Question about Miscellaneous
Can I order #120974 on line? - Miscellaneous
Move a hunt group button to different position on set
Hunt group buttons are just like lines, they occupy to first buttons on the phone. The only way to move a hunt group button is up or down the list of lines. If you want it first, you have to remove all assigned line from the extension to be changed this includes the hunt group. Now come out of programming and go back in to the extension. Add the lines or hunt group in the order you want them. NOTE IF THE LINES ARE TO BE OUT OF ORDER NUMERICALLY, YOU HAVE TO ADD THE ONES THAT ARE IN ORDER AND LEAVE PROGAMMING AND COME BACK IN AGAIN. THIS SETS THE ORDER OF APPEARANCE.
Apr 10, 2013 | NorStar M7310 Corded Phone
Firing order
In-line four-cylinder engine ignition order is: 1-2-4-3 and 1-2-4-2;
In-line type 5 hair hijacking ignition order is: 1-2-4-5-3
In-line 6 cylinder engine ignition order is: 1-5-3-6-2-4 or 6-2-4-1-5-3;
want to know more auto diagnostic tool
Mar 14, 2013 | 1996 GMC Jimmy
Fuel line
Ask for the 2 lines coming off the sending unit. to the main line. That should be enough for ordering them. be sure to change your feul filter while you're there good luck
Jan 01, 2013 | 1999 Pontiac Sunfire
BIS-10 Phone - How to change default line
If you have a "squared" system (each line assigned to a different button), just press a different line button. To change the order of the lines, slide the "T/P" switch to "P" and press the line buttons in the order you want to use them (ie: Line 4, Line 3, Line 2, Line 1).
If your lines are "pooled" you just get the next available line from the pool - no choosing which line you get.
Hope this helps.
Jun 21, 2010 | AT&T Merlin BIS 10 Phone
Firing order diagram for 94 vw gold
For the 1994 VW Golf:
I do not know if you have the 1.8L SOHC In-Line 4-Cylinder or the 2.0L SOHC In-Line 4-Cylinder; however I have included both below:
For the 1.8L SOHC In-Line 4-Cylinder
Firing Order:
1-3-4-2
Cylinders:
..........(back).........
|...1....2....3....4...|
..........(front)
Distributor:
...(back)
(+)....1
...2.........3
........4...(+)-screw
For the 2.0L SOHC In-Line 4-Cylinder:
Firing Order:
1-3-4-2
Cylinders:
..........(back)..........
.........(front)
Distributor:
......(back)
.....2.......1
(+)............(+)-screws
.....4.......3
......(front)
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
May 27, 2010 | 1994 Volkswagen Golf
1996 dodge stratus firing order spark plugs
For the 1996 Dodge Stratus:
I do not know if you have the 2.0L SOHC In-Line 4-Cylinder, or the 2.4L DOHC In-Line 4-Cylinder or the 2.5L SOHC V6; however I have included all three below...
For the 2.0L SOHC AND 2.4L DOHC In-Line 4-Cylinder:
Firing Order:
1-3-4-2
Cylinders:
.........(front)
Ignition Coil:
.....................o <---4
1---> o
.....................O <---Connector
2---> o
.....................o <---3
For the 2.5L SOHC V6:
Firing Order:
1-2-3-4-5-6
Cylinders:
|...1....3....5...|
|...2....4....6...|
.......(front)
Distributor:
.......(back)
....(+)....5
..4...........3
Let me know if this helped......
May 17, 2010 | 1996 Dodge Stratus
Firing order for 92 plymouth laser
For the 1992 Plymouth Laser:
I do not know if you have the 1.8L SOHC or 2.0L DOHC (or Turbo) In-Line 4-Cylinder Engine; however I have included both below.
For the 1.8L SOHC In-Line 4-Cylinder:
Firing Order:
1-3-4-2
Cylinders:
..........(back)...........
.........(front)
Distributor:
.....(back)
..............1
.................3
...4
.....(front)
For the 2.0L DOHC (AND TURBO) In-Line 4-Cylinder
Firing Order:
1-3-4-2
Cylinders:
...........(back)..........
..........(front)
Ignition Connections:
(back)
...3
...2
...1
...4
(front)
May 07, 2010 | 1992 Plymouth Laser
Is there 2 sizes of gas lines on a 1995 GMC jimmy
theres a pressure and a return, the pressure line is ALWAYS the larger of the 2
Oct 22, 2009 | 1995 GMC Jimmy
I need to replace the metal racks in the u line 75wc refrigerator. They rusted in the back.
To order the racks you will need to order from a parts distributor. To find one in your location just visit U-line. www.u-line.com and under customer service you will see parts locator.
Sep 26, 2009 | U-Line 75WC Wine Cooler
Miscellaneous Logo
15 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
