Question about Coffee Makers & Espresso Machines
After brewing the unit shuts off and wont keep coffee hot
  • 10 Answers
SOURCE: Brew unit in Miele coffee system CVA615 block
It sounds like the connector or wiring that links the LCD display board on the door to the main PCB inside the coffe maker has become loose or damaged.
This would cause the text displayed to become scrambled.
Its a 26 way connector that is labelled JP16 (on the next model up) and is next to a large IC.
Posted on Jan 02, 2008
  • 4 Answers
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Posted on Nov 15, 2008
  • 25 Answers
SOURCE: Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
Posted on May 14, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: it shuts off after brewing.. how do i keep it on?
Turn the function knob to AUTO OFF - change the time to 4:00 by pressing and releasing the HR button. A denotation of "4:00" means it will stay on for 4 hours, which is the maximum allowed by this coffeemaker.
Shortcut method - unplug coffeemaker for an hour or longer - it will restore itself to its default, which is to remain on for 2 hours.
Posted on Sep 29, 2009
VtToolMan
  • 704 Answers
SOURCE: Coffee maker shuts off too soon after brewing.
Hello FloydBob, The Cuisinart DCC-1200 has the ability to program the auto-off function that keeps your coffee warmer plate on after brewing is complete.
The unit lets you select the time increments from zero up to 4 hours.
See page 6 of the attached manual for the full instructions for reprogramming the coffee maker.
To program the Variable Auto Off:
1. Turn the FUNCTION KNOB to the “Auto Off”
position. Press and hold the “Hour” button
for 2 seconds. The clock display will start
blinking.
2. Program the coffeemaker to shut off from
zero to four hours after brew cycle is
finished by using the “Hour” and “Minute”
push-buttons.
I figured you might also like to have a complete instruction/owners manual so you can have access for any other questions you might have about your coffee maker, in the future.
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
I hope you find this Very Helpful and best regards!
Posted on Nov 10, 2009
Wont make espresso or cappuccino but will allow other coffees
Hi, not a common problem, have you checked your programming, other wise, id be looking at the electronic board. If its brewing other coffees through the brew unit, then I would think a board. Other non working functions may help you trace the problem further. example; steam or hot water not working. dazza
Oct 12, 2011 | Jura Capresso Impressa Z5 Espresso/Coffee...
Water is hot but it does not brew the coffee.
Hi. How do you know that the water is hot if it wont brew coffee. They have different boilers to do each function. Hot water function. steam function and brew funtion. Sounds to me that you have a clogged brew unit. If hot water is coming from the water outlet, the you do have a fault with the brewing side of things. Dazza REPAIRER
Sep 23, 2011 | Keurig Elite B40 Coffee Maker
The Krups coffee maker brewed as usual, it was a little hot so I did a few other things went back to the coffee maker it had shut off by it's self and now wont come back on???
unplug the coffee maker. Let the unit cool down for say a half hour. Try another pot of coffee and see if it comes on after plugging it back in of course
Oct 31, 2010 | Krups ProAroma 453-71 Coffee Maker
The heater plate on cuisinart cbc-1600 coffee maker does not stay on after brewing cycle to keep coffee hot. is this normal operation?
The CBC-1600 comes with a thermal carafe. therefore, it doesn't rely on a heater plate to keep the coffee warm.
Feb 01, 2010 | Cuisinart DCC-1200 Coffee Maker
Change gaskets on BUNN model CWT15-APS
  • Brews 3.8 to 7.5 gallons (14.4 to 28.4 litres) of perfect coffee per hour.
  • Large 200 oz. (5.9 litres) tank provides back-to-back brewing capacity.
  • Adjusts automatically to varying water pressure.
  • For high lime areas, BrewLOGIC® technology calculates flow rate and adjusts brew time to maintain consistent pot levels.
  • BrewWIZARD® technology incorporates simplified programming with a LCD display.
  • Quickerinstall saves up to 30 minutes. Pot level, cold brew lock-out and tanktemperature set easily from advanced touch pad on front of machine.
  • Electronic diagnostics and built in tank drain make service easier.
  • Ensures coffee brew quality with cold brew lock out capability.
  • Brew into decanters.
  • SplashGard® funnel deflects hot liquids away from the hand.
  • Coffee extraction controlled with pre-infusion or pulse brew and digital temperature control.
  • Automatic warmer shut-off.
Jan 13, 2010 | Bunn CWT 15-APS Coffee Maker
blinking.
push-buttons.
Nov 09, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Cuisinart grind and brew
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Oct 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Black and Decker Coffee Maker DE790B
The warming plate is controlled by the same thermal switch that cycles while brewing and they are mechanically in contact; it switches at about 150 degrees C.  Most later coffee makers have a time limitation as well and if they are so designed, will turn off completely after 30 minutes to 2 hours after the brewing is finished to reduce the chance of the machine failing. If you insist on having one that doesn't behave this way, you can buy a cheap one from a 'dollar store,' they don't have that feature and will continue to cycle until turned off.  Your B&D isn't malfunctioning, that is how it was designed.
Sep 05, 2008 | Black & Decker (050876530606)
I have a dgb600bc grind and brew. It will initially grind and brew the coffee hot, but as soon as the brewing is done the heating element shuts off causing the coffe to slowly get cold.
When the cycle is finished, the coffeemaker will beep 5 times, indicating that the coffee is ready. The unit will turn off automatically.
The insulated carafe keeps the coffee warm for four hours. The aroma of the coffee is preserved thanks to the hermatic cover. It is not necessary to remove the cover to pour coffee.
Hope this will help you.
/Mirran
Jul 24, 2008 | Cuisinart DGB-600 Coffee Maker
How to keep coffee heated after brewing
I beleiv this model is like a thermos ,once it brews you can take the pot and place on a table for company,so that you dont have to keep getting up to get more,a lot of breakfast places use this method so the waitress is walking around all the time with a hot coffee pot,if your losing heat make sure the top is secured please rate this solution thanks
Jul 13, 2008 | Krups Aroma Control 229 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
