Question about Exercise & Fitness
Where does the oil go on the tx200 treadmill - Exercise & Fitness
    Top Expert:
  • 8,204 Answers
Tx200 sportcraft treadmill
Grainger usually has the best products at a reasonable price
Item # 44N745
Silicone Aerosol, Container Type Aerosol can, Size 11 oz., Temp. Range -40 Degrees F to 500 Degrees FVOC Content 55 Percent, Specific Gravity 0.72O-rings
Oct 15, 2013 | Sport & Outdoor - Others
see the video attached and proceed according. God bless you
Jun 13, 2013 | Exercise & Fitness
How to download the installer of epson?
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port
you might see a yellow question / exclamation ? ! mark or a red X this will mean you need to install a new driver for this device right click to update driver
hope this helps
Mar 14, 2012 | Epson Stylus TX200 Series
Replace inside bulb of projector lamp for Hitachi
check the site below
thats the manual
Jan 09, 2011 | Hitachi Cine Master PJ-TX200 Multimedia...
I have aI have a sportcraft treadmill that stops working after 7
You will need to check the speed sensor for proper alignment and function. it should be located near the front roller or mounted on the motor. It should be within a credit cards width of the magnet or toothed wheel. If properly adjusted check with an ammeter to see if it is opening and closing by manually spinning the front roller or motor flywheel. If it isn't replace the sensor. If it is functioning make sure you are getting 5vdc to it across the wires. If you are not replace the upper control board(console). If you are getting the proper voltage then replace the lower control board(motor controller).
Jul 31, 2010 | Exercise & Fitness
I have a sportcraft tx200 treadmill that will not power on, I have fliped the switch on by the supply power cord also. What are some potential problems?
Test for voltage going to the treadmill, if there is no power going to the treadmill then check the fuse or breaker in your house. If you already checked the house fuse/breaker then try this.
first thing is check for any loose connections or bad wiring and then follow the steps below to try and determine what is wrong with your treadmill.
* Check the breaker on your treadmill it can be combined with the on/off switch or it can be a separate breaker. Make sure it is not open.
* If that tests ok, check to see if your getting power to the motor controller(electronic board under the hood) this can be done by following the power cord in and testing where they attach, if you are getting 120/240 volts then check the light(s) on the controller If they are not lit then the controller is bad.
* If they are lit you will need to check the dc voltage going to the motor
* Also make sure you have voltage going to the console
if you have 8-12 vdc voltage to the console and the console is dead replace the upper control board.
* If only one or none of these voltages are present then the controller is bad.
* If your treadmill is equipped with a separate power board then you will need to take voltage readings going in and coming out from the board If nothing is present then the power board is bad. If all tests well move on to the controller.
* some motor controllers are equipped with a fuse on it, if this is blown the console will not light as well.
* Hopefully it is just a breaker.
* Make sure you are lubricating your treadmill as well on a regular basis. Too much friction can wear out electronic parts and reduce the life of your treadmill. Use the appropriate lubricant recommended for your specific model and never use an extension cord.
Thank you for the question and please feel free to contact me again with any questions or problems you may have.
Jul 24, 2010 | Exercise & Fitness
Exercise & Fitness Logo
54 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
