Question about Ryobi Garden
40cc ryobi chainsaw is overheating? - Ryobi Garden
    Top Expert:
  • Ryobi Master
  • 49,277 Answers
Blocked exhaust system, not correct oil/fuel ratio mix, dirty /blocked air cooling fins around the cylinder /head from saw dust
Posted on Dec 04, 2016
  • 2692 Answers
SOURCE: Ryobi 40cc CHAINSAW .... pulled out cord too far
It is usually just jammed, when you go out too far. Ifyou take the recoil starter off or loose , sometimes it goes back in on it own. If not ,carefully disassemble it and see if the recoil spring is broken.
Posted on Mar 18, 2009
dontbother10
  • 2220 Answers
SOURCE: ryobi 40cc chainsaw
Have you checked for spark? Sounds as though your ignition module has quit.
Remove the plug, connect a jumper wire between the threaded part of the plug and the cooling fins, Switch the ignition on, take it into a dark room and pull the starter. You should see a spark at the tip of the plug. HTH
Lou
Posted on Sep 17, 2009
rwvanlue
  • 486 Answers
SOURCE: ryobi 40cc chainsaw chain oiler function not
1) check oil supply holes in the bar
2) With the bar removed, run the engine for 30 seconds, does oil come out of the side of the saw.
3) If no oil on the side of the saw, inspect the clutch drive spring and worm gear on oil pump shaft
Outboard drums (drums on the outside of the clutch) are held on by a nut or e-clip.
Inboard drums are held on by the clutch which is threaded onto the crankshaft. And there is the challange.
***NOTE all chain saw clutches have LEFT hand threads, so, rightey loosey, lefty tightey. (just backwards from everything else)
*** NOTE #2: DO NOT USE AN IMPACT GUN
this will most certainly shear the flywheel key or damage the flywheel !!!!! (after 35 years, you can ask me how I know that, LOL)
1) Use a piston stop to hold piston from moving: THIS IS A MUST !!!
Ok, so you do not have one, let's make one.
a) remove the spark plug
b) insert a piece of recoil rope into the cylinder hole, leaving a tail to remove it by. (rope, large shoe string, anything that is soft, that is aprox 1/4 to 5/16 in diameter to place into the spark plug hole to help the piston to stop it's travel by filling up the empty space. Just make sure you can remove it later)
c) secure the saw (extra set of hands may be needed) and with a suitable wrench on the clutch center, rotate the clutch to the right until piston comes to a stop. With a hammer, tap the wrench to aid in rotation. This can be very difficult, and may take several taps.
d) after removed, inspect and grease the drum bearing before re-assemlby.
e) upon re-assembly of clutch, tighten by hand only, NO hammer required. The force of the chain will tighten the clutch.
f) remove the rope, and re-install the spark plug.
Posted on Nov 16, 2009
  • 4088 Answers
SOURCE: my ryobi 40cc chainsaw wont start, spark at plug
'No compression' usually means serious mechanical problems with the piston/rings, but if this unit has a compression release, then it may be 'set' which reduces compression considerably until the engine fires. Try putting some fuel mix into the cylinder head spark plug hole and reinstall the plug. If it runs for a few seconds, then look into the fuel delivery system (did the compression increase?). Check that the carburetor is bolted tightly to the engine and the fuel lines are intact. Make sure the choke will close all the way and the throttle opens all the way. Make sure that the primer bulb fills with fuel after several pumps. Assuming that the engine ran properly for the people that 'reconditioned' the saw, this unit should not be giving you problems like this.
Posted on Dec 31, 2009
  • 4088 Answers
SOURCE: chainsaw wont start. new plug has a little spark.
The engine case needs to be removed to expose the flywheel and ignition module. Check the module pole gap to the flywheel magnets with a thin business card for a gauge. If the gap is excessive, that can give a weak spark. If the gap appears to be correct, then it is probably time for a new ignition module. Make sure the spark plug is gapped at 0.020" before condemning the module. The spark should be blue and snappy. Check it in a dark area. Hope this helps!
Posted on Apr 17, 2010
What gap should I have ona champion RCJ6Y spark plug for a RYOBI RCS4040CA chainsaw? (40CC).
you should be Googling this yourself, check the model number on the spark plug then google the spec or "spark gap".... that would've been quicker than asking this question.
Aug 26, 2017 | Ryobi Garden
Parts diagrams
We call that a duck bill vavle. You may have to buy fuel cap for it. The Home Depot should be able to help you with that. Or you can call Ryobi, I think they will sell you one direct
Sep 02, 2014 | Ryobi RCS4040CA 40cc Petrol Chainsaw...
Chainsaw makes a clattering noise
Is the exhaust tight? Is the chainsaw louder than normal?
Sep 25, 2013 | Ryobi Factory Reconditioned 18" 40cc...
Fuel/oil ratio for ryobi ry10532 chain saw
The fuel Ration is 50:1
I have included a link to the owners manual if you need it
http://www.ryobitools.com/product_promotion/discontinued_manuals/chainsaws/RY10532_867_eng_00.pdf
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Thanks for using Fixya.
Jul 01, 2011 | Ryobi Factory Reconditioned 18" 40cc...
Hi there,i m looking for 16"chain ryobi 40cc chain saw
Take your saw or old chain to a shop that works on small motors and they can make one . Take it to lowes and try one of theirs. They have them to fit any brand saw. Sears, Home Depot or a small hardware store.
Apr 20, 2010 | Ryobi Factory Reconditioned 18" 40cc...
Have The split cylinders in the Ryobi RY10532 40cc chainsaws caused grinding problems?
check chain sprocket take a rag over chain and pull it around should be smooth rolling also check nose of bar there are rollers check them out lota sawdust can build up behind clutch/sprocket
Apr 08, 2010 | Ryobi Factory Reconditioned 18" 40cc...
Ryobi 40cc chain saw, pull cord won't turn engine
If it has ball bearings in the rachet mechanism they may be sticking and need cleaning so they move freely.!
Aug 14, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Garden Logo
61 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
