How to remove basket from cutting head on Ativa MDM 8000
How to take basket off to empty
    New Friend:
  • 85 Answers
How to empty basket on Ativa MDM 8000
just refer to the service manual provided at: and search for the model.
Dec 04, 2016 | Office Equipment & Supplies
My Ativa HD Pro 1800 will not power on
First check the power point is still working - plug in another appliance, like a table lamp. If OK check the fuse in the shredder cable plug.
The commonest reason for a shredder stopping is a paper jam, or running the shredder for too long. By 'too long', many shredders will cut-out after 5 minutes continuous working, and the sensor may take 15 minutes to cool down! Read the manual.
It maybe that the shredder cutters are jammed. Unplug from mains, and lift off top and place upside down. Use a small screwdriver and/or long nosed pliers to poke at any compressed paper wrapped around the blades - can take a while.
It may be that the sensors are dirty - use a cotton bud dipped in rubbing alcohol to clean the sensor light(s) and heads
Give a quick spray to cutters with WD40 Replace - turn on - and run in reverse.
May 21, 2014 | Ativa HDM PRO 8000 8-Sheet Micro-Cut...
I have jb01 and can nott see any sensor no light no switch
There are 2 methods. One is a mechanical arm that is lifted by the paper.
More often there is an LED light at one end of the ffeed to the cutters, and a sensor at the other end. It may be that the sensors are dirty - use a cotton bud dipped in rubbing alcohol to clean the sensor light(s) and heads
Mar 15, 2014 | Office Depot Ativa DQ60M Shredder
Jammed shredder
If your Ativa shredder has a bin, you can gain access to the shredding mechanism by removing the bin and turning the shredder upside down. With power disconnected, be prepared to spend considerable time picking out bits and pieces of material. Tweezers and a utility knife are useful tools. Eventually your shredder will be back in working order.
Feb 28, 2014 | Ativa MDM6000 6-Sheet Micro-Cut Shredder
Ativa shredder manual
I could not find a manual or support on Ativa website but I searched their FAQ. It said that the shredder basket must be fully closed and integrated with the shredder. I had the same problem. I pushed the basket firmly into place and it stopped. I believe this flashing scheme may be telling you that the shredder and basket aren't properly aligned.
Oct 05, 2013 | Office Equipment & Supplies
Won t shut off
Blow out the sensors with some compressed air, Using a can of compressed air, look for the sensors that detect the paper and give them a blast or two, then try it, it may take a couple of tries.
This may also be a good time to lubricate the cutting heads, if it is a good machine with metal heads a light oil applied to paper then run through the shredder will pass the oil onto the heads.
A shredder oil or light oil like 3 in 1, these usually have a narrow nozzle to limit the oil flow, draw lines, do a picture or spell your name on the paper with oil and shred it. You have just serviced your shredder.
If it is a less expensive shredder with plastic heads, shredding a couple if sheets of waxed paper will pass the wax onto the cutting heads reducing friction.
Hope this helps.
Oct 01, 2013 | Office Equipment & Supplies
How do you empty the container?
You will first need to unplug your shredder. On either side on the shredder head, there are grooves. These are finger grooves. Place your fingers inside the finger grooves and lift up. This will remove the shredder head from the waste basket. Simply empty the waste basket, replace the shredder head and plug back in.
Jul 10, 2012 | Compucessory CCS 60062 Shredder
I have an Ativa AT120DC. It won't operate
I have an Ativa AT120DC Shredder. When it is switched to auto there is dim green light and it doesn't start. If I feed paper in it makes no difference. For some time it always started up when you switched it to auto and didn't wait for paper to be fed through. If you remove the basket the Door Open light comes on. can you help?
Mar 18, 2010 | Office Equipment & Supplies
The basket full light will not go out
Sep 15, 2009 | Fellowes DM15C Shredder
How to empty a Tech Solutions TS8000 shredder
Pull the top of the basket toward you and the top of it should swing out. Then you can lift the basket up and out once the top of the basket is partly open. Hope this helps. Have a good day. Mac =)
Mar 09, 2007 | Tech Solution TS-8000 Cross-Cut Shredder
Washing Machines Logo
65 people viewed this question
Top Washing Machines Experts
