Question about Sewing Machines
How do i get the needle to stop moving when winding the bobbin?
  • 42 Answers
Most machines will have a smaller wheel inside the handwheel that you turn towards the front of the machine, while holding the larger outer handwheel. If the needle still moves after doing this you'll need to work oil through the handwheel bushing.
Posted on Dec 04, 2016
Trying to rewind bobbin machine starts beeping and stops
Is the bobbin pushed over to engage the stop
Oct 01, 2017 | Sewing Machines
My singer 1507 it's not sewing although the engine is spinning. The needle does not move
Confirm that the machine has not been set to wind a bobbin. The bobbin winding mechanism will generally stop the needle action.
Apr 26, 2016 | Singer Sewing Machines
Code 88 starts flashing as well as all the stitching lights on the panel when I try to thread the bobbin. I can sew, that is NOT the problem, threading the bobbin is. What is Code 88? I am not interested...
Turn your machine off and leave it off. Remove all bobbins - in the machine & from the pin. Remove all thread - from threaded machine and bobbin thread path. Clip the machine thread at the spool and pull the needle thread towards yourself. Clip bobbin thread at spool and close to bobbin, then pull towards you through thread guides. This keeps the tension where it belongs. Move the bobbin winding shaft from normal sewing back to winding bobbin a couple times. It should click in place when moved to the winding position. Check to see if there is any thread that has slipped under the bottom of the bobbin and wound itself around & under the bottom of the shaft. Carefully unwind to clear. If the shaft does not easily move back to the sewing position it is probably stuck in the winding position. Don't force it, but try to get it out of the winding position. Leave it to the left in the normal sewing position (unclicked). Check to see if there is any thread caught anywhere along the path from spool to the winding pin. Pay close attention to the first thread guide and the two discs the thread slips between that control tension. Hand wind the wheel on the right towards you to raise and lower the needle a couple of times. Stop with needle in highest position. Do NOT wind hand wheel backwards (away from you). Make sure the bobbin pin is not in the winding position. Now turn on your machine. Needle should jump to default position. Move the stitch length and stitch width guides to the far right, then far left, to attain the green lights. Press the reverse stitch button to raise lower and raise the needle. It will stop in the highest position. If you still have the error code - make sure the bobbin winding pin is NOT in the winding position. Remove the needle. Lower the presser foot and run the machine without any thread a bit. If the needle bar does not go up and down most likely the bobbin pin is stuck in the winding position. If the code has cleared use your manual to carefully wind a new bobbin. Make sure you are using a 15J bobbin which this machine requires. It will not work with just any bobbin. Next, raise the presser foot then carefully thread the machine. If you don't have a manual you can download one from the Singer website. You might consider cleaning the entire machine paying special attention to the hook area and feed dogs while the power is off. If you find a lot of lint do this more frequently to prevent buildup. Take special care when replacing the bobbin care. Hope this helps. If not call Singer. It may take some time but you should be able to reach someone to help you troubleshoot. If this is an older machine I recommend taking it for repair yourself instead of sending to Singer
reference: http://www.amazon.com/Singer-7466-Electronic-Sewing-Machine/forum/Fx3BSOY0VA78VQ4/-/1?_encoding=UTF8&asin=B000B91B3K
Mar 28, 2015 | Sewing Machines
E123@aol.comMy needle on my Bernina 1530 Inspiration just stopped going up and down whether I use the foot pedal or manually attempt to move the needle
This sounds like you have the machine in bobbin winding mode, just refer to your manual to take it out of bobbin winding mode. I'm not familier with your exact model, but the is typically a lever, or button that is used to wind bobbins, so the needle doesn't keep sewing without the bobbin thread in place.
Please rate my solution thanks
Mar 13, 2011 | Sewing Machines
My needle keeps moving while I try to wind my bobbin
hi there,
the hand wheel and clutch should be disengage so that needle will not move also w/ the bobbins,doing this is hold the hand wheel then grip hold also at the center hand wheel.rotate center counter clockwise to release clutch.other type is push and pull hand wheel.any of them,try to run machine if needle is move again.cheers have a nice day don't forget to rate me.
Apr 07, 2009 | Singer 7436 - INGENUITY
Needle is moving when bobbin is winding & lights are flashing
Check the clutch at the knob on the right side of the machine, where you tighten it to sew & loosen it to wind a bobbin. It could be very loose and when you start to wind a bobbin, it tightens itself up.
Apr 06, 2009 | Singer 7436 - INGENUITY
Singer 750 how to rewind the bobbing?
1. Push in indent (illustration 1) on hand wheel disc. This will stop the needle from moving.
2. Place spool of thread on spool pin.
3. Slide spool pin holder/cap (illustration 2) firmly over rim of spool to prevent thread from tangling.
4. Lead thread passing it first through the lower slot of the thread guide. Next through the upper slot, leading the thread to the right and around (illustration 3).
5. Wind thread clockwise around front of bobbin winder tension disc (illustration 4).
7. Pass thread end, from inside, through small hole in rim of bobbin.
8. Holding thread end, step on speed controller to run machine until desired amount of thread is wound. (Winding stops automatically once bobbin is full.)
9. Cut thread; push bobbin to the left and remove it from bobbin winder pin.
10. Trim thread end from top of bobbin.
11. Press the bobbin winding indent on hand wheel to its original position. If necessary, turn hand wheel to engage needle movement.
Feb 09, 2009 | Sewing Machines
Bobbin Winding
How do I wet wind a 2 inchs long bobbin using varnish.
Thanks
Gholam
Jun 16, 2008 | PfaFF Creative 7570
Sewing Machines Logo
37 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
