I would like to find a user manual for a White Rodgers thermostat model 1C70w-19. cAN YOU HELP?
Wiring instruction for a White Rodgers 1F78 non-programable thermostat.
The White-Rogers 1F78 thermostat is a single stage 5/2 day programmable thermostat. Home Depot has the manuals for one model of this thermostat, 1F78-151, on the product page: . The wiring diagrams are in the Installation manual. The direct link to this manual is . Emerson Climate also has the wiring diagram here: .
If you have a different White-Rodgers 1F78 thermostat, check for the manual at Emerson Climate by starting at . Click on the Enter Model Number button and start typing in the model in the search box. I found a number of models with 1F78 listed. After selecting a specific model, I found a link to the installation guide on the left side of the page, below the search box. (Note: the manual link was above the Suggested Replacement header for the models that I checked.)
I hope this helps.
Dec 15, 2017 | White Rodgers Home Security
Does white Rogers thermostat 1f56n-444 have a reset button
White Rodgers 1F56N-444 User's Manual - ManualAgent > White Rodgers Manuals > 1F56N-444
White Rodgers 1F56N-444 PDF User's Manual Download & Online Preview. ... Download Air Conditioners User's Manual of White Rodgers 1F56N-444 for free. .....Set anticipator to match the setting of your old thermostat you noted in Step 3, ..
Aug 04, 2015 | Home Security
I need wiring diagram for thermostat white rodgers
Hi. This is Aaron Moratalla from White Rodgers. See this link for the copy of manual.
Wiring connections are on page 7. If you need more help don't hesitate to call Tech Support at 800-284-2925. Thank you for choosing White Rodgers.
Jan 17, 2013 | White Rodgers White-Rodgers 1F85RF-275...
Model 1f90w-51 the up down buttons stopped working this is a white-rodgers
Electronic Digital Multi-Stage Thermostat 1F83-261
  • 1F83-51 - White Rodgers Installation and Operating Instructions Thermostat 1F83-51
  • 1F86-344 - White Rodgers owners manual Thermostat 1F86-344
  • 1F86-444 - White Rodgers Installation and Operating Instructions Thermostat 1F86-444
  • 1F87-251 - White Rodgers Thermostat 1F87-251 OPERATION INSTRUCTIONS
  • 1F87-51 - White Rodgers Installation and Operating Instructions Thermostat 1F87-51
  • 1F89-11 - White Rodgers Installation and Operating Instructions Thermostat 1F89-11
  • 1F90-51 - White Rodgers OPERATION GUIDE Thermostat 1F90-51
  • Hi, This is a good stat and I have used it alot in the past as it is a older model. If you have 24 volt control voltage at the stat, and the battires are good, then you have a malfuntion in the ciruitry and will need to replace it. I have sent you a ton of manuals on there products I thiught they may be helpful. Please dont forget to rate this post as I know you will be kind. I hope I have been of help to you.
  • Sincerely,
  • Shastalaker7
  • A/C, Heating Contractor
Sep 22, 2010 | Heating & Cooling
WE need a copy of the instruction manual. Is there a site where we can download a copy? White and Rogers programmable thermostat - 80 Series. Thanks for your help! Fred Skoglund
check this link : Don't Know Your Model Number?
after you verify the model number check our website
put the model number on the White-Rodgers Model Number Search/Cross Reference then click submit this will lead you the way on how to secure a soft copy of the instruction manual. If you having difficulty you can call hometechline 18002842925.
Aug 10, 2010 | White Rodgers White-Rodgers 1F85RF-275...
The snowflake is displayed on the screen when the system is in cool position. check page four of the installation manual
May 26, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Need a thermostat manual for a Comverge Model 1F88-290
That thermostat is handle by White- Rodgers, call hometech line 18002842925, then provide them an email address or a fax they will send you a softcopy.
Mar 18, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
