Have a Phillips flat screen TV has sound has lines but sometimes u can see color kinda reminds me of a vcr trying to fix picture need help trying to find out whats wrong
abhishek33
  • 1239 Answers
SOURCE: lines running vertical that appear to be red
hi
it is colour wheel problem,,,check it
please rate it..
thank u....
Posted on Jul 04, 2009
Slinteriors
  • 8617 Answers
SOURCE: Phillips HDTV Projection TV. Colors don't line up create shadow
yes sounds like a convergence issue. The following link has convergence repair kits which contain the parts and a cd with instructions on how to do the repair.
http://www.tvrepairkits.net/
Posted on Jul 10, 2009
SOURCE: Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Posted on Sep 21, 2009
promo7uk
  • 19 Answers
SOURCE: rainbow lines and no picture
NEW YSUS AND BUFFER BOARDS ARE NOW NEEDED THE YSUS IS THE BIG BOARD IN THERE VERY LEFT HAND SIDE ONCE BACK IS OFF BIG BOARD WITH 1 BIG HEATSINK,, THAT AND THE BUFFER BOARD PUSHES INTO THAT WITH TWO BLACK CONNECTION TO THE YSUS REMOVE BOTH BUFFER IS FIDDLEY,,NEED TO REMOVE 4 RIBBON CABLES ATTACHED TO THE SCREEN B4 HAND,,
6871QYH053B IS YSUS MODEL BUFFER U WILL ALSO FIND ON EBAY.
Posted on Jun 26, 2010
SOURCE: my phillips 42' flat screen makes a chirping or clicking noise when turned on but no picture or other sound?
sounds like the Main Elec on the PSU is bad and needs changing
Posted on Apr 19, 2012
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Vertical lines on screen kinda pixelated
Just check this link. You can see similar type of fault to LCD TVs. Compare them to that of your TVs and make sure. It sounds that the LVDS cable has loose contact with its connection sockets. Re-seat it once, and check.http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 03, 2013 | Polaroid Televison & Video
Dp32746 Sanyo Picture is messed up?
try to play a DVD on your TV to determine if the problem is on TV or signal..
If the DVD plays same image you have bad t-con board,.,just replace it to fix the problem..
Aug 25, 2012 | Sanyo DP32746 32 in. LCD Television
My 42" flat screen phillips
I'd post TV model number first - it's on the back of the TV -and I'd also post a picture if I could.
The lines on the screen do not usually go with the "channel not available" problem and the likelyhood of you having both at the same time is , well, small.
Sep 18, 2011 | Insignia 42" LCD Flat-Panel HDTV
I have a Phillips FLATTV model ... Problem with the Philips Flat Panel Televisions I have a Phillips FLATTV model 42PFL7662D/ 05 I have no picture, the audio is OK, I have had a hissing noise for about 2...
Try with that...
http://www.filestube.com/3c4e959f7e53ba6703e9,g/PHILIPS-42PFL7932-LC420WU5-V2-CIRC.html
Symptom:
Sound but no picture.
Cure:
Master or Slave inverter is defective.
It can be that the driver IC is defective or MOSF
inverter transformers, or 470uF 35V C
Replace driver IC BD9897FS or MOSFET's.
996500046243 IC BD9897FS
996500046242 Mosfet FDD8447L
996500046241 Zener KDZ100V
Oct 18, 2010 | Philips Televison & Video
JVC LT 42x688 no picture just sound
Sorry, this has no easy fix. The good news is you do not need an LCD Panel. The bad news is the Video Processor has a problem.
This TV has x3 Boards. The one you should replace first is the one in the middle. If this doesn't fix it, try the one on the right. The Part #s are on the Boards if you wanna try ebay.
Dec 22, 2008 | JVC LT-40X776 40 in. LCD HDTV
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Vertical lines through the right side of the screen
Sorry sounds like you have a bad panel Try changing picture format if the lines don't dissappear or change bad panel
Apr 17, 2008 | Philips 42PF7220A 42 in. Plasma Television
Philips Flat Screen Green Lines
The LCD Panel is defective. You will need to replace the LCD Panel. It will probably be cheaper to replace the monitor since the LCD Panel may exceed the monitor cost.
Single lines of single color (red,green, blue) are LCD panel failures.
1 or 2 lines of single color are LCD Panel failures.
Multple color lines could be anything so in this case you start by checking the power circuit.
Nov 28, 2007 | Philips 20 in. TV/VCR/DVD Combo Flat...
No picture
Tvs usualy have a few ways to hook them up. One is a coax cable this is the silver one in the back that you screw in a cable. The second are RCA cables these are the ones that are yellow, red and white. Yellow is always the video and white and red are for audio. If your using the coax cable your tv needs to be on channel 3 or 4 you may have to force the tv to go to that channel by pushing 03 on the remote. If you are using the Rca cables then you need to change the tv to "video 1" or "video 2" this changes the tv from tunner mode to aux input mode. Most DVD players dont have a coax out so you have to use the rca plugs. Some tvs have the rca plugs on the front (video 2) and the back (video 1) or line in. Some tvs have line out also so you need to figure out wich way you have it hooked up. Do a search for the model of your tv and it should show a diagram on how to hook it up.
Apr 07, 2006 | Emerson EWD2003 DVD Player/VCR
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
