Question about The Computers & Internet
Working on an excel spreadsheet that is linked. I am adding tabs to the files but each tab has whatever is on the master sheet, how do I make each tab hold its own info?
  • Brett Duxbury
    Brett Duxbury Dec 04, 2016
    Hi Sally Tucker,we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    tabs are these the workbooks at the bottom of the spreadsheet ?
    Are you copying the information to the new tab ?
    When you are copying the information to the new tab it will be linked to the master sheet.
    When you paste- select copy values only rather than the formulas linked to the master sheet.
  • 265 Answers
SOURCE: consolidate few sheets under 1 excel
What version of Excel are you working with. Newer versions allow you to have multiple spreadsheets grouped together into what is called a, "Workbook." To view the sheets separately, you simply click on the tabs at the bottom of the workbook. The easiest way I know of to join spreadsheets together into a single workbook is to open all of them at the same time, then choose, "View / Arrange All," and they'll be small, but you can grab each one by its tab and drag it to the workbook you want them in. Then you save the workbook (give it a new name like, "Accounting Roll-UP," or, "Consolidated Books," or whatever best describes it) making sure to close all the (now empty) spreadsheets without saving your changes to them (or else you'll lose your 'back-up' data). Voila! You open one file, and all your spreadsheets are available with the click of a mouse.
Posted on Dec 18, 2007
SOURCE: how to read wsdl from MS =excel 2003
You could try BEA AquaLogic Data Services
Posted on Aug 28, 2008
  • 477 Answers
SOURCE: Excel formulas
hello
yes it is.
example
sheet1
A1 (50)
A2 (50)
sheet2
(A1)=
"=Sheet1!A2+Sheet1!A1" <-this is the actually code in sheet2 column A1
ok let me explain
in A1 and A2 in sheet1 you got 50 and 50 like numbers.
in A1 on Sheet2 you have = sheet1 a1 + sheet1 a2.
did you get it?
dont know else how I should explain it...
good luck
Posted on Oct 09, 2008
luiskiev
  • 144 Answers
SOURCE: Excel 2007 Toolbar
Use "drag and drop". Move the toolbar into the other toolbar if exists.
Posted on Nov 10, 2008
  • 23 Answers
SOURCE: excel 2003 / 2007 vba code
A similiar thing happened to me once and I used the format
"Sheets("Lab Work Order Master").Copy(,ActiveSheet)" instead of
"Sheets("Lab Work Order Master").Copy After:=ActiveSheet"
You may also want to try using a sheet index instead of "ActiveSheet" to refer to your sheet.
P.S. Don't forget to rate me. Wish you the best.
Posted on Dec 12, 2008
How do you copy and paste one excel spreadsheet to another making sure the headers are lined up correctly.
right-click the sheet you want to copy, select "copy to", then either select the position within the current document, select annother document (needs to be open in the same excel instance) or select "new document". check the box "copy" to copy, leave unchecked to move.
Jan 01, 2016 | Microsoft Excel Computers & Internet
How do you make lines appear on an excel sheet?
I'm not sure what Version you're using, so I'll assume after Excel 2010.
At the top of the page, under the Home tab and directly under the Font window, there is an icon which looks like a window frame (dotted all around except on the bottom edge).
In your spreadsheet you have to select the area you want to work on. You can select a single cell to add lines to or the whole spreadsheet. Click on the icon I described above and a menu box will pop down. There many choices which allow you to select lines on all sides of your work. I prefer the one at the bottom which says 'More Borders'. With that window you select the edges you want lines on, the thickness/type of the line, or put an outline.
I think that's enough for now and I hope that gets you started.
Aug 12, 2014 | Microsoft Excel 2010
Excel table link in word
Excel and Word are two parts of the Microsoft Office Suite that have become standards tools for spreadsheets and word processing.
Among their features are the ability to easily exchange information.
For example, you can easily copy a cell or part of a spreadsheet from an Excel and paste it into a Word document, which preserves all the formatting.
This method requires opening up both programs at the same time.
To avoid this, you can insert an Excel file from within Word itself.
Choose the "Insert" tab inside Microsoft Word to display the Object dialog box.
Click the "Create from File" tab and Browse to display the Browse dialog box.
Navigate to the Excel file that you need and double-click to load its name into the File Name box of the Object dialog box.
Click a checkmark into the "Link to File" box if you want the table that you insert to be automatically updated anytime the original file is changed.
Otherwise, leave it blank if you don't want the inserted information to be affected by the original file.
Click "OK" to insert the Excel file as a frame into the document.
Note how only filled cells from the first table (worksheet) of the file are inserted.
Blank cells are not inserted. You can resize the frame by clicking it and dragging the handles that appear.
You can also click it and drag it to a different line within the document.
http://office.microsoft.com/en-us/word-help/link-or-embed-an-excel-worksheet-HA010120810.aspx - BM4
Aug 07, 2013 | Microsoft Excel Computers & Internet
Excel to word tables linking
Aug 07, 2013 | Microsoft OFFICE 2013 HOME AND BUSINESS 1...
This printer will print a pdf file but not an excel spreadsheet
shade the area of the excel spreadsheet you want to print, then right click and choose format cells and under the border tab, choose inside and it will outline a printable excel spreadsheet.
Dec 23, 2009 | HP Deskjet D1455 InkJet Printer
Using Microsoft Query to bring Access 2007 data into a spreadsheet
Try using Data > From Other Sources and select From Microsoft Query. In the Excel sheet, select the cell that you want the results to start in. Your MS Query would be pulling the data from your Access database.
May 04, 2009 | Microsoft Excel for PC
I have done something in my spreadsheet ... many icons are dimmed. For example, under the Insert tab, all the icons are dimmed except for Header & Footer, and Signature line. If I open a new file, the...
It sounds like the file is "read only". Open the file and save under a new name, or right click the file name and select properties. Then make sure the "Read only" box is cleared. The file could also be protected. Go to the review tab and sele "Ptotect Sheet" in the changes group. If the is no password, the sheet will be unprocted when you click the icon.
Feb 10, 2009 | Microsoft Excel for PC
Excel 2007 Toolbar
Nov 05, 2008 | Microsoft Office Professional 2007 Full...
Consolidate few sheets under 1 excel
Dec 18, 2007 | Microsoft Office Standard for PC
Computers & Internet Logo
Top The Computers & Internet Experts
tim brauer
tim brauer
Dilum Senarath
Dilum Senarath
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
