Question about Refrigerators
Wat temp is for fridge and freezer to be on plz
    Top Expert:
  • Refrigerators Master
  • 8,211 Answers
What are your recommended temperatures for the fridge-freezers? The default and recommended temperatures for our fridge-freezers are as follows:-
4?c for the fridge compartment, 5?c specifically for the fruit and veg compartment, and -20?c for the freezer.
The ideal temperature setting for a refrigerator is 3?C and for a freezer it's -18?C. The only exceptions are fridge-freezers in the RB*** range, for which we recommend -19°C (as -18?C isn't an available option for these models).
Keep your fridge at the perfect temp with these handy tips
Posted on Dec 04, 2016
My Westinghouse RS662V fridge is not cold at all. I have turned the dial to full cold but it has made no difference. The freezer seems to be working OK. Could it be the thermostat in the fridge?
Yes you need to adjust the thermostst located inside the fridge compartment to change the temp. setting of the fridge.
Regards.
PLZ. dont forget to rate my suggestion.
Jul 19, 2011 | Frigidaire FRT18G4A Top Freezer...
Freezer working /fridge not
You most likely have a failure in the defrost circuit. One or more of thee possibilities: Heating element, defrost timer and/or defrost thermostat.
Check these links:
http://appliancehelponline.com/defrostheatervideo.html
http://appliancehelponline.com/referdefrostheater.html
May 31, 2010 | Maytag MBB2256G Bottom Freezer...
Refrigerator not keeping temp.
There is normally a fan in the freezer (usually removing the back panel from inside the fridge will show it [sometimes you need to pull the bottom panel of the freezer off] The panels are normally secured with phillips head screws.). If it doesn't turn, it probably needs replacing. Make sure the coils are not iced over. [unplug while removing panels, then plug back in... the temp will have risen in the freezer so the fan should come on right away].
Make sure that the "vents" in the freezer (bottom of the freezer - in the front back or both) are not covered.
Some fridges have a separate control for fridge temp, make sure that was not moved, or try setting to a colder setting.
Sep 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is too cold (-14 degrees) and fridge is too warm (51 degrees). The freezer keeps gettting colder but the fridge part keeps getting warmer.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
The temp sensor for the freezer may be reading the warm air in the fridge so is not cutting the compressor off.
Sep 25, 2009 | GE Profile PDS20MFS Bottom Freezer...
Freezer works great, but fridg. will not get below 50
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 17, 2009 | Maytag MZD2766GES Side by Side...
Fridge (KBRA22KLSS00) has lower freezer compartment. Fridge is running, & freezer is cold,however upper portion of fridge is not cold. Is there a fan or a control to bring the cold into the fridge...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 31, 2009 | Refrigerators
Freezer works, fridge part does not
Aug 21, 2009 | Refrigerators
Freezer woks fine but the fridge not working
sounds as if the evaporaator fan inside the fridge between the fridge and freezer is out. This fan is located between the freezer and fridge in the same area as the control switch for the temp. This fan isn't hard to replace you just need to take care of the removal of the plastic cover. Once the cover is removed the fan is accessed easily. Take the model and serial number to an appliance parts house for the proper part. Good Luck
Dave
Jul 22, 2009 | Whirlpool ET4WSKXS Top Freezer...
Servis frost free fridge freezer makin crackin noise afew tyms a day
this is not unusual on any make. the cracking noise is the cabinet creaking with change in temperatue. don't worry about it
Oct 18, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
