My DPF-1411 has stopped working, wont power on at all. I have tried plugging it into various plugs and holding down the power button but nothing happens. What else can I d?
    Habit-Forming:
    New Friend:
  • 85 Answers
Do this steps:
1. check the power supply adaptor cord ,stranded wires inside sometimes breaks without your knowing.
2. Use a voltmeter to check the voltage output from the adaptor if doesnt react and no reading at all replace it .
3. if the powersupply is good, open the back cover and find the fuseable resistor inside the power source section of the board. replace it with the same value and put it back the cover and you are good to go. thanks
Posted on Dec 04, 2016
  • Lynda-Jo Jackson
    Lynda-Jo Jackson Dec 05, 2016
    Thank you so much! We borrowed a volt meter from my father in law and found out that the adapter had indeed gone bad. luckily we had another that worked just fine. Sadly, when we got the picture frame powered up we found there was damage to the screen in one corner. :(
    Thanks for you help!!
  • Jennies de leon
    Jennies de leon Dec 05, 2016
    you are welcome lynda
Allwinner a33 tablet wont charge or power on
Plug the tablet in, and try holding volume up + power buttons for 15 seconds or until something happens. If nothing happens, try holding volume down + power buttons for 15 seconds or until something happens.
Dec 13, 2016 | Tablets & eReaders
My nexus 7 wont go past multicoloured x.. cant switch on/off. tried hard reset and nothing works
Important:Plug your device into power outlet
Step 1: Power off Nexus 7
Step 2: Power on while holding Volume Down/Up
(enter BootLoader)
Step 3: Press Volume Up to toggle to "Recovery Mode"then press power to select
Step 4: Hold The Power Button and tap Volume Up when you see "No Command"
Step 5: Press & hold Power Button & Volume Up Button Again
Step 6: Toggle with vol down and vol up / power at wipe data (all data) & reboot
Nov 20, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
Gateway laptop i push power button it wont boot up but leds in front flash 4 times
Try holding down the power button instead of just pushing it. I had this problem with my HP dv7 and holding the power button down for around 5 seconds worked for me. Also make sure that its plugged in to a power source.
Oct 23, 2012 | Gateway Computers & Internet
I cant get the message lamp life is ending off
Unplug your projector from the power source. Hold down the On/Standby button and the Menu buttons at the same time and plug the power back in as you are holding them down. This will reset the lamp hours used and should remove that message.
May 30, 2010 | Toshiba TDP-S8 Multimedia Projector
Westinghouse dpf 1411 shuts off after 2 minutes, wont stay on
Check your settings, maybe you have an auto-off feature turned on. If this is not the case, seek professional help, it's probably a software problem.
Apr 07, 2010 | Westinghouse DPF-1411 Digital Picture...
Westinghouse dpf 1411 wont turn on power block
I would recommend contacting Westinghouse customer service team at 1800-701-0680 for further assistance in getting this frame replaced.
Dec 31, 2009 | Westinghouse DPF-1411 Digital Picture...
I have a DPF-1411. It will run thru one cycle and then freeze on last picture. Turn off-on and does same thing.
There should be a repeat setting in the menu. It is only playing once through and stopping.
Eric
Jul 02, 2009 | Westinghouse DPF-0702 Digital Picture...
Westinghouse DPF-01411 Digital Photo Frame
Things I have learned after messing with 3 different Westinghouse DPFs (1 -14" & 2 - 10").
1. Just tap the buttons. Exit first and then Menu or one of the other functions. Holding them down too long seems to nullify the functions. Only the Power button needs to be held down for a second or two to turn the device on or off.
2. Use a USB to mini-USB cable to access the internal memory. Expect flakiness when you plug in the cable. Sometimes it will warn the USB 2 device is plugged into USB1 port. Ignore this and just look for a string of removable drive letters to show up in My Computer window. The one named FLASH Drive is the internal memory.
3. I reformat the internal memory (FAT32 seems to work fine) and this gets rid of the troublesome canned pictures that may be causing your lock ups.
4. I have had good succcess the xD memory cards from 16MB to 1GB.
5. I have not seen any prblems with edited photos or long file names - just be sure they are named with .jpg extension and not .jpeg. - go figure?
Hope this helps...
Mar 30, 2009 | Westinghouse DPF-1411 Digital Picture...
Dpf-1411 locked in slideshow
To fix the freezing problem, all you have to do is change the file names to basic numbers. If you have long file names, it causes the pictures to freeze up. Change the names, and the problem stops!
Dec 18, 2008 | Westinghouse DPF-1411 Digital Picture...
My Iphone wont turn on
listen to solution number 4..I tried it and it worked. Hold the power and home button until the apple logo pops up and your golden
Jul 20, 2007 | Apple iPhone Smartphone
Computers & Internet Logo
David Payne
David Payne
