Question about Cell Phones
Can't find manual and don't know how to access battery. Back does not look like it comes off easily - no place to insert anything.
    Top Expert:
  • Cell Phones Master
  • 48,226 Answers
If it is a cell/mobile phone , insert a finger nail under the join for the back half and lift gently
the back just clips on exposing the battery and sim card
Posted on Dec 04, 2016
Unable to insert battery on my samsung galaxy s111 don't have a user manual
There is a notch middle top plate is only gelding in with plastic clips. Be firm but not forceful. Just pry apart with fingernail remove top to bottom and bottom to top to put back on.
Jan 10, 2013 | Samsung SGH Cell Phones
How to Replace the Fuse on a Kenmore Dryer?
1) Firstof all unplug the dryer from wall unit.
2) Carefullypull the dryer away from wall. So that you can easily access the dryers back.
3) Removethe back panel of the dryer. It’s fitted with some screws.
4) Insome dryers it been noticed that top panel of the dryer blocks the back panelto come out. In this case the top panel latch needs to be pressed by a puttyknife .this will release the back panel to be easily removed.
5) Afterthe back panel is removed out. You will see the thermal fuse. its a metal barwith wires connected to the end of the metal bar. The other end of the wiregoes to vent hose.
6) Removethe wires carefully and remove the old fuse out.
7) Beforeremoving the fuse. Please note down which wire is connected where and in whatposition the fuse is placed in the socket.
8) Afterremoving the old faulty fuse insert the same fuse of same amp/voltage.
9) Refitall the parts which you removed while removing the old thermal fuse in reversemethod. Take care you don’t miss any part fitting.
This will help. Thanks.
on Mar 20, 2010 | Dryers
Removing seat for battery replacement on 2001 Kaw ZR 7 s
does the seat come off with a key? most cycles differ in the way to access the battery read your owners manual if you don't have one buy one some seats remove with a key some are bolted and the bolts are under the edge of the seat and can be difficult to access if you don't know where they are
Oct 15, 2012 | kawasaki Z 750 Motorcycles
How do I replace the battery on my Bang and Olfsun BeoCom 2 hand set
The battery retaining clip assembly sits inside a groove that holds it in place. Do not try to pry it you'll probably break it into many pieces. Using a retaining spring pliers, insert the pliers two prongs into the two tooling holes in the assembly and squeeze it so the clip assembly clears the groove ledge. It will come out slowly. Replace the battery. Assembly is the reverse.
Nov 22, 2011 | Bang Olufsen Bang Olufsen BeoCom 2 24 GHz...
How do you change batteries stanley 3 in 1 tripod led flashlight
The unit is 3 individual flash lights. Pull one of the flashlights by the head (the light part) it will come out easily once you know what you are doing. The other two may be pulled out in the same manner. The bottom will then unscrew where you will be able to replace the AA batteries. Each flashlight will then go back into place very easily. Hint...test each individual flashlight before putting back together to make sure you have your batteries in the proper place and that they are useable batteries.
Dec 08, 2010 | Stanley 3in1 Tripod LED Flashlight 95155
Battery in a Polar F7 heart rate monitor
You can change the battery in your polar f7 if the battery is worn out.
1. Insert the tip of a pen knife into the lifting point and lifting the back up. The back of the watch is only pressed into place and will come off easily this way.
2. Grab the small clip that is extending across the surface of the battery with a pair of tweezers. Slide the tweezers toward the end that hooks down into the watch. Pull the hook end of the clip out of the watch and remove the clip from the battery
3. Match the old battery with a new one at any electronic store. The store will be able to read the writing imprinted on the battery to make sure that you get the correct battery type for your heart monitor.
4. Press the new battery into the watch making sure that the writing on the battery is facing up.
5. Press the holding clip back into place. Handle the clip with tweezers only, since it is very thin and can be bent or lost easily. Once it is in place, press the back of the watch on.
Jul 15, 2010 | Polar FS1 Unisex Heart Rate Monitor Watch
Replacing door handle on microwave ge profile JVM2070BH02
You will need to access the door handle mounting screws and remove them to replace the door handle. To access these screws on MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. This can be easily be accomplished by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel and pry the plastic up. Work your way slowly around the perimiter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful microwaves.
With the inner panel removed, the door handle screws are visibile and can easily be accessed with a screwdriver. Simply remove the broken handle and install the new one. Re-insert the inner door panel, gradually working your way around the perimeter of the door glass to ensure it snaps back into place and seats properly.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwaves, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
You can view an exploded view diagram of your microwave at for reference. Just type in your model number and locate the parts listing for the door. If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Nov 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Samsung LN-T4066F 40" LCD TV has no picture, has sound. It appears to have lost color, with daylight coming in my room, I can make out the faint picture of the LED screen like you can see on an old LCD...
According to my knowledge it is the bulb so please replace it to fix your problem and below is the detailed procedure to do it with pictures.Required Tools
  • Philips head screwdriver
Remove the access panel
Locate and remove the lamp access panel on the rear left of the set (left if you’re facing the front of the set). There’s one screw holding it in place. Remove that screw and ease the panel off. It removes most easily if you hold the back of the panel and slide it toward the side.
samsung-dlp-lamp-1.jpgRemove the old lamp
Unscrew the two brass screws on each end of the base. They won’t come out completely as they’re designed to stay on the lamp as it’s removed. There’s a pull-handle for removing the lamp. Give that a tug, and if it gives and stops, you may need to loosen the screws more.
samsung-dlp-lamp-2.jpgPull out the lamp. Don’t touch anything other than the plastic casing as it can be hot. Put it in a safe place, especially if it isn’t entirely dead and you wish to keep it as a last-ditch spare.
samsung-dlp-lamp-3.jpgOnce the lamp is out, make a mental note of the color wheel in the space where the light shines. You may meet this part in a future episode of your television’s maintenance.
samsung-dlp-lamp-4.jpgInsert the new lamp
Look at the connector plug at the top of the lamp so you know what you’re dealing with. Carefully slide the new lamp back in the same way the old one came out. That plug needs to connect with it’s mate, and the two tabs that the screws are on will meet flush with the ends of the rails. It can be tricky to get the new lamp back in. I watched a repair guy struggle with it for quite a while once. He just kept wriggling it. I wouldn’t recommend using force, however. Keep trying, it’ll go.
Once it’s in, tighten the screws that should already be there attached to the lamp.
Close up the access panel
Put the cover back on the set and secure it with the screw. The television has a sensor and will not turn on if this panel is not in place. This is a safety feature as things get hot in there.
Turn on the TV
Power up the television and if all went well, your set should start up like the old friend you know and love.
Oct 12, 2009 | Televison & Video
New PC woni't boot
there is a chance that the RAM is not placed properly or has dust ..
take it out, clean nicely, the edge which is inserted with a tissue Then reinsert it. If there are two RAM slots, then place the RAM in another slot and try.
continuous beeps are due to the ram not inserted properly or some loose contact in the power switch wires, which is not identifiable and correctable easily.
Apr 11, 2008 | Computers & Internet
Removing cover on Acer 5720z to access RAM
Download Aspire 5720 User Guide. Extract the .zip file and open the User Guide Acrobat File.
You can finr info on Installing memory on page 75
Follow these steps to install memory:
1 Turn off the computer, unplug the AC adapter (if connected) and remove
the battery pack. Then turn the computer over to access its base.
2 Remove the screws from the memory cover; then lift up and remove the
memory cover.
3 (a) Insert the memory module diagonally into the slot, then (b) gently press
it down until it clicks into place.
4 Replace the memory cover and secure it with the screw.
5 Reinstall the battery pack, and reconnect the AC adapter.
6 Turn on the computer.
The computer automatically detects and reconfigures the total memory size
Mar 22, 2008 | Acer Aspire 5610 Notebook
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
