Question about Sewing Machines
How to fill bobbin - Sewing Machines
  • Sewing Machines Master
  • 16,270 Answers
All machines are different, but basically it is done on the top of the machine. First you disengage the drive to the needle by slackening off the wheel in the centre of the manual drive (the big knob on the end of the machine for manually moving the needle). The bobbin and the threads spool go on spigots on top of the machine with the thread threaded past a roller. You put the thread into the bobbin and operate the foot pedal and the bobbin fills.
Most of the instruction manuals are online.
Google
make model manual
Posted on Dec 04, 2016
Can't figure out how to fill the bobbin
hi Beverly.
you have not said what make and model.
but try this.
Always wind the bobbin before threading the machine and needle.
  1. Place spool of thread on spool pin.
  2. Slide spool pin holder/cap firmly over rim of spool to prevent thread from tangling.
  3. Push bobbin winder pin to far left if it is not already there.
More items...
Winding a Bobbin ' Singer Sewing
www.singerco.com/sewing-resources/bobbin-winding-other
or try this.
How to fill bobbin for sewing machine
How do you fill a bobbin on a Brother sewing machine? Use only the included bobbin or bobbins of the same type (part code: SA156, SFB (XA5539-151)).
  1. Turn on the sewing machine, and open the top cover.
  2. Place the bobbin on the bobbin winder shaft so that the spring on the shaft fits into the. ...
  3. Remove the spool cap that is inserted onto the spool pin.
More items...
How do I wind the bobbin? ' Brother
support.brother.com/g/b/faqend.aspx?c=us&lang=en&prod=hf_pc420eus... Search for: How do you fill a bobbin on a Brother sewing machine?
or you could go and look at this link to see if it helps you out some more.
igniter button for SUNJOY PH018PSS Google Search
Nov 21, 2017 | Sewing Machines
How do I get machine case open to take care of thread jam around spindle
Um, you cannot fill a bobbin while it is loaded in the shuttle. To fill the bobbin, you have to remove it from the machine, go through other threading sequences and wind the bobbin on the outside of the machine. If you'd provide us with the make & model of your machine, we could probably help. With the information we've been provided, there's not much we can do.
Nov 03, 2016 | Sewing Machines
Unable to remove bobbin from bobbin threader till almost all thread removed. Viking 1+
You could stop the bobbin filling process just before the bobbin is "full."
Most machines have a finger that rides against the area being filled; maybe this is bent?
Feb 22, 2015 | Husqvarna Sewing Machines
Can't fill the bobbin! Starts ok, but immediately stops and beeps.
Is it the correct bobbin? Is it wound in the correct direction? Is the tension set for the type of thread?
Jan 22, 2015 | Singer Confidence 7467 Mechanical Sewing...
How to fill the bobbin
Please first up on needle bar (Pressre foot). Then take one small screw driver or big needle put on bobbin center before some 3 or 6 times wring some thread ,then put on the bobbin machine wheel side after machine start slow and correctly you fill the bobbin.
Dec 27, 2013 | Sewing Machines
Cant fill bobbin the wheel does not go round on 131 newhome sewing machine
check the bobbin winder spindle... can you slide it to the right or left? If so do that.
Aug 05, 2012 | Janome Sewing Machines
Filling bobbin
is it still under warrenty where you can take it back?
Apr 09, 2012 | Singer 1507
Singer/merritt 2430 bobbin fill
If you lift up the thread holder, the bobbin holder is inside. Loosen the hand guide to stop the needle from going up and down. Pull the thread around the top thread guide and back into the bobbin holder. Thread the bobbin and move the bobbin over so the guage is "inside" the bobbin. As for the manual, the Singer Merritt 2404 is applicable to the 2430 if that helps.
Jun 18, 2009 | Janome 6019QC Mechanical Sewing Machine
Filling the bobbin with my Juki DDL-5550-6
It's actually designed that way on purpose so you can wind a bobbin while sewing. If you lift the presser foot, at least it'll make less noise in the process.
Feb 25, 2009 | Juki DDL-8300
Bobbin filling
Does the winder spin freely by hand? If so then it needs to be adjusted, maybe a new bobbin tire also. If not then try oiling it and freeing it up by hand.
Hope this helps.
Jan 30, 2009 | Singer 7442 Mechanical Sewing Machine
Sewing Machines Logo
29 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
