Question about Singer Sewing Machines
Machine hand wheel will not move. - Singer Sewing Machines
  • Singer Master
  • 11,769 Answers
Depends on the make & model of your machine. If it's an older mechanical, it could have seized due to lack of oil.
Wheel on right side that controls the needle up and down is very tight...
Posted on Dec 03, 2016
    Top Expert:
  • Singer Master
  • 8,213 Answers
Http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Troubleshooting.htm .most of the time it is caused by a small piece of thread being caught in the hook area. Try this...grip your handwheel in your left hand and the small wheel in the center of the handwheel in your right hand and turn the handwheel sharply away from you. This will usually pop out the offending piece of thread and free your machine. Be sure to oil your machine well before you start to sew. Best of luck..
when mine sticks it's always the thread underneath the fabric that gets tangled. try taking out the bobbin and making sure no parts underneath are loose. i would google this and type in your sewing machine brand. there are more specific instructions this way.
It can do this if your bobbin is tangled. Check to see if any thread is caught. take the bobbin and the bobbin case out and clean it from threads and dust.
I had the same problem, eventually realized I never slid the bobin stopper back to original position (to the left) after filling up my bobin with new thread...
This is all i could find on the internet hope some of this helps you out.
    Top Expert:
  • Singer Master
  • 50,335 Answers
Sounds like it jumped time . take it to a repair shop .
Hand wheel moving needle moving but will not sew cannot release hand wheel to turn in opposite direction
Do NOT turn the handwheel the reverse direction.
If your machine is mechanical, most likely it hasn't been cleaned and oiled for a long time. Old sewing machine dries out and turns to glue which then prevents parts from moving like they should.
This web site may be helpful:
How to Oil Vintage Sewing Machine
Tri-Flow Synthetic Lube is very good because it has little teflon beads. It also does not dry out like sewing machine oil will. Then applying heated air from a handheld hairdryer will help loosen it.
Do NOT oil plastic/nylon, cams, or belts.
Aug 20, 2016 | Sewing Machines
Why is the wheel on the right hand side of my machine very stiff when turning
the "hand wheel" on a sewing machine is meant to only advance the mechanism far enough to thread and set the needle , the motor should be used to run the machine else wise , as its turning every thing inside the machine to keep all the functions in "TimE" as models increase in there complexity there hand wheels are harder to move as more stuff needs to be kept in "time" now , also on some models the bobbin winder is directly powered by the hand wheel , if its not in use it should be disengaged completely
Mar 02, 2016 | Sewing Machines
Hand wheel won't move.Scissorbutton wont work.
Repairing a Janome or New Home Sewing Machine ...
www.thriftyfun.com/Repairing-a-Janome-or-New-Home-Sewing-Machin...
Question: Memory Craft Machine Won't Run ... I'm a computer repair technician and good with tools, is this something I could fix or should we .... machine which will zig zag fine if i turn the wheel by hand or sew very slowly; as soon as I speed ...
Janome won t turn Sewing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > won t turn > Sewing Machines
Janome sewing machines won t turn related questions and answers. ... Ad. Question about Memorycraft 6500P Computerized Sewing Machine ... it could be a part has worn or broken, esecially when the hand wheel won't turn,, it needs to be.
Janome wheel not turning Sewing Machines Questions ...
www.fixya.com > Forum > Tags > wheel not turning > Sewing Machines
Janome sewing machines wheel not turning related questions and answers. ... 10000 janome jamming fly wheel won't turn fly wheel won't turn warning for too thick ...the hand wheel is not moving the needle at all Hi I was unable to move the needle at all ... Janome Memory Craft 9000 Computerized Sewing Machine.
Jan 25, 2016 | Janome Memorycraft 6500P Computerized...
In sewing mode the motor turns but needle does not move. I have checked bobbin & upper thread - any help?
1. Try to turn the hand wheel. Does the needle move?
2. Make sure the center wheel on the hand crank is tight.
Try the hand wheel now. If you still don't have luck try this.
3. Loosen the center wheel on the hand wheel. There is a small screw on the center wheel on the front or side. Loosen it until it almost comes out.
4. Now tighten the center wheel. (clockwise) Does the needle move if you move the hand wheel? If it does you can tighten the small screw.
5. If this doesn't do the job you will have to take the cover to the motor off. The motor has a bolt to loosen. As you loosen the bolt you can move the motor until it tightens the belt and makes it aligned as well. Run the motor slowly with the foot pedal and adjust the motor until it operates at it's highest speed. Now tighten. Replace all covers.
6. The belt is sometimes in need of replacing but not usual. You will know when you take the panel off.
Apr 16, 2015 | Sewing Machines
Why won't my old manual singer sewing machine needle move?
1. Disengage the bobbin winder.That is done by moving the arm away from the center wheel. 2. Tighten the hand wheel. When you tighten you should have resistance like a jar has. If this doesn't then continue. 3. Loosen the small screw attached to the hand wheel center lug. Now, move the hand wheel into a position where it will tighten. 4. Go ahead and tighten the small screw. Now, it should move.
Nov 19, 2014 | Singer Sewing Machines
Hand wheel not moving
sounds as though the hand wheel at the right end of the machine needs tightening by hand to engage inner workings. Hold the larger wheel with one hand tighten the smaller wheel.
Dec 07, 2013 | Janome Memory Craft 3000
Hand wheel will not move easily
it sounds like the machine is ready to be serviced, the machine
could have a broken or loose part.
Dec 22, 2012 | Sewing Machines
The hand wheel just stays put while the inside of the machine seems to be moving, like something is slipping.
Move the bobbin winder to LEFT. Sounds to me like you didn't re-set after winding a bobbin.
Hope this helps!
Jimmy
Apr 06, 2012 | Singer Inspiration 4210 Mechanical Sewing...
Im trying to sell a Kenmore 117 - 959 but I can't get it to move. There is power to the work light, but Im stuck. Help!
If your gaskets are bad, the machine will not rotate. Can you move it by hand? If not then have you checked the gasket in the back of machine that comes in contact with the hand wheel? If it is making contact, this is what runs the machine and both the little black gasket and the hand wheel will spin when you rotate by hand. If the hand wheel is free spinning then it may need oiled. If you have a manual, try oiling the complete machine according to manual.
Jul 10, 2009 | Kenmore 11101 Mechanical Sewing Machine
My needle keeps moving while I try to wind my bobbin
hi there,
the hand wheel and clutch should be disengage so that needle will not move also w/ the bobbins,doing this is hold the hand wheel then grip hold also at the center hand wheel.rotate center counter clockwise to release clutch.other type is push and pull hand wheel.any of them,try to run machine if needle is move again.cheers have a nice day don't forget to rate me.
Apr 07, 2009 | Singer 7436 - INGENUITY
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
