Question about Pool & Spa
My balbo hot tub switches it self off but doesn't blow the breaker, I then have to reset it from the breaker, it will go through the pre checks then cut out again.
  • 151 Answers
SOURCE: 115 volt 20 amp breaker for hot tub keeps tripping
Is there anything else on the same breaker? Is that the proper amperage for the pump? How long has the pump been in service? It may need to be cleaned as possible obstruction causing too much strain.
Posted on Dec 28, 2008
  • 102 Answers
Most likely you have a bad or weak circuit breaker. Consult an electrician for breaker change out. Make sure that it isn't hooked up with a GFI plug. They will not work on a GFI.
Posted on Apr 01, 2009
  • 3433 Answers
SOURCE: Bryant Legacy Air Conditioner doesn't blow out cold air
Unplug the unit with all controls off, then plug back in and wait 5 minutes before turning on switct at unit. Good luck
Posted on May 27, 2009
  • 1723 Answers
SOURCE: i have a 45 amp breaker for a hot water heater
Sounds like a bad breaker, replace.
Posted on Jul 01, 2009
  • 98 Answers
SOURCE: breaker relay tripping out
If the unloading valve trips , which i think is the safety valve that tells me the compressor is pumping up past its maximum allowed pressure. that black switch should be the overload switch. check the amps of the wires going to the motor while its running and then look at the name plate of the motor to see the maximum amount of amps that the motor is allowed to draw.
Posted on Jul 21, 2009
I have a spa berry 2 person hot tub. Tried resetting it but as soon as I let go of the reset button it trips the breaker. Can't get it to stay on. Tub is 4 yrs old. Where do we start?
Melisa, Breaker/GFI may be going bad. You may have to get an electrician to check for short or faulty motor/heater, etc. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Troubleshooting tripping hot tub GFCI breaker
Hot tub GFI keeps tripping
Spa Circuit Breaker Mysteriously Tripping Any Clues Portable Hot Tubs amp...
Jun 27, 2016 | Pool & Spa
Goodman minisplit flashes on pre. Def. Wont start
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset.
Air Conditioning Repair Tamarac
Apr 07, 2015 | Goodman Heating & Cooling
Circuit braker keep popping
Sounds like the heating element has gone out again. Once you reset the circuit breaker and the tub turns on it will start to circulate the water. This usually runs like this for about 2 mins and then the tub will recognize it is cold and send power to the heater. If the element is back at that point it will blow the circuit breaker.
If this circuit breaker pops as soon as you turn it on then you most likely have a bad circuit board.
Jan 30, 2013 | Jacuzzi Home
My hot tub i dont no how too turn it on or turn the heat up
There should be an independent circuit breaker to control the tub, most commonly a 50 amp GFCI breaker. (Has a "test" button on the breaker itself) It is usually located either in the vicinity of the spa in a gray box, or in the main circuit breaker panel of your home. In rare instances, they may have used a "fuseless disconnect" either in the spa equipment compartment, or within the vicinity of the spa. (at least 6 ft. away from spa) The disconnect is simply a removable lever that you pull out to disconnect power to spa. I would advise you search for a breaker or disconnect. If you locate the breaker, switch it off, then back on. If you locate a disconnect, pull it out, ensure that it is inserted in the correct way, then re-connect it. If that doesn't work, check for a GFI on the equipment pack itself. It would have a "test" and "reset" button on it. Press the test, then reset button. You should hear a distinct "click" when the test button is pressed, and the reset button should stay in once pressed after that. If it does test and reset properly and the pump, etc doesn't work, then you have a problem in the control pack. (Either a fuse, or a component that an average consumer cannot diagnose or repair.) That being the case, you should call a qualified spa technician. Hope this helps.
Dec 31, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
My electric went out for 24 hours. I hooked up my generator to the breaker box to power the house. The generator only powers one 110 leg so there would have been 110 going to oneside of the 220 breaker to...
You should start with checking all your breakers to be sure the breaker did not pop just half of your breaker. This is something you should do with all your breakers. When you do this you should shut down all your 220v breakers so you don't get bleed back through the system. Other than that you need to look for resets on the tub. The heater is a good place to start and don't forget the gfci's on the tub or in the bath or laundry room.
Dec 13, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
240 w/60 a outside breaker with test switch wont'
Inside the controller box is a red button to reset it but most likely the heater element is shorted out so replace the heater element first. Cost $100.00 at any pool or spa shop. Post here if you need more help.
Sep 28, 2009 | Siemens 12 Q115u 15a Circuit Breaker, Qp
How to turn on hot tub
Check at the plug in if it has a normal plug like in your home first. Should be a set of buttons there, called a GFI. One is test, and the other reset.Push reset to see if spa comes on. Most spas dont have an actual on button. Check breaker box for popped breaker also, maybe tub is having problems, and needs a service call. Also larger tubs ussually jave a gfi or fuse box outside, close to tub. Kirk
Dec 01, 2008 | Pool & Spa
Pool & Spa Logo
124 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
