How to setup the internet connect - Computers & Internet
  • Brett Duxbury
    Brett Duxbury Dec 04, 2016
    Hi Harlene Doud, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
How to setup tp-link TL-MR3220 on xp2002?
Connect the router's WAN port to your cable-modem.
Connect the computer to one of the LAN ports.
No other "setup" is needed.
Apr 29, 2014 | D-Link AirPlus DI-524 Wireless Router
It was working fine until ive reset my linksys wrt54g, and i did my setup again, but i dont get any internet connection, my linksys is using a cable to my pc. please help
When you resetted your linksys router, chances are, the setup for WAN connection was lost. You can try these steps:
1. Connect the internet directly to your pc. If your pc was able to browse the internet, move on to the next step. If not, you'll have to contact your ISP for the settings of your internet connectivity.
2. Connect back the internet to the WAN port of the router, and connect your pc to the router's LAN port.
3. Open the router's page in a browser (the address usually is 192.168.1.1, username is admin and password is admin)
4. If your router has a setup wizard, run the setup wizard, because it usually clones your pc's mac address.
Hope this helps.
Mar 06, 2011 | Linksys Wireless-G WRT54G Router
I am trying to setup a internet connection using yahoo what do i do
Sir,only using yahoo connection it will not provide to setup internet connection.
For internet connection you have to configure all the component which provides you to connect with internet.
These configuration requires LAN card,LAN driver,modem,NIC card,phone and internet service provider to assist the internet to activate the internet.
Apr 12, 2010 | Computers & Internet
Internet explorer is not working properly
di u setup the connection ?
else do this..
open Explorer..in the menu Tools/internet options/Connection Tab/
next u can either setup the new connection or if ur using a broadband/DSL cable and connect using a LAN port check the Lan setting at the botton of that window
if u want to use setup option
click Setup/Next/Connect to Internet/Setup my Connection Manually/Conenct using my boradband connection that's always on....
if u want to use LAN setting do this
Click LANsetting/Check the box "Automatically detect setting"
OK
Let's c if this works else we will work on some other solution...
Dec 20, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
Computer repair tech said Linskey wireless caused internet prob
If you are using DSL as your internet connection there is a timeout period that could be setup in the linksys.
In order to change this you need to log into your router and on check on the setup page. You see the timeout option.
Check with your linksys manual for detailed instructions for logging into the unit. If you dont have it, you can always get it from their website.
Jul 31, 2009 | Linksys Wireless-G Broadband Router
Router not seeing internet connection
If you are on cable internet, you need to perform MAC Address Cloning. Access the router's setup page using your main PC, under SETUP tab, there's a sub-tab called MAC Address Clone. Enable that and click on "Clone My PC's MAC" then click on Save Settings. Power cycle the router and the modem. You should be online after that.
Jun 09, 2009 | Linksys Wireless-G WRT54G Router
Internet connection issue. Is it setup or internet service
The problem would be comcast. Your connections are setup correctly. The modems do not control the internet traffic flow, they are made to produce maximum flow.
If more people use the internet, the less flow it will have.
Check all internet options settings, and make sure EVERTHING is set to automatic
Jun 06, 2009 | Arris SURFboard SB5120 Modem
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
