Question about Precor Exercise & Fitness
My Precor 9.41 si treadmill won't let me click the switch to the "on" position. When I go to push it to the "on" position, it resist and spring back to "off".
    Top Expert:
  • Precor Master
  • 40,706 Answers
Is the safety key inserted as there may be a connection to not allow the unit to operate unless the key is in position
Posted on Dec 03, 2016
  • Anonymous Dec 04, 2016
    yes, I checked the safety key. You are right, it won't work without it but in this case, I have it in place. thanks
Precor 9.27 treadmill won't slow down
Hi, It's probably the speed censor. Clean it up and should be good to go. When you disasemble it clean all other parts and put back togeather. Good luck
Jan 23, 2014 | Precor 9.27 Treadmill with Ground Effects...
Precor 927 stuck in incline position
How long have you let it run for after turning it back on ? Some treadmills have a re calibration test built in and will incline to the max and work its way down. During this time you should simply walk away and not touch anything as it trys to calibrate its self. If not i will need more information on it
Oct 10, 2012 | Precor 927 Treadmill
Precor 9.27 Control Portion Not Turning On
1) Reset the c.breaker from your house
2) See the c.breaker or blown fuse in your treadmill see the block diagram +c. diagram
3) Try again, and proof.
4) Test the main switch from treadmill, and replace if necessary for OPEn, see the diagram how to do it.
God bless you
Jun 10, 2012 | Precor 9.27 Treadmill
C956i Precor is displaying Error code 44 ?
Precor Error 44, Un-commanded Lift Motion Probable Cause 1. Intermittent or bad connection in the lift position sensor(potentiometer).
2. Lift position sensor (potentiometer) is bad.
3. Lower PCA is bad.
Corrective Action
  1. Bad or intermittent connection of the lift position sensor (potentiometer) is the most common cause of the error 44. Inspect all wiring and connections related to the lift position sensor (potentiometer). Repair or replace wiring connections as necessary.
  2. Monitor the lift position number displayed while operating the lift in diagnostics mode. If the reading makes large changes or is erratic, the lift position sensor (potentiometer) is likely bad. Replace the lift position sensor (potentiometer) or lift motor if the lift position sensor (potentiometer) is internal to the lift motor.
  3. If the lift moves without any command entered either manually or through a program, replace the lower PCA.
Precor Error Code 44
May 30, 2012 | Precor C956i Treadmills with HR /...
Precor 9.25i treadmill will not turn on at on/off switch. It throws a spark then immediatly turns off
With a few more details I am sure we will be able to work through is issue together and get you back into your exercise program shortly. If you would please give us a call at 1-800-347-4404, one of our technicians will be more than happy to assist you. Please give us a call at 1-800-347-4404 Mon-Fri 6AM-5PM, except Thur 6AM to 3PM, Pacific time.
- Precor Customer Support Team
Feb 28, 2012 | Precor C966i Treadmill C 966i
Precor treadmill error L5
Precor Error LS, Speed Sensor Signal Missing Probable Cause 1. Intermittent or open connection of the speed sensor (reed switch) wiring.
2. Reed switch is defective or has intermittent connection.
3. Drive motor brushes are bad.
4. Lower PCA is bad.
Corrective Action
  1. Inspect the speed sensor (reed switch) wiring for damage or poor connection to the lower PCA. Replace damaged wiring or reset connection as necessary.
  2. Using an ohm meter, test the reed switch while rotating the drive pulley. The reed switch will close when the magnet passes in front of it.
  3. Inspect the drive motor brushes and replace if necessary.
  4. Test unit with a known good lower PCA. Replace lower PCA if nec
Precor Error Code LS
Feb 25, 2012 | Precor 935 Premium Series Treadmill
Where is the saftey switch on the precor 9.45i treadmill
You are refering to Reed switch or Sensor switch or Speed Sensor? please indicate.
Some equipment can have the safety switch when you remove the Hood as security measure, for to avoid the machine goes on or Start ON .
Please specify.
sincerely.
Nov 06, 2011 | Precor 9.21 Treadmill
Treadmill won't turn on, I get a slight shock when I click the on/off switch.
Dear Sir:
Thank you by you request, I will help you inmediately.
Please do this with very Carefully!!
The shock is a build upof static electricity on your body called Electrostatic Discharge (ESD).Friction between the walking board and belt can generate static electricity.
If experienced, the shock is not harmful ordangerous.
Thank you in advance, sincerely. God bless you.
IF YOU NEED FURTHER ASSISTANCE, PLEASE CONTACT ME
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Sep 27, 2011 | Precor 9.21 Treadmill
I have a C956 treadmill. I am getting error code 44, can you tell me what that means?
Corrective Action
Jan 04, 2011 | Precor C956 Treadmill with Cardio Theater...
Will switch on but the enter button will not work and the other buttons will only work occassionally. we have a precour 9.21s
hi
check the push button (micro switch) for enter. may be it faulty. if found faulty replace it. its a cheaper one.
ok
Dec 26, 2010 | Precor 9.21 Treadmill
Exercise & Fitness Logo
46 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
