I am looking for a thermostat control switch for a space heater Model #927/C
A dial type rotery heat control thermostat switch
  • 15 Answers
SOURCE: electric space heater contactor won't stay latched
Jumpered the bimetal thermostat and everything worked smoothly. Tried to clean contacts in thermostat with no luck, so ordered a replacement. At least it was cheaper than the contactor.
Posted on Dec 12, 2008
EsWorld
  • 1618 Answers
SOURCE: bunn cwtf15, water does not heat, ready light on all the time
There is an inline thermal fuse on the right side of the element, check to see, if it has resistance, if not replace.
Posted on Apr 01, 2009
  • 34 Answers
SOURCE: Need a thermostat for a space heater
visit this page for Lakewood parts and service center info:
http://www.lakewoodeng.com/html/parts.html
Posted on Apr 18, 2009
SOURCE: Lancer 2002, change heater control switch
contrary to what the dealership tells you you don't have to take out the entire dash to fix the heater switch, all you have to do is first locate a heater switch which I thought was imposible to find too, but I found one online for 165 bucks from a used autoparts store, then all you do is take off the molding that surrounds your stereo, then take out your stereo, then you will see a blue cable on the right side and a black one on the left carefully disconnect those and the two wireing harnesses in the back the upper one is white the lower is black, then pull the unit out and put the other back in the same way, now it's still going to stick cause of those moron engineers so if you kneel on the ground and look next to your gas pedal you will see to pieces of white plastic that is why you can't switch to heat that flimsy cabel has to push that gear forward, that gear is sticky so it won't go forward, there is a replacement gear to fix that problem that should be about 18.00 from the dealership. it took me about an hour or less to do the whole operation. I just literally finished it 20 minutes ago in my wifes lancer which i broke that knob off of. Good luck if you havent figured it out yet.
Allen
Posted on Apr 22, 2009
  • 3 Answers
SOURCE: Lakewood space heater thermostat source
If it is a Ksd31 thermostat you need, you are in luck. I found what I needed for my model 5600/7 on ebay. The store Larksining sells the for as few as five/pkg in various temp. settings. I got 5 ea. in two temp settings for less than $11.00 USD with shipping from Hong Kong.
Posted on Jan 26, 2010
Space heater stops working after 2-3 minutes
The problem is most likely the over heating sensor thermostat located directly under the heating elements - The reason the over-heat safety thermostat sensor is tripping the warning buzzer is because either the cool air fan intake is obstructed with dust / dirt, or the fan motor stopped rotating, or the over-heating condition thermostat is defective, or over sensitive - Usually when the cool air intake is obstructed for any reason, the heating elements will glow brighter, and hotter without good air flow, and the elements may start to bow downwards closer to the over-heating safety thermostat - However, if the safety thermostat is defective, it can trigger the warning buzzer even though there may not be an over-heating condition / event present - The buzzer warning going off prematurely also occurred with my Holmes space heater - I checked the air flow first, and then the appliance tip-over switch second - Both were found functioning properly - It wasn't until I replaced the safety over-heating thermostat, did the buzzer stop going off moments after I plugged the space heater in an outlet.
Jan 05, 2014 | Holmes Products HRH316 Mid-Size Heater
Tip
DeLonghi Space Heater does not Heat
<p><b>Space heaters</b> are becoming more common as people are trying to get their<b> energy costs</b> under control. To try and s<b>ave money on heating</b>, many people are <b>turning down the heat</b> for their <b>central heating systems</b> and then heating just the area that they are in with a <b>small electric space heater</b>.<br /> <p><br /> <br /> <p>While these<b> electric space heaters</b> are relatively inexpensive, there are many people who want to repair their space heater if it stops heating. <br /> <p><br /> <br /> <p>If you have an <b>oil filled type space heater</b> and it is leaking or you are thinking of refilling it then check out this tip.<br /> <p><br /> <br /> <p><a href="/../support/r7770415-oil_filled_radiator_heater_leaking">Oil Filled Radiator Heater Leaking</a><br /> <p><br /> <br /> <p>If you have an <b>electric hot air space heater</b>, and it is not working, then there are only a few things that can go wrong. The only parts that can fail are the <b>switch(s) for the heating</b>, the <b>thermostat</b>, and the <b>heating element</b>. Of these parts, the <b>switches</b>, and the<b> thermostats</b> are replaceable, but the <b>heating elements </b>usually are not. Finding the<b> replacement parts</b> can also be difficult. Here is one website that carries many of the parts for these heaters.<br /> <p><br /> <br /> <p><a href="http://www.ereplacementparts.com/">Click Here</a> <br /> <p><br /> <br /> <p>To find out which part exactly is the part causing your problem, you will need to follow the power through the switch(s) and the thermostat to the heating element(s) and find out where and if the power is being interrupted before getting to the heating element. If the element is getting power then everything else is working and the element is bad. If there is no power there then go backwards till you find power and replace that part.<br /> <p><br /> <br /> <p>Always remember to mark any wires that you remove very well before removing them. There are many people looking for<b> wiring diagrams</b> because they have not remembered where they removed the wires from.<br /> <p><br /> <br /> <p>Also make sure to remove power, (unplug the cord) before removing any electrical components from the heater. Also when checking for power with the power on, you must be very careful to avoid a shocking experience that could result in death. Make sure all parts are away from metal parts of the heaters also to avoid shorting the part to the heater and blowing a breaker or ruining the heater.<br /> <p><br /> <br /> <p>In many cases, the time, energy and the <b>cost of parts</b> and shipping are not worth the <b>cost of the heater</b> that you are trying to fix. Make sure to check all of that out before trying to make repairs.<br />
on Jan 15, 2011 | Heating & Cooling
Honeywell thermostat will not work when put on automatic
Depends on what type of heat you have...if it is electric, it could be your thermostat (some electric heaters use contactors & rely on the thermostat to switch the fan on). Heat pumps also use the thermostat to switch the fan on in heat & cool mode. Most electric furnaces use a sequencer to switch the low speed of the fan whenever there is a call for heat. Gas furnaces use either a fan/limit controller (if the unit is older) OR a circuit board based on time (after the thermostat calls for heat). SO depending on the type of system you have, it could be a bad sequencer, controller, relay, thermostat, or control board. Hope that helps.
Dec 17, 2013 | Heating & Cooling
I don't understand what the controls do pelonis oil filled radiator
I would try the thermostat one by turning it up to a higher heat. I feel the other one may heat on high but would not shut off. You would have to do it manually.
Sep 23, 2017 | Pelonis WM-HO202C Oil Filled Radiator...
I need a thermostat control for a Lakewood oil filled heater model 5101
Check out this tip that I wrote about space heater problems..
heatman101
Feb 13, 2011 | Lakewood 5101 Oil Filled Radiator Heater
How do I Turn the heat on ?
It's hard to answer that question because there are so many variables. First I would look at the thermostat and see what manual settings are available. If it's a non programable there should be a switch that goes from heat to cool,one position for fan on , one for off, and one for auto. Set the heat/cool switch to heat. the fan on ,off and auto to auto. Then turn thermostat control up so it's above surrounding temperature.This should cause the heater to come on. If that doesn't work you may have problems with heater or thermostat. If it a programable t-stat I will need more information,such as name brand,model,etc. Hope this helps. Thanks.
Nov 05, 2010 | Heating & Cooling
I have ran my 12-2 wire from breaker box to thermostat from the thermastat i ran a 12-2 wire to first heat. question 1) do i run another 12-2 wire from heat 1 to the next heater i want on this thermostat?...
There are so many questions. WHAT IS THE MODEL number of the unit that you are wiring The thermostat and the source voltage are two different things. What voltage are you wiring this to?
Apr 30, 2017 | Marley Electric Hydronic Baseboard Heater,...
Feb 22, 2009 | Heating & Cooling
Heater will not stay lit on auto procom ml 300 blue flame
If you have an ML300HGA, it is a manual-control heater, which means you turn it on and you turn it off. No thermostat. It does not have an AUTO setting.
Likewise, the thermostat-controlled models do not have a Manual mode. If you have the ML300TBA, it has a thermostat and will turn itself on/off in order to maintain a room temperature.
On manual models, the numbers (if any) on the dial are heat output selections. Set the control to the highest heat setting and that's what it does until you turn it off.
On automatic thermostat models, the numbers on the dial are temperature selections. Set the control to the highest heat setting and the heater will continue running until it is 85-90 degrees, then shut off. Set it around 2 and it will maintain a temp of around 70 degrees.
All Procom heaters are either automatic (thermostat-controlled) or Manual. None are both.
Oct 05, 2008 | Procom ML300HGA Heater
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
