Question about Pool & Spa
I just installed a new aqua link rs8 pcb and temp sensor. The heat is set at 104,initially it reached 102 at the water,read 104 on the one touch and as it continued would only reach 100.
5 Suggested Answers
  • 990 Answers
SOURCE: spa heater will only reach 100 degrees unit should
This is in your temp sensor or in the well that holds it. The temp sensor is easy enough to replace in most heaters. If you have a mineral build up on the well you would need a pro to do this and you need to address the cause of this. This will be the long shot problem and the temp probe is more likley the problem. I could give you instructions but no heater brand or model and no info on in spa or out of spa or style of control. Good luck.
Posted on Dec 03, 2009
  • 44 Answers
SOURCE: the display on the Jandy
If you replace the sensor and get the same code,there is only one option before replacing the board...This only works on a board with one (4 pin ) red connector terminal. If you have two it won't work. On the back of the board, directly behind the "air temp" wire terminals, there is a small black diode with a silver stripe.This is a redundant circuit and isn't necessary. AFTER you turn off the power to the board, you can cut this diode off with some dykes.
Posted on Sep 30, 2010
Testimonial: "Thank you Sir!!!! It worked!!! I owe you a beer Sir."
UglyPoolGuy
  • 46 Answers
SOURCE: have pentair easy touch controls just installed
If the Easy Touch is reading the correct temperature, but the heater is not - you need to double check the temperature of the pool water with a standard pool thermometer.
Other things to consider:
1) The water is traveling too slowly through the heater. If the water is heating too quickly, then it will shut it off. If it takes a while for this to occur, then this would not be the issue.
2) Thermostat/thermistor is incorrectly reading the temperature of the water prematurely shutting the system down.
Make sure you really are checking the temperature of the water and matching this temperature up with one of the two readings that you are getting. Don't just take the word of the displays on either unit.
Posted on Dec 10, 2010
  • 990 Answers
SOURCE: Have a Jacuzzi self contained
Check your power through the heater. It sounds like your getting 110v to the element instead of 220v.
Posted on Dec 24, 2010
Just installed new rs8pcb and temp sensor. Set at 104,only reaches 102, why?
Try calibrating your Jandy controller to the temperature of the heater. Temp sensor could be off by two degrees
Dec 04, 2016 | Pool & Spa
Jamdy RS Shuts off heater too soon
when using the aqualink make sure heater is in tstat mode if not for your heater then turn heater all the way up make sure the wires are connected to pool and com then make sure the wires 5and 6 are connected to the heater then the aqualink will command heat if the red light is lit on controller
Feb 10, 2014 | Jandy 7953 AquaLink RS One Touch Control...
Er3 flashes hot water will not reach set point
Had this happen to me before, if you have hot water from the boiler going in and out of the boiler mate and the temps are not rising within the hot water means more than likely you may need to remove exchanger and clean sediment off element, basically sediment creates a blanket over the heat source causing poor thermal conductivity. Things to check before removing heat exchanger
- outlet temp of boiler water to aquamate -inlet temp of boiler water to aqua mate= 20-30'F if low then bad thermal transfer or poor water movement
-make sure sensor is reading properly
- get boiler temp higher to speed up thermal gain in water heater
Jan 19, 2014 | Amtrol 2704E76 41 Gallon WH-7C BoilerMate...
Heats to only 72 degrees
make sure heater is set to 104 degrees aqua link controls temp
Jan 03, 2014 | Jandy Laars LX Pool Heater / 400,000 BTU /...
I have an Aqualink system, spa set to 104, it will heat to 94 and stay there, temp sensor is working, took water sensor out of line, plugged line, assumed heater would just keep heating, it did heat a
The heater may be wired just fine. The aqualink uses its water temp sensor to call for heat based on what you've set the thermostat to on the aqualink. However, most heaters have built in thermostats that over-ride the aqualink. Those thermostats come factory defaulted not to go over 94. Check your heaters manual on how to adjust the thermostat on the heater. Your heater should have its thermostats set to 104 and the aqualink will control the actual temp of the water by calling for heat based on what you've set the thermostat on the aqualink for. Hope this helps.
Oct 16, 2012 | Jandy Aqualink Rs4 One Touch Control...
Have pentair easy touch controls just installed new water temp sensor. spa is 88 degrees but master temp heater shuts off because it reads 104. what should i check? the thermistor/
Dec 10, 2010 | Pentair Mastertemp Heater
SPA WILL NOT HEAT PAST 94 DEGREES. i HAVE IT SET TO 103 AND IT HAS NOT MOVED PAST 94 DEGREES FOR OVER 1 HOUR EXACTLY WHAT BUTTONS SHOULD BE LIT ? IN OTHER WORDS IS THE AIR BLOWER LIGHT SUPPOSED TO BE...
if hook up to the firemans switch turn heater all the way to 104 degrees if using 4 pin connector for aqua link to heater set spa temp to 104 and make sure on aqualink spa heat is enabled and 104 degrees
Nov 30, 2010 | Jandy Aqualink Rs4 One Touch Control...
Hot tub heats from 85 to 98, then E05 message. Max setting is 104. It's run for 2 years with no issues getting to 102-104. I have the Pentair manual, troubleshooting chart, but wanted to see if anyone had...
Could be the temp sensor about 50-60 bucks, the book will say the board about 350-500 bucks. Try the temp sensor first. If it's reading over what the water is then that is probally the problem.
Jun 27, 2010 | Pentair Mastertemp Pool & Spa Heater Dual...
Pool & Spa Logo
118 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
