Question about Dyson DC25 Vacuum
Dc25,brushes won't turn, no blockage and belt is good. I tried testing for power to brush motor and switches work properly
    Master:
  • Dyson Master
  • 894 Answers
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dc25
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Posted on Jan 12, 2017
    New Friend:
You have to lower the handle for the brushes to turn. Also, there is a push button with a pictogram of the rotating brush next to the power switch. If its depressed, brushes won't rotate
Posted on Jan 01, 2017
    Top Expert:
  • Dyson Master
  • 79,077 Answers
The motor must defective.
Posted on Dec 04, 2016
Roller bar will not spin on dc25 animal
If the brush bar motor is running try putting on a new belt. If the motor is not running it may be the main switch, the switch that activates when you recline the handle, the motor itself or a loose wire or connector somewhere. Check the connection between the vacuum and the power head. If power isn't transferred properly the motor will not run.
You have to closely check all these areas to find the problem.
Mar 05, 2017 | Dyson DC25 Animal Bagless Upright Vacuum
Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
I can think of three things that could be wrong.
The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
The internal drive belt is worn, or the nylon bush that it runs on.
The clutch is worn out.
The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    Why won't the brush head on my DC25 turn?
    If the brush bar motor isn't turning it could be the switch or the motor, if it is turning you may need. To replace the belt
    Aug 02, 2014 | Dyson DC25 Animal Upright Ball Bagless...
    How do I reset my dyson dc25
    You may need a new belt if the brush bar motor is working properly. It could be the switch or brush bar motor if the motor does not run .
    Jul 06, 2014 | Dyson DC25 All Floors Bagless Upright...
    Can't activate front brush
    Hi Sandy, it's Jack at Dyson.
    DC25 has a belt engineered to last the lifetime of the machine. It's protected by a sensor which shuts off the brush bar if something jams it. If your brush bar won't rotate it's likely it just need to be reset. Please follow the steps shown in the video I've attached.
    Tip: Once you've checked the cleaner head for obstructions and removed any threads or hair from the brush bar, recline the machine into the vacuuming position. Turn it on with the red on/off switch, then press the silver brush control switch twice.
    Please note: The brush bar will never rotate when the machine's standing upright, so make sure you recline it down into the normal vacuuming position before testing it.
    I'm confident this will resolve the issue, but if you would like further advice after you've tried this, please get in touch with us directly. You can reach our genuine Dyson experts by calling 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
    Best wishes,
    Jack
    Dyson Online Customer Support
    www.dyson.com
    Aug 19, 2013 | Dyson DC25 Vacuum
    Dyson dc25 off button won't turn off, brush button won't engage brushes
    Hi ... did u get this fixed cos mine is the same hve to switch off on the wall?
    Sep 22, 2012 | Dyson DC25 All Floors Bagless Upright...
    Dyson DC25 rotating brush doesnt work
    There is a reset button on the side of the brush bar head. Press it.
    Jul 11, 2010 | Dyson DC25 All Floors Bagless Upright...
    Dyson DC25 Vacuum Logo
    801 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
