Question about Dishwashers
I'm using Lamona HJA8704. And it doesn't drain so i want to clean filter, however, can't find place. I would appreciate if someone could tell me.
2 Suggested Answers
  • 6277 Answers
SOURCE: I am looking for a
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
(this is my standard reply but I've just followed my own advice and found this!
http://www.inter-spares.co.uk/howden/howden-washing-machine/hja8703/instruction-manual-1-2-3-4-5-6-7-8-9-10-11-12&usg=AFQjCNHicY59t2EHXq15qkInEBscfeGeZw)
Posted on Jun 19, 2011
Lamona hja 8514
You have an internal pump which is not accessible without uninstalling the appliance, however instead of using drain block have you tried a proper appliance cleaner and cleaning the connection under the sink as this is where most smells come from and not the machine themselves
Apr 07, 2014 | Washing Machines
I have a lamona washing machine that is only 1 year old and its started to stink. I have cleaned the machine with several hot washes, vinegar, washing machine cleaner ,the lot, and still it stinks after a...
it would be the air flow is blocked, washers get there air flow from the drain pipe, if this starts to get blocked it stops air flow but still allows water to go out, this will leave a lot of congestion on the washing machine door glass, use a descaler tablet on the hottest wash you can do and then leave the washer with it draw out, depending on the condition it can take upto 3 times with the descaler, use the liquid type and watch washer as you use it as you will need to put it in the draw every time it empties its cycle. overnight leave some bleach in the drum toilet type will do fine, this will not damage the washer but it will kill all the bad bacteria in the washer drum and the smell, then before use do a quick wash no heat wash or 30c. hope this helps.
Nov 08, 2017 | Washing Machines
Lamona Washing Machine HJA 8514 Half way through a
(no promises but try this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
John C
Jul 27, 2011 | Washing Machines
The clean filter light is on, where is the filter on the Whirlpool AWD3571
There is a little door set in the botton right of the front of the machine. Flip the door open, the filter is behind it (It unscrews).
Can't recall if this model has a little drain pipe that you pull out do drain off any dregs of water in the filter. If it doesn't, I usually pull the machine out from the wall and tip it back a little so the water in the filter doesn't pour out when I unscrew it. HEAVY MACHINE, if you are going to tip it backwards, have someone help you do this!
Please rate this solution
Jul 18, 2011 | Whirlpool Washing Machines
How do I change or clean the filter on my Lamona 8362 dishwasher ? I do not appear to have been given a user manual Thanks
  • 1 Wait until the dishwasher has completely cooled after use before attempting to clean the filter. Turn the dishwasher off and unplug it from the power supply.
  • 2 Remove the lower dish racks and locate the filter compartment on the bottom of the dishwasher.
  • 3 Unscrew the filter housing and gently pull to lift out the filter.
  • 4 Use a few drops of dishwashing liquid, warm water and a soft-bristled brush to clean the filter and the filter housing.
  • 5 Dry the filter and the housing and reassemble them. Reposition them in the bottom of the dishwasher and turn until locked into place. Replace the racks and close the dishwasher door. Plug back in to the local power supply.
  • Jul 07, 2011 | Dishwashers
    Lamona dishwasher from Howdens. E1 code
    we have a howdens dishwasher model number hja8630, which is full of water which hasnt drained . i have ladled it out checked filters are unblocked but it still fails to start. it does a click click sound and then nothing . only 18 months old and only ever used twice a week
    Feb 21, 2010 | Dishwashers
    Washing machine not draining water during washes
    hi..The problem most probably is your pump is not working
    or the hose that the water drains out is blocked.
    check it out..
    thank u..
    kindly rate my response..
    May 08, 2009 | Washing Machines
    Dishwashers Logo
    Top Dishwashers Experts
