By 2Pansy - usenet poster
simple question:
Is it possible to build g++ 2.95.2 and to use it
with non-trivial C++ code
on a Compaq ES40 (latest version of Tru64) ?
Thanks for any help,
Markus
Solution #1
posted on Aug 09, 2005
maartenw - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
If the non-trivial C++ code is ISO conformant, you should try to install
the STLport-4.x C++ library. Just drag in the header files before the
ones that come with g++ using the -I switch.
If the code is too non-trivial you may encounter link problems with
stlport, for simpler programs I remember this combination working.
As I recall the link problems are claimed to indicate a problem in the True64
linker (True64 4.0) (my memory is weak here). I think there is
something pertinent in the docs coming with stlport or gcc.
I gave up at that point (waiting for gcc-3),
since cxx and its library are quite close to the standard.
Stefan Schwarzer office: +49-(0)711-685-7606 fax: x-3658
Uni Stuttgart, ICA 1 e-mail: s @ica1.uni-stuttgart.de
Pfaffenwaldring 27 pgp public key available on request/finger
70569 Stuttgart, Germany http://www.ica1.uni-stuttgart. de/~sts
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
kioner - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Thanks.
Markus
Markus Diesmann MPI fuer Stroemungsforschung
Tel. : +49 (0)551 5176 417 Bunsenstrasse 10
Fax : +49 (0)551 5176 439 D 37073 Goettingen
EMail: diesm @chaos.gwdg.de http://www.chaos.gwdg.de/
Markus
Suggest a new solution for this problem
Post a New problem for Compaq Refurbished SYSTEM BOX
Email this problem
Email this problem
Can you Help with these PC Cases problems?
Repair Service
Find PC Case Repairman Near You:
