Question about Refrigerators
My Kitchen Aid model# KBFS22EWMS9 is not making ice. Water is formimg in bottom of freezer and freezes to ice. I can't really see where water is coming from.
It's possible it looks as if the water is comimg from like the back wall inside the freezer vent piece. Also i might have water leaking elsewhere. Water comes out of water dispenser just fine. I don't have a filter on. I just have the plug in it.
  • Refrigerators Master
  • 4,654 Answers
That sounds like the defrost drain is blocked you will need to clear the drain or have someone do it for you
Leaking Refrigerators
Posted on Dec 04, 2016
My Kitchen Aid Refrigerator model KFCS22EVMS8 is leaking water . I was told that I should clean the drain pipe. How can I clean it and stop the leak? Thanks
The drain is plugged up from ice and debris that comes off the food in the normal process of working. You may have to remove the back panel in the freezer and pour hot water in the drain area at the rear bottom if the freezer under the coils. After thawing the ice it would be a good idea to run a short piece of 1/4 inch plastic hose, maybe about 18" or so, down the drain to push any debris through the hose. Flush it out well with hot water and this should be good for several years.
Sep 13, 2014 | Refrigerators
How to defrost freezer in kitchen Aid bottom drawer freezer
My kitchen aid bottom drawer freezer kept melting and freezing to block the drain and then water would leak out all over the floor. I did the WHOLE fridge/freezer defrosting process once, when i really just needed to do the bottom.
I have had issues with other Kitchen Aid (NEW BTW) appliances so I've talked to many repair people. One guy who came out to fix something else, told me that the freezer is really a pain to get to close completely. SO, when you don't close it all the way (Extra push) it will melt and then re freeze when it is closed properly. He suggested I take everything out, leave it open and use a hair dryer on the ice until it melts. Then use a wire hanger to unplug the drain to make sure its draining properly.
It works! You really have to make sure the drawer is shut ALL the way. I have a 2 yr old who is constantly opening it up...this is my issue! The seal is not that great and you have to really push it closed to prevent the ice build up issue.
Hope that helps!
Sep 10, 2013 | KitchenAid Refrigerators
ICE AND WATER DISPENSER WILL NOT WORK ON KITCHEN AID MODEL # KSCS25FKSS01
if neither one works that usually is the water valve located on the back of the fridge. Try this manually fill the ice make with a glase of water and check the temp. in the freezer. you can reach in and touch to see if water is freezing in ice maker. see if it dumps the ice then surly the valve is bad
Apr 21, 2010 | KitchenAid KSCS25FKSS Side by Side...
Water not flowing from Kitchen Aid Refrigerator. I've switched the filter and it has not resolved the problem. the unit is one year old, was working properly. 2 days ago, water leaked from spout and that...
water maybe frozen somewhere in the system. may need to disconnect water connections at various points and retry to narrow down where freeze up is at.
Jan 06, 2010 | KitchenAid Refrigerators
I have a kitchen aid refrigerator freezer. The
the supply line of the ice maker might be blocked please check it.
Aug 18, 2009 | Refrigerators
I have a Kitchen Aid side by side KSRS25IL. The ice maker after
Sounds like you need to defrost.
if you can move everything out unplug it ,turn it off w/ doors open,you can put pans of hot water in the freezer to speed up the process 12 to 24 hrs this will free up any clogged tubes.After its completely defrosted Only turn it up to 4 or 5. Good luck.
Len West
Feb 27, 2009 | KitchenAid KSRS25IL Side by Side...
Kitchen Aid Model KBLC36MHS01
The drain under the evaporator is frozen/plugged.  You can take the back panel inside the freezer off and run hot water down it to thaw it out completely and this will solve your problem.
Oct 17, 2007 | Refrigerators
Refrigerators Logo
79 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
