Question about Dryers
Replacing ceiling fanlight combo with regu,lar light fixture with 2 way switches...have a red black and white with grd in the ceiling box...how do i wire the light to the wiring
    Top Expert:
  • Dryers Master
  • 49,314 Answers
Playing with power is not a job for diy people as it causes fires and deaths
call an electrician and have it fixed in short time and have the job done safely and properly
Posted on Dec 04, 2016
Hunter ceiling fan/light unit install with 3 pole switches. there are 2 white, 2 black and one orange wires coming out of the electrical box. How do i handle the installation?
Not understanding, three pole switch is a wrong switch, wires in the ceiling or wall electric box.
Needed: What switch is existing and what wires are in the switch box and runs or groups in each run coming in as wire groups. Same for ceiling box, colors and wires in each run coming in.
Basically, remove the existing ceiling fixture and connect the ceiling fan replacing the fixture to the same wires the fixture was connected to. White to white, green or bare to green or bare, colored wire to fan's blue and black. Wired like this one switch controls both fan and light, on and off at same time. Use fan pull chain switch for individual fan or light control.
Oct 22, 2017 | Hunter Dryers
Why is the light switch not working after i have wired up ceiling light
check to make sure you have all the white (neutral wires connected as well as the wire to the fixture. Make sure both wires from the fixture are connected to the wires in the light outlet box. White to white(maybe more than 1 in the light box) to the white (common) of the fixture an a different color (usually black or red) to the black from the fixture. Connect ground to ground wire or metal box. Turn the circuit breaker back on, if you turned it off, and turn on the switch. If this doesn't help it is time to get someone who can operate a multi-meter and understands electrical troubleshooting.
Jun 28, 2014 | Electrical Supplies
Electrical/wiring for a pendant fixture
white - nuetral
black - zap the junk out of you positive
if you can test continuity then test for source power, check both black wires and the red. the white wire better be neutral
set your volt ohm meter to 200 VAC if you have a cheap dial one or if you have a nice auto range one, set it to AC volts and test. red to the three wires, black lead on white...
Dec 29, 2013 | Dryers
I have a single pole switch that currently controls a bedroom outlet. i am installing a fan and light in the bedroom. i have a new triple switch that i want to control the existing outlet, the fan and the...
Wiring is not fully described: Location of hot wire and neutral wire from breaker box are unknown.
If Hot wire arrives in ceiling box first, the switch box will not have white neutral wires that are twisted together and covered with wire nut. Neutrals will be in ceiling box.
What is known: You are replacing single pole switch attached to one 14-2 wire going to light.
You are replacing light with a fan-light and replacing switch with a 3-pole TM8111 switch.
You have replaced 14-2 wire with 12-3 wire.
TM8111 wiring shows following link:
http://waterheatertimer.org/images/TM8111-switch-wiring-500.jpg
Fan pull-chain wiring shows following link:
http://waterheatertimer.org/images/Fan-motor-1-344.jpg
Assume neutrals in ceiling box.
Assume Hot wire in ceiling box: Connect 12-3 black wire to black Hot wire. Connect 12-3 white wire to black wire on light. Connect 12-3 red to red wire on fan.
White neutral from fan and white neutral form light connect to other white neutral wires and covered with wire nut.
Wiring at switch:
Black Hot wire from ceiling box connects to A COM terminal.
White wire to ceiling light connects to A SP2
Red wire to fan connects to A SP1
Jun 21, 2011 | Pass & Seymour Legrand TM8111 Three Single...
How to wire this fan
The wiring on most paddle / ceiling fans id such:
White = Fan and Light neutral or "common"
Black = Fan line voltage or "hot"
Blue = Light line voltage or "hot"
Green = safety ground
If you are replacing an existing light fixture - be sure to replace the ceiling box with one designed for use with a fan - as per electrical code. If the existing box had only 2 wires (or 3 counting the ground) that connected to the old light fixture and it was controlled from a wall switch, the wiring would be fixture white to ceiling white, fixture black and fixture blue to ceiling black (or red) and fixture green to ceiling bare ground or connected to the metal box. This would power both the fan and light whenever the wall switch was on and the pull chains for each were also on. This is also the preferred wiring for replacement of a pull chain type light fixture (no wall switch present).
If there are other wires in the box that previously were not connected to the old light fixture, using a meter or tester - determine if there is constant power between the ceiling white wire and any of the these other wires (test with the wall switch on and off to be sure). If you do have constant power available, you might consider using the wall switch to control only the light, and using the pull chain to operate the fan (or vice-versa). Simply connect the black (for fan) or the blue (for light) to the "constant power on" wire and that part of the fixture will work by pull chain only - regardless of the wall switch position. If the fan can be shut off by the wall switch, it is very important that the wall switch remain a toggle (or on / off switch), do NOT replace with a dimmer type switch.
If you'd prefer to operate the fan and light completely independently of each other - you can purchase a 3rd party fan & light remote control device for between $30 - $50.
I hope this helps and good luck! Please rate my reply. Thanks!
Apr 22, 2011 | Aloha Housewares (93645) Ceiling Fan
I believe my power source is in the ceiling. I just want to wire a light but use a leviton switch and dimmer at the wall. Can't figure this one out. Can you help. There are two red wires, one black and...
Question needs more details. Let me answer as if you have one light and one switch, and one cable coming into switch box from ceiling.
Usually a switch-dimmer combo operates 2 different Loads (lights).
One light is controlled by switch, other by dimmer.
If power source is in ceiling, then one cable enters switch box.
Cable has black, white and ground wires
Old switch had 2 brass screws where black and white wires connect
Black wire brings Hot down from ceiling, and white wire connects back to Load (fan).
Neutral wires are in ceiling box, and not inside switch box, and are discussed.
With new dimmer: Black Hot wire from ceiling connects to dimmer black wire.
White Load wire connects to one of the red wires.
The other red wire goes to another Load, which is unknown at this point.
Add a comment for more free help. Say what cables and wires enter box, and what Loads you are controlling. Also add exact model number so expert can reference manual. Levition instruction sheets and manuals usually have toll free number.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail or phone while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 22, 2011 | Leviton MFG L00-IPI06-1LM DIMMER SLIDE...
I want to mount a simple ceiling light. The electrician used a 3-way cable (white, black, red and ground) because initially we wanted to mount a ceiling fan with light. I tried to hook up the fixture,...
The red wire is probably the switched leg to the light.. You can verify this by turning the power to the circuit OFF at the circuit breaker, then pull the switch from the box. Post back if you need more assistance.
Jan 17, 2011 | Hardware & Accessories
Need to find out how to hook up a toggle switch/outlet
You can't, not without running an additional wire. The black and white pair of wires that you have is most likely routed from the ceiling fixture. The black wire would be the hot wire coming to the switch and the white is the switched hot wire returning to the fixture. You don't have a neutral available at this location, so you can't make the outlet work, just the switch. ----- Sorry for the bad news. Thanks for using fixya. Al Kupchella
Apr 30, 2010 | Pass & Seymour #681ICC6 15A Ivory...
Replacing a ceiling fan pull chain light switch.
that is strange
normally a 3 wire switch could only be able to control 2 things + off. black would be common, red would be one fan speed or set of lights and blue would be the other fan speed or set of lights.
if it is a replacement, couldn't you just hook it up like the switch you are removing?
most likely the black wires are grounds for everything and white would be power. hook it up however you like. white power would hook up to the black wire on the switch and then the blue to one light and red to the other set of lights white wires.
good luck!
Jan 06, 2010 | Westwind Classic Hugger Polished Brass 52"...
Light will not shut off on fixture (replacement of ceiling fan)
One of the two cables in the ceiling box is power and the opther is a switch leg .. what you need to do is connect the two black wires together at the ceiling, connect the white power wire to the white fixture wire ,.,. connect the white switch wire to the black fixture wire .. put some black tape on that white to make it legal .
Sep 27, 2009 | Hampton Bay 52 In. Black Huntington III...
Dryers Logo
Top Dryers Experts
