Question about Reddy Heating & Cooling
My Reddy heater 55,000 is not blowing out the flame is not as hot as usual.
There is a flame but does blow out just whilst around and back.
  • 49 Answers
SOURCE: Heater only blows hot (well, warm) on full speed of fan
Replace the temp control on this car, it should be electrical control not cables.
Posted on Dec 03, 2008
  • 12 Answers
SOURCE: fan not blowing hot or cold air into car
Sounds to me like your heater resistor may be bad do you have any speeds on the fan because typicly you will still have high when this fails if so you may want to check fuse for heater and relay hope this helps
Posted on Jan 22, 2009
  • 319 Answers
SOURCE: Faulty Fan Heater - The main vents are just blowing out cold air.
all cars have a recycled air weather its called max or just recycle its doing the same thing. So if your getting cold air in one spot and hot in another it means your vents are not blocking where they are suposed to. It could be just a simple fix, by getting into the dash where your vent controls are and looking at the flap that tells air where it can and cant go. if its stuck then it needs to be cleaned and oiled. If the cable is corrodend clean it and oil it so it can move freely, or just reconnecting it may be the fix. it sounds like you are going to have to be adventurous, and play with the mechanics of your vents. Typicaly theres really nothing tough there to work on, just REMEMBER WHEERE ALL THE SCROOS AND CLIPS GO. I have forgotten where a few went in the past and had to listen to sqeaking noises till I took it apart again. There are vent seals wich are no more than the weather stripping you buy at the hardware store the 1/8 inch thick tape. You may need to thin it down with a razor, usually not. but it works great for fixing the seals in car heaters, because its the same thng just a different color. Which no one will ever see.
Posted on Feb 02, 2009
  • 7 Answers
SOURCE: when i have the heater/defroster on the heater
It sounds like you have a blend air door stuck. This is in the housing of the heater a/c blower unit under the passenger side of the dash. There is a motor on the top of the housing that could possibly be stuck or on working.
Posted on Sep 05, 2009
  • 83 Answers
SOURCE: My 2001 Yukon front heater
Check your heater control valves.
Posted on Jan 19, 2011
My reddy55 will only fire if i blow air in back of heater.any help would be great thanks
I have one similar, needs a new fan or new unit, anyway on mine I have to plug it into both propane and electrical and will not light unless the fan is plugged in, saefty from it blasting flames\fumes out the back
Jan 15, 2011 | Reddy Heater-30-55,000 BTU Variable
I need 100,000 btu or highest btu output for an enclosed new york masony jobsite
Hi try surefire heaters lpg blows hot air all differant ranges local lp company or hire shop
Feb 12, 2010 | Reddy Heater-30-55,000 BTU Variable
I have a R-150. starts runs and fames out in 30 seconds and continues to blow fuel for about 20 to 30 seconds and then I assume flame sensor shuts it down. Im thinking ignition coil. Any ideas. Thanx
What usually causes that is the ignition component is not hot enough to sustain a hot enough temperature to keep the fuel burning some have a spark ignition some have a hot surface ignition,try replacing it and it should work fine.
Sep 02, 2009 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater R50A will not ignite
yep.plug the unit in and look in the back of unit.should see an orange glow.if you don't the glow bar is not comming on
Feb 23, 2009 | Reddy Heater-30-55,000 BTU Variable
No heat, just smoke, flame inside,
Jan 16, 2009 | Reddy Heater-30-55,000 BTU Variable
Remington 60 portable forced air heater 60,000 btu
I had the same problem. I took the nozzle head off and blew through it with air. I also blew through the air line, this is the one that goes to motor. It has worked fine ever since.
Dec 16, 2008 | Reddy Heater-30-55,000 BTU Variable
Reddy heater TB100 propane
Well it sound like you have all the components working. Try lighting it with a torch or long match or something. If it lights, then you may need to adjust the spark-er. You also may need to adjust the pilot. It may be too much pressure, which will blow out the flame, or its not enough gas. Make sure the pilot orifice is clear.
Mar 01, 2008 | Reddy Heater-30-55,000 BTU Variable
Reddy heater R55tb
what is pictured is a propane heater. two problem areas come to mind. one) the hi limit cutout, and two) the flame sensor. the hi limit is a normally closed device that is bolted to the back plate of the fire chamber. its two wires go to the cappilary of the flame sensor. the flame sensor is of the j-k thermocouple. it generates a millivolt signal to keep the pilot valve open. the flame sensor generates a dc output to the tiny electromagnet inside the main valve. when you start the unit, a hot surface igniter heats up, the main valve opens, a signal is generated to keep the valve open. if it doesn't sense a flame it shuts down and goes into lockout. change the flame sense unit first. what you can also do is temporarily put a jumper wire on the two terminals on the cappillary of the flame sensor.
Nov 29, 2007 | Reddy Heater-30-55,000 BTU Variable
Heating & Cooling Logo
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
