Question about Ovens
Im looking for intelliseat toilet temperature sensor
  • Ovens Master
  • 14,584 Answers
IntelliSeat - the Ultimate Bidet Electronic Toilet Seat, Bidet Seats ...
https://www.amazon.ca/IntelliSeat-Ultimate-Bidet-Electronic-Toilet/dp/B0050EJBQ0
  1. Cached
IntelliSeat - the Ultimate Bidet Electronic Toilet Seat in Bidet Seats. ... Bio Bidet BB-i3000 Premium Dual Temperature Bidet Toilet Seat, White · 4.3 out of 5 stars 18. CDN$ 179.00 .... Maybe the sensor on the Seat is not working? I am contacting ...
Intelliseat Bidet Toilet Seat - Proper Wash
www.properwash.com > Electronic Toilet Bidet Seats
  1. Cached
  2. Similar
IntelliSeat, is one of AMDM's featured innovations bidet toilet seat, and after one use ... Toilet sensor permits operation only when skin contact is made ... Water Heater; Endless Warm Water; Heated Seat (adjustable temperature); Increased ...
AMDM IntelliSeat the Ultimate Bidet Electronic Toilet Seat - Amazon.com
https://www.amazon.com/product-reviews/B0050EJBQ0
  1. Cached
However, if you have a newer elongated toilet, the Intelliseat will probably fit just fine. ... Maybe the sensor on the Seat is not working? ..... Both seats have LED indicators for seat temperature and water temperature, but only the Intelliseat has ...
Intelliseat is a must for modern toilets - Pilot Bidet
pilotbidet.com/intelliseat-is-a-must-for-modern-toilets.html
  1. Cached
  2. Similar
IntelliSeat is one of the most advanced toilet apparatuses and after one use you ... These sensors can sense the presence or absence of a human body on the ...
=$= AMDM IntelliSeat - The Ultimate Bidet Electronic Toilet Seat w ...
https://betojhkitchenbath.wordpress.com/.../amdm-intelliseat-the-ultimate-bidet-electro...
  1. Cached
Mar 20, 2013 - AMDM IntelliSeat - The Ultimate Bidet Electronic Toilet Seat w/ ... Water Glow LED Faucet Light with Temperature Sensor Three Optional Colors ... intelliseat toilet temperature sensor Google Search
Posted on Dec 04, 2016
Get an error code of f4 when trying to set temperature
F3 - F4 Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor.
Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control
Possible Solutions:
· Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace. If all above is ok replace control.
Hope helps.
Jun 21, 2011 | GE Ovens
Ge profile f2 error while broiling in upper oven
F2
During
BAKE Control senses oven
temperature above 615F-630F If actual over temperature condition occurred: Look for
welded relay contacts on bake or broil relays. If this happens, replace oven
control (also called clock or ERC).
If no over temperature condition
occurred
: Look for a high resistance connection or any other cause of high
resistance in the oven temperature sensor circuit. Check sensor, sensor harness
and sensor harness connection at sensor and oven control. Replace sensor if
found defective.
Remember: Oven control (ERC) measures resistance
of sensor circuit , not actual oven temperature. F2
During
CLEAN Control senses oven temperature above
915F-930F If actual over temperature condition
occurred
: Look for welded relay contacts. If this happens, replace oven
occurred
found defective. Check door lock switches.
(ERC) measures resistance of sensor circuit , not actual oven
temperature.
Jan 24, 2011 | GE Profile JTP56 Electric Double Oven
Error code F2
F2
During
occurred
found defective.
During
CLEAN Control senses oven temperature above 915F-930F
Look for welded relay contacts. If this happens, replace oven control (also
If no over temperature condition occurred:
Look for a high resistance connection or any other cause of high resistance in
the oven temperature sensor circuit. Check sensor, sensor harness and sensor
harness connection at sensor and oven control. Replace sensor if found
temperature.
Dec 30, 2010 | GE JTP15 Electric Single Oven
30 " Convection wall oven
F2 During BAKE Control senses oven temperature above 615F-630F If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature. F2 During CLEAN C ontrol senses oven temperature above 915F-930F If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches.
Nov 26, 2010 | GE 27" Built-In Double Electric Convection...
Shutting down with an F2 blinking at us
F2 During BAKE. Control senses oven temperature above 615F-630F If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature. F2 During CLEAN . Control senses oven temperature above 915F-930F If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
Nov 25, 2010 | GE JTP45 Electric Double Oven
F2 error beeping make it stop
F2
During
During
CLEAN Control senses oven temperature above 915F-930F If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
Nov 22, 2010 | GE Profile JTP56 Electric Double Oven
I was gettin a F5 error andnow i get a F3 error
These are both problems with you Temperature sensor and circuit.
I would check the sensor first. You should have close to 1100 ohms. If this checks out good and wiring looks good the relay is integrated into the board so you would need to replace the control. The info below was taken from www.appliancehelponline.com You can also find diagrams there to show you what these parts look like.
Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· cold solder joint on control.
F5
Relay safety circuit failure
· Check oven temperature sensor circuit for intermittent high resistance.
· Check lock circuit
· Press Clear/Off and reprogram control. If code reappears, replace control
Note: If all above check OK the F5 code can be a result of a momentary loss of power (Do NOT replace control or lock, check lock circuit)
Mar 21, 2010 | GE JTP15 Electric Single Oven
I am getting an F2 with beeping on the display of my double ovens. Any idea what this is?
Hello, here is what the error code F2 refers to for a GE oven: F2
During
During
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature. If you have any other questions please feel free to comment. Mike
Nov 19, 2009 | GE Ovens
I HAVE A FRIGIDAIRE ELECRTIC STOVE,GETIN F2&F3 CODES
Hi, these codes represents a fault within the oven temperature sensor. Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Please rate and god bless:)
Apr 18, 2009 | Ovens
F3 code and beeping
F3 - F4 Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
Nov 17, 2007 | GE Profile Advantium SCB2001KSS Stainless...
Ovens Logo
41 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
