I have a hisense XQB70-XC14 7kg top loader. My machine keeps saying e4 error just before the rinse cycle. I've tried putting the machine on a levelled surface and even setting the clothes evenly.
  • Monica Grey
    Monica Grey Dec 15, 2017
    I have the same problem...any idea what's wrong and how to fix it?
    New Friend:
    Problem Solver:
  • 6 Answers
I take it does not rinse or drain?
Posted on Dec 15, 2017
  • 1294 Answers
SOURCE: Machine not spinning due to uneven load balance although clothes are loaded evenly initially
I suggest you stick to the maximum load capacity (or less) of the machine; and not over-load the machine with clothes.
Posted on Apr 14, 2007
Coldcut
  • 1554 Answers
SOURCE: kenmore 90 series stops after rinsing
Check or change the lid switch. Unplug the washer. Check the actuator on the lid that operates the lid switch to see if broken
here is a site with more info
http://www.applianceaid.com/procedures.html#remove
Posted on Feb 02, 2008
  • 351 Answers
SOURCE: hoover 600mb 6.0 kg top load washing machine (not as below)
timer or timer module fault
Posted on Mar 02, 2008
SOURCE: Computer board shows UL even when very few clothes are in the washer
try to unplug and plug back after 30 seconds.
Posted on May 09, 2008
proJekttaLon
  • 91 Answers
SOURCE: after the spin cycle runs the clothes are still soaking wet
I had that problem at one time with my old washer and what it ended up being was the Washer Dog Agitators were broken and causing the it to slip and not spin correctly. I would try checking the Dog Agitators.
Here's A picture of a typical top-load washer breakdown to show you where they are located --->Here<---
I hope this helps. If that is the problem I bought mine at Sears for about $8, normally in stock item.
moz-screenshot-2.jpgLet me know if there is anything else I can do.
Posted on May 25, 2009
I have a hisense 7kg -xqb70-xc14 auto washing machine and it can wash but when it comes to rinse, it stops and gives an error of ES
Possible the pump is blocked with any kind of stuff went into the machine or the pump is defect . the Maschine have the opener in front of that Pump . you need to open it to look is there something what blocks the Pump . you can feel with your Fingers is the Pump Turning .
Dec 15, 2017 | Washing Machines
Defy top loader. What is e4 error?
Generally the E4 error means that the tub is unbalanced. You either filled the washer unevenly, or you are trying to wash something too heavy or too large. Take everything out of the machine, and then re-arrange it and put it back in. If you are still getting the error, you need to wash less clothes at a time.
Another possibility is that your sensor needs replacing, the sensor that tells you how full the tub is and when it's off balance. For that, you need to call a repairman.
Jan 22, 2016 | Washing Machines
Samsung WA5471ABP 4.7 cu.ft. VRT PowerFoam Top Load Washer spin cycle error
This is a common problem, check to make sure machine is level an not on a lean, also check the machine feet are all wound down so machine sits firm.if all good then it may be worn out suspension rods
Sep 26, 2017 | Samsung WA5471ABP 4.7 cu.ft. VRT PowerFoam...
Machine Running noisy during cycle
lift off spray arm and remove motor rotor and remove any debri this can cause a noisey motor.
Sep 04, 2012 | Fisher and Paykel 24 in. DD603H W Built-in...
Hi i have a 5.0 kg. samsung SW5OUSP washing machine as i turned it on it stopped in rinsing cycle and the message says 5E
5E. Water Drain Error.
5E is displayed if the water level frequency detected os 25KHz or less in the initial phase of the UNB - detecting cycle. The WATER DRAIN ERROR
can be rectified by turning the POWER SW OFF AND THEN BACK on.
Hope this helps you
Feb 01, 2012 | Samsung Washing Machines
Why won't my whirlpool model #LSR8233JQ0 go through the rinse cycle or the spin cycle
i have no info on this model, but if its a front loader then you will be looking at your drain pump motor as at the start of the rinse and spin cycles it will need to drain if it cannot it will not even attempt to continue on, so take that little drain pump cover off and have a look inside the propeller it may just be jammed up, if not it may be blocked somewhere along the hose or just a faulty pump altogether, if its a top loader you will be looking for the same thing but if it isn't the pump it will be the lid switch that senses the lid has been shut as all whirlpool top loaders must be able to activate the lid switch or else it cant spin (simply a safety feature to prevent injury), get back to me if you have any questions
Nov 21, 2011 | Whirlpool Washing Machines
Hoover 750 top loader goes through cycle drains but will not spin if you manually put it in spin it will not stop fills up and rinses drains but will not go again into spin until manually do it then again...
Two issues are possible , After the first start of the wash , check if the machine starts only when the water level is reached- to confirm the working of the water level sensor.
Secondly if the program cycles seems out of hand then it is possible there are errors in the program controller unit.
Apr 21, 2011 | Washing Machines
Washing machine off balance in one cycle
Make sure washer is on a level surface and all four feet adjusted properly. A slight forward lean may help with this problem as the out of balance switch is at the rear.
Feb 28, 2010 | Washing Machines
My washer stops before the rinse cycle because it can't seem to drain enough to start the spin cycle. I just had the drain motor replaced one month ago. I get the error code nd. I can sto the cycle and...
I'd love to say yes! The machine is stopping because it will not drain. This is what the nd code means. Therefore, it will not rinse (add more water) or spin because the water level is already too high and to try to "spin it out" would put too much pressure on the machine with that much water in it. Drain out the water by putting the drain hose below the level of the washer (this takes forever) and call your repair man back!
Feb 18, 2010 | Maytag MAH8700A Front Load Washer
Beumatic
The E4 code means - Overfilled. To much inlet water. Remove water manually from the tank pan and try operating a new cleaning cycle. Good luck !
May 31, 2007 | Baumatic 23 in. BDW14 Built-in Dishwasher
Washing Machines Logo
107 people viewed this question
Top Washing Machines Experts
