Question about Sanyo Televison & Video
Sanyo tv model dp42848.want power on,no power light.after having it plugged in for30 min. light comes on,a clicking starts.screen comes on follows the clicking flashing on and off.Have to unplug it
    Habit-Forming:
  • 107 Answers
Either the circuit board has over heated and fried itself, or your digitizer is malfunctioning. Either way it is time for a new TV sadly, TV repair is very expensive, and Sanyo is a cheap brand, you can buy a new TV for the cost of fixing it, or if its still under warranty get a new one. Good Luck!
Posted on Dec 04, 2016
  • 208 Answers
SOURCE: Red Light Flashing 6 times
When the lamp fails in this unit, often the thermal fuse opens. The error code is 6 blinks. To replace this part requires a great deal of deal of disassembly.
Posted on Mar 29, 2008
ginko
  • 19396 Answers
SOURCE: HITATCHI ULTRAVISION P50S601...POWER LIGHT BLINKING...WONT COME O
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
  • 6 Answers
SOURCE: I have a Samsung 52
easy fix. check here: http://www.earthinfo.org/samsung-tv-makes-a-strange-clicking-sound/
Posted on Sep 01, 2009
  • 6 Answers
SOURCE: Sanyo Vizon 42" Plasma DP42746 Was
This is a common problem with these TVs. You can download the official Sanyo repair manual for this TV (DP42746) at http://www.eserviceinfo.com/downloadsm/43343/sanyo_dp42746.html. I uploaded it here when I had the same issue with my TV last year. The solution is almost always to replace the Power Board (Y-Main) and the Upper and Lower Y Buffers. The parts and costs (from Sanyo in July 2009) are listed below (NOTE: Sanyo will not ship these parts to anyone but a repair shop): 1. V4 Y-Main (Y-Sustain) Circuit Board (Part # LJ92-01200A, Alt Part # LJ41-02759A) - USD $139.00
2. Upper Y-Buffer Circuit Board (Part # LJ92-01202A, Alt Part # LJ41-02760) - USD $64.00
3. Lower Y-Buffer Circuit Board (Part # LJ92-01203A, Alt Part # LJ41-02761A) - USD $64.00
Sanyo charges USD $10.50 for shipping, which brings the total cost for parts to USD $277.50. From my research, a shop would probably charge between USD $500 and $700 to do this repair. FYI - there is a class action lawsuit pending against Sanyo for this issue. The V4 Y-Main (Y-Sustain) Circuit Boards fail VERY frequently in this TV due to overheating. Hope this helps.
Posted on Aug 07, 2010
SOURCE: sanyo model DP42848 pic comes
Mine has been donig the same thing.
If the TV is left on a screenshot of some sort, it makes a loud beeping noise and then shuts itself off.
Not sure what to do.
Posted on Jan 14, 2011
Sanyo dp42848 black spots and scrambled screen
Black spot means the LCD panel is faulty. Its better to go for new tv than rearing this one.
www.electro-medical.blogspot.com
Oct 07, 2015 | Sanyo DP42848 LCD TV
No picture Sanyo dp42848
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Sep 08, 2014 | Sanyo DP42848 LCD TV
Tv started screeching then screen went black volume and channels ok
Sounds like this:
http://www.coppelltvrepair.com/p/428/sanyo-dp42848-p42848-00-backlight-inverters-replacement-for-dark-screen-no-image-problem
Of course your TV model may be different and the inverters may be different...but the description points to the same problem.
Aug 15, 2013 | Sanyo 42 in. LCD TV
Sanyo dp42848 turns on but blank screen
Replace the Main board if your not hearing any audio from the set.
Oct 27, 2012 | Sanyo DP42848 LCD TV
PICTURE CUTS OFF AFTER A FEW SECONDS
the inverter is the usual cause of that issue. You can get the replacement Inverter from www.tvrepairworld.com
Aug 23, 2012 | Sanyo DP42848 LCD TV
Lightening struck 25 yards from our home, power whent out for afew seconds, the tv will not come on. the power green light comes on for 15 seconds then goes out..no sound or picture Sanyo DP42848 LCD...
power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hoping that this will help out in solving the problem
Sep 11, 2011 | Sanyo DP42848 LCD TV
I have a sanyo model #dp42848 and when i turn it on the picture comes on for a few seconds then you hear a noise the the picture goes out. The sounds still works. What could this be and how much will it...
Hi art_davis,
Power on the unit in the dark room then shine with the flashlight directly in the screen, you will barely see the images. This is because your backlight is not functioning. The following reason was the caused.
1. Power supply - missing B+(supply voltage) coming from this board feeding the inverter board. This is caused by faulty transistor, dried/leaky electrolytic capacitor, open fusible resistor.
2. Inverter board - even the B+ is good from the power supply, if the fuse, driver transistor, driver transformer is faulty no output to the backlight resulting to black picture.
3. Busted backlight - even inverter board is good but if this is busted resulting to black picture also.
Check the parts here.
Diagnosing the fault is technical and if you don't have necessary tools and test instrument and can't fix it yourself, I would advice you to look for an experienced technician to isolate the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Apr 02, 2011 | Sanyo DP42848 LCD TV
My Sanyo DP42848 has audio but no picture. How can I fix it?
i turn my sanyo on and its all good for a few seconds then i loose picture but still have sound ,,whats wrong?
Jan 21, 2011 | Sanyo DP42848 LCD TV
Televison & Video Logo
29 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
