Question about Health & Beauty
Set food scale to "0" - Health & Beauty
    Top Expert:
  • Health & Beauty Master
  • 8,204 Answers
And what is it you are asking
Posted on Dec 04, 2016
Digital food scale will not turn
It is possible the replacement batteries could be defective or installed incorrectly.
Sep 11, 2016 | Taylor 3843-49 Digital Food Scale 11 Lb /...
Refrigerator freezing food
Let's start at the easy part. The thermostat should be set mid range if a dial thermostat. For example, if scale on thermostat is 0 to 9, set to 5. This is the most common problem and solution. If refrigerator is frozen, you may need to defrost unit by turning off and let thaw until unit is defrosted.
If you have a refrigerator with a damper, the damper could have broken off and the circulation fan in the freezer is circulating cold air continuously. To get part go to with make and model number and get drawings of various systems. You can order parts and get them them in couple of days.
Hope this helps!
Apr 19, 2016 | Maytag Refrigerators
I need a free user manual for a chefmate digital scale. Where could I find one?
Dec 31, 2014 | Health & Beauty
How to replace rubber wheel rings on a bachmann 0-6-0 ho scale steam engine
carefully remove the drive rod from the wheel, slip traction tire on the wheel and into groove in the wheel, replace drive rod. play with your train!
Feb 03, 2014 | Bachmann Ho Scale Trains Steam Engine...
How to reset as scales are not weighing properly and new batteries have been inserted
These scales cannot be calibrated so i'm afraid that it's time for a new set. I think they were first manufactured in 2002 and they have a 10 year guarantee which meas you are out of luck. If you are in the UK, this site is a good place to start looking for another set of All Kitchen Scales
Jan 23, 2014 | Taylor Salter 1010 Stainless Steel...
Why does scale print extra label?
sounds like it is setup to print a secondary label. go into supervisor mode 10 and check to make sure the secondary label setting is at 0
Aug 22, 2012 | Hobart Quantm1-1ss Quantum Self-service...
What temperature should my maytag side by side freezer be set to it has an ice maker and water dispenser thanks
Your refrigerator temperature should be between 35-40 degrees F, the freezer should be 0-8 degrees F. Both of the control settings should be in the middle, so if its on a scale of 1-9, 5 is middle, if its on a scale of A-J, E or F would be the middle, if its a temperature setting, 37 and 0 is normal setting.
Nov 09, 2010 | Maytag Refrigerators
Food in the fridge part keeps freezing even with setting at highest temp
if its at the highest setting, i.e., the largest number or letter, you have it at the COLDEST setting, and it will freeze in the refrigerated secion. Reset all controls to normal, which is the middle setting. so if your scale range is 1-9, middle setting would be 5, if scale is A-E, middle is C and so on.
After you reset controls, it will take 24 hours for temps to balance themselves out. Your food may take longer to thaw out, so dont go buy whether food is still frozen, instead place a thermometer in the center of the fresh food side. your fridge temp should be in the 35-40°F range. If after 24 hours your fridge section is still below 32, Then you do have a problem, but LG is not a simple unit to diagnose, impossible to do without inspection.
Mar 08, 2010 | LG LRSC26925 Side by Side Refrigerator
I just changed the battery and I keep getting the temperatures in Celsius instead of Fahren. How do I change it to F?
You need to discinnect the battery and reinstall it. When you reconnect the battery press the 'SET' button within 15 seconds. The temperature reading will now be set to Degrees F.
See below.
Setting/Changing ºC and ºF Temperature Scales
The food safety thermometer can display temperature in either the °C
(Celsius) or °F (Fahrenheit) scales. The desired scale is selected at the time
the battery is installed:
Selecting the °C Scale:
When the battery is connected to the battery leads the °C scale indicator
shows on the display for approximately 15 seconds. If the SET button is
not pressed the unit will time out and default to the °C or Celsius scale.
Selecting the °F Scale:
If the SET button is pressed within 15 seconds of connecting the battery to
the battery leads, the temperature scale display will toggle to the °F scale
indicator and the unit will now default to the °F or Fahrenheit scale
Feb 28, 2010 | Fluke Networks Fluke/Raytek FoodPro Plus...
My bathroom scales ww35cha stopped working, i replaced the battery and now the scales turn on, but do not display a weight when u step on. Instead the weight shows '0'
you have 4 button on this model
1 tap the scale to start, it show 0.0
2 tap set to set person and height, age ...( use set, up, down buttons )
when start use
1 tap scale to start , show 0.0 again
2 tap user again and again to choose your user
3 wait after it show your height, age, then it show 0.0 step on the scale and you're done.
i've been through becuase my friend lost his instruction manual.
Now it wook
Have Fun
Nov 16, 2009 | Conair Weight Watchers WW35 Body Fat Glass...
Health & Beauty Logo
116 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Are you a Health and Beauty Expert? Answer questions, earn points and help others
