95 + shipping.good luck
Apr 12, 2006 | Zenith ALG4010 VHS VCR
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
