Question about Husqvarna Garden
A 359 husky. What is the size engine in mm.? Do they make a cylinder, piston kit that Inc gaskets. YEARS IN PRODUCTION?
  • 486 Answers
2001 thru 2011
aprox 47mm
Piston and Cylinder kits from Husky do not include gaskets, but can be purchased individually.
Posted on Jan 24, 2017
fastboyz
  • 674 Answers
SOURCE: size in msize in mm of a yamahm of a yamaha wr400 standard piston
92x60.1
12.5 to 1 comp
Posted on Jan 02, 2009
  • 6 Answers
SOURCE: Husky 359 clutch bearing lube tech
Remove the chain brake cover and check the end of the crankshaft to see if there is a small hole for the roller nose lube gun that should have came with the saw. If so, inject a couple of pumps into this hole which will put grease into the bearing.
If no hole exists then you will have to remove the clutch housing from the saw which can only be done easily with an air or electric impact wrench. The nut comes of in the OPPOSITE direction (counterclockwise) that the nut rotates in when in operation - this should be very easy. Then remove the clutch housing which will expose the needle bearing and using your fingers smear the bearing with a small amount of light high pressure grease. Then replace the clutch housing and turn the nut in the opposite direction you used to take it off with your fingers until it is snug - then use the impact wrench in a very short burst to tighten the nut. Finally replace the clutch housing and/or bar and chain.
For a casual user this should only have to be done once a year as good quality chain oil can get into this area and provide some lubrication.
Posted on Jan 26, 2009
  • 82 Answers
SOURCE: cylinder gasket, use 1 or 2 0.5mm gaskets with a standard piston
Just 1. Never stack gaskets
Posted on May 08, 2009
SOURCE: can I make my own cylinder gasket for a husky 61 ?
Yes you can make your own cylinger gasket for your chain saw just as you can make a gasket for a carberator or other items. Just go to the local automobile parts store and ask for gasket material. Take the old gasket out and trace the pattern on the gasket material and cut it out. The holes will have to be cut cut out also to the correct diameter. The screw holes can be drillied out or punced out for the installation. Be sure you obtain the correct gasket material so take the old material in with you for them to look at.
Posted on May 09, 2009
SOURCE: What should compression be on husky 359?
This saw needs aproxamitly 150 psi. Any less than 120 and you will have problems with the saw breaking up at high rpm and stalling under load. Pop the muffler off and take a peek at the piston and the cylinder walls for scoring. If its scored it will need a new jug and piston, the kit from Husqvarna, includes everything you will need, should run from $175.00 to $200.00. Hit us up on eBay MorganPower is our user name. http://www.morganpower.com/ is our website. Or you can email me at ebay@morganpower.com
Hope this helps, feel free to email me with any other questions, we are a Husqvarna dealer/repair center and can help you out with that saw. It is a great saw all the features of the XP line at a fraction of the cost. It has the 3 piece crank and magnesium case. It is definitely worth putting the money into this saw!
-Steve
Posted on Sep 12, 2009
Standard bore size mm
ENGINE 2 stroke single cylinder direct reed valve crankcase induction Liquid cooled 125 cc engine Cylinder size 124 8 cc Bore and stroke 54 x 54 5 mm 200 cc engine Cylinder size 175 3 cc Bore and stroke 64 x 54 5 mm 250 cc engine Cylinder size 247 7 cc Bore and stroke 72 5 x 60 mm 280 cc engine Cylinder size 272 2 cc Bore and stroke 76 x 60 mm 300 cc engine Cylinder size 294 1 cc Bore and stroke 79 x 60 mm I Cant put periods or commas so bare with me
Mar 15, 2014 | 1999 Daewoo Lanos
Valve adjustment shims for Mazda protege 2002 2.0 litter engine. Dual over head cams 16 valve. Was bored out .020 inches over? What size if it was over bored out?
Three sizes of pistons are available:
1. Std.
2. Over size 0.010 in (0.25 mm).
3. Over size 0.020 in (0.50 mm).
Over sized pistons and rings are widely used in all automobiles with no trouble at all. They last for more than 200,000 km, provided if the engine oil, oil filter and air filters are replaced at the recommended intervals.
The most important point to consider here is to maintain the oil clearances between the various parts during the machining process.
For example piston to cylinder clearance, crankshaft to main journals and big ends clearance, valve to guide clearance, at room temperature. Then comes cleaning process and the engine assembling process.
Dec 28, 2013 | 2002 Mazda Protege
What is the standard size of diameter of the piston for hyundai accent 2002.
76.5 mm bore, 87 mm stroke, 10 compression ratio, double overhead cam and four valves per cylinder. I found this on Autobuy.com this was for the 1.6 liter engine.
Nov 23, 2011 | Hyundai Accent Cars & Trucks
How do I know if my husqvarna '51' has a 44 or 45 mm piston..Does it matter if I need a cylinder kit too...
The 50 had a 44mm piston, all 50 specials and 51s had a 45 mm piston, as a cylinder and piston both will fit the crankcase, the stroke was the same on both.
Jul 29, 2011 | Husqvarna Garden
2001 ultra classic tire size
Specifications: Engine Type: 1449 cc, 4-Stroke, Air Cooled, V-Twin
Engine Bore and Stroke: 95.3 mm x 101.6 mm
Valves 2 valves/cylinder
Claimed Horsepower: 67 hp (50 kW) @ 5200 rpm
Maximum Torque: 110 Nm (81.1 ft. lbs) @ 3100 rpm
Transmission type: 5 speed
Final Drive: Belt
Tire - Front: 130/90-16
Tire - Rear: 130/90-16
Brakes - Front: dual 292 mm discs with 4-piston calipers
Brakes - Rear: single 292 mm disc with 4-piston calipers
Sizes can vary depending on what has been done to the bike.
Ride safe and loud pipes save lives.
Dec 14, 2010 | 2001 Harley Davidson FLHTCUI Electra Glide...
Piston seizure in Husky 359 chain saw-how to remove old top end, evaluate damage and install new piston and ring or all new top end.
Probably going to be a paired piston&cylinder http://www.ebay.com/itm/HUSQVARNA-359-357-CYLINDER-AND-PISTON-KIT-47MM-/140580138020
you will need to replace both.. remove your muffler and see scorched(black streaks) piston, fused rings. Remove air filter and carb to see scored cylinder wall(on hot side)
Aug 23, 2010 | Husqvarna Chain Saw 20" Bar
HOW DO I REMOVE THE CHAINDRIVE CLUCH ON A 359 SAW
My 359 has 3 detents rather than 2 but other than that is like the video.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
If you need them, part numbers for Husqvarna and Oregon rim sprockets can be found below.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 27, 2010 | Husqvarna Chain Saw 20" Bar
My husqvarna 359 chainsaw blows fuel out the exhaust when I try to start it. Just rebuilt the carburetor with a kit. Still same problem.
You need a carburetor kit. The needle valve in the car. is stuck open. The needle valve helps to control the flow of fuel.
Jim
Jun 18, 2009 | Husqvarna Garden
-Steve
Apr 07, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
274 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
