What size armature brushes are needed for Norleco 4401LC? I found 5mm x 2mm x 2mm on Amazon. Will these fit?
4 Suggested Answers
b0sslady2001
  • 357 Answers
SOURCE: Good armature maybe needs new brushes
Carbon brushes wear over time and may need completely replaced...it doesn't cost a lot and i have guides available for the repair. Try my troubleshooting guide....
http://reviews.ebay.com/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING_W0QQugidZ10000000003800312
I have the brushes available as well. The changing process is also outlined in my guide for changing the power switch.
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
Hope this helps...
Marci
Posted on Apr 21, 2008
snor38
  • 118 Answers
SOURCE: bad arcing were brushs
From snor38@gmail.com Hi dkhallquist. When you cleaned the comuntator did you carfully clean the groves as they may have enough trash to make the brushes ride roughly on the comuntator.
Posted on Jul 01, 2011
jmgldsmth
  • 2005 Answers
SOURCE: I replaced armature, bearings and brushes. The brush/armature contact seems to have excessive blue sparking. What now?
replace or recondition the worn armature in your motor that the buushes rub on
Posted on Feb 18, 2013
Replacement carbon brushes Ryobi AG402 angle grinder
You can purchase replacement carbon brushes on amazon Amazon com Ryobi carbon brushes. I hope this was helpful. cheers
Jul 12, 2013 | Saws
Machine not spinning although draining
hi does your machine turn on wash cycle if not your motor brushers need to be looked they may have worn down and are not connecting with the armature or they may be stuck remove the motor and you will see two plastic brush holders each side of the armature undue the two screws on each one they then pop off ythey should be about 25 mm long and not soter thah 5mm and shinny on the ends try this first any more help let me no you can buy new brushes on line euro spares just type in your make model no
Nov 12, 2011 | Washing Machines
There are sparks coming from the motor, is this because the brushes are worn
This is probably the reason or the armature is worn.
You need to remove the motor and check the brushes, replace them if less than 3-5mm long.
Jan 22, 2011 | Hotpoint WMA40 Front Load Washer
Washing machine tripping out house electrics on fast spin
Could be worn brushes in the motor causing the problem I would remove the moter and check the brushes, replace if less than 4 or 5mm long, and clean the armature at the same time.
Dec 07, 2010 | Bosch Washing Machines
I need to find an Eyepiece for my grandsons TeleStar 60AZ-A
Most telescopes use a standard size for eyepieces (one and a quarter inches outside diameter) and if that is the size of the mount in your scope, you can use any that fit. If you do a search on Amazon, you will find hundreds in this size, many of them branded Meade. The other dimension specified will be focal length. 5mm will give high magnification (but dimmer and harder to use) while 20mm will give lower magnification with brighter image and less fiddly focus.
Nov 15, 2010 | Meade TeleStar 60AZ-A Telescope
I need new brushes for Powermate Air Compressor motor. Where can I purchase them or do I need to have a Technician install? Model #CL0551109 Thank You J.L. Brooks
Brushes are not listed as a replacement part for your compressor. Not to worry because universal brushes are available at tool repair shops, hardware stores and ebay. Measure your brush and order same size or slightly larger and sand to fit. Dont worry too much about the length of brush as they can be shorter than factory and still work fine (just longer than worn brushes). Some motors have a spring pushing brush onto armature and others utilize the spring attached to brush to make contact. You can cut off wire from back of brush if needed, however if your motor needs brushes with spring attached, find close match and solder your old contact and spring to new brush. Also check for other problems because brushes should last the life of motor on your unit. Good luck
Aug 17, 2010 | Coleman Powermate 27 Gallon Air Compressor
Motor on mod 51591 died, nedd replacement
The Mamco motor is WAY too much money.I bought brushes on E Bay and made them fit. #51591 takes 1/4 " square brushes.
Nov 28, 2009 | Toro Blowers Rake and Vac - Electric...
Installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Bosch WFK 2401
Washing Machines Logo
Top Washing Machines Experts
