SOURCE: Maytag gas Stove MGR5710 bake oven does not work. boiler works
Usually I always find it's the ignightor. They are not to hard to replace. It's #5 on this looooong link
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MGR5710ADW&productCategoryId=0124002&brandId=3048&modelName=GAS-RANGE&diagramPageId=00005&componentDescription=GAS%20CONTROLS&documentId=X2906551&backToLink=Return%20to%20Sub%20Components%20list
Or go to http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
enter your model number and it'll kind of show you how to get it apart. Good luck.
Scott
SOURCE: I was setting the clock
If your code is SaB i just did this myself....i accidentally turned on the sabbath mode. I fixed if (after 2 days of trying) by holding down the cancel button for about 5 seconds, and then the clock button for about the same.
SOURCE: I get an "F1" code on my Maytag range.
you need a new temperature probe. its usually located in the upper left hand corner in the rear of the oven.
SOURCE: Maytag oven doesn't fire, but stovetop burners work fine
This will sound crazy but I had to work through it on my own stove a few years ago. The ignitor (glow tube) was getting hot but the oven would not owrk. When investigating the problem I found that the gas valve will only open when the ignitor pulls a specific amperage or draw of current. As the ignitor ages it pu;;s a reduced draw of current. This causes you to be fooled by the glow nut no gas. Replace your ignitor and your oven will begin to work again!
You can get ignitors easily online by doing a search for "appliance parts" and then entering the model number of your stove. Look for ignitor and you will be good to go. Also check out a few different sites as the prices of the parts can vary quite a bit.
Testimonial: "Thank you very much for your help. I was looking for a thermocouple but that must be old school. I couldn't figure out what told gas to flow."
