Working on a Rheem 90+ gas fired furnace with A/C. Replaed the 24vac fuse twice now. Unit runs 1-3 days then blows the fuse. Thoughts?
  • Ken Bledsoe May 11, 2010
    Is your unit in the cooling mode? And if it is trace down the wires that go outside to the unit trace the thermostat wire we call it two wire. Now look for a bare place where the wires could be touching each other. If you find a place either wrap some electrical tape around it or just cut out the wire and replace from that point on to the condenser. If you need any further help just ask and will help you out.
    Problem Solver:
  • 17 Answers
Could be a couple of things check the low voltage wiring going from the furnace to the outside unit. It will look like a small telephone wire. Sometimes rodents like to chew this wire and it can cause a short which will blow the small fuse.
Posted on Jul 21, 2009
How do i prime the water trap on a rheem classic 90
This trap will fill itself up when the furnace runs for the first time. It does not need to be primed to make it work. If you have the drain end above another p trapped drain.
Oct 28, 2014 | Rheem Classic Series 90%...
On occasion, my furnace will not kick on at
If your Rheem furnace is less than 10 years old, it may store an error code to help you figure out if it is the furnace or the thermostat. Look at the circuit board for a blinking light. If you have to remove the panel that opens up the door safety switch, it will erase the code. Look for a small viewing port. Next time the furnace fails, prior to doing all the things you did last time, look thru the viewing port to count the number of blinks. Once you get the number, open the cabinet and on the wiring diagram glued to the back of one of the panels'\; there will also be an error code chart. It may give you a starting point where to look. If you have no error code, chances are that your thermostat is freaking out or has a bad connection. Hope this helps.
Dec 28, 2009 | Honeywell CT3200 5-2 Day Electronic...
My goodman gas furnace is not kicking on. the light on the unit is saying that it should be working but it is not. there is no pilot light, the fan is working the heat is not
If you are not getting any codes from the board, then the furnace is not getting a call for heat from the thermostat. A wire may have come off, the thermostat not properly wired, or a break in the stat wire. On a call for heat, you should have 24vac between W and C on the circuit board. This will let you know if you are getting a call for heat all the way back to the furnace.
Oct 01, 2009 | Goodman GMS90703BXA Heater
Rheem gas furnace blower unit not working properly
look at circuit board and follow wires that come from fan motor, if this is a standard motor black is high and it will be going to a prong that says cool, red is low and it will go to heat, you will have a yellow and a blue that are "parked" remove red park it were the blue is and put blue on heat, if this is a variable speed motor you will have to set dip switches via your equipment manual
Sep 29, 2009 | Heating & Cooling
24v wiring for RHEEM heat pump
Brown wire connect to com C on terminal block in your furnance (0VAC from 24VAC transformer)
Yellow turn on compresor (hot wire from 24VAC Transfrormer)
Blue switch Valve from AC to Heat (hot wire from 24VAC Transfrormer)
Purple prevent starting compressor in Heat pump and furnace in same time
Jul 02, 2009 | Ruud UBHC Air Conditioner
Fan and compressor will not run
Try replacing the fuses for the condensor.
Apr 24, 2009 | Goodman CKL36AR36 Air Conditioner
Blowing 3amp fuses
You have a low voltage short. A lot of low voltage shorts come from the wires that go out to the outdoor unit. Go outside and inspect those wires and that they are in good condition. Also check for any splices in those wires that they haven't degraded in any way. This is the only thing that will blow the fuse. That's why it's only 3 amps and based on the size of your fuse, it's a gas fired unit right? Have a great day!
Apr 10, 2009 | Ruud UBHC Air Conditioner
Goodman forced air gas furnace not firing
if your power vent moter is not running you should not have have glowing ignitor.Frist the vent moter must close an air prove switch in series with the idnitor .seems you have a stuck air prove switch.Its the one with a hose attached
Apr 04, 2009 | Heating & Cooling
Heating & Cooling Logo
124 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
