Question about Miscellaneous
ORD 115-0243519-2759450 - STATUS? WHERE IS IT?
PLACED AT 10.45 AM, SAID I"LL RECEVE IN 5 MIN. SIX HOURS PASSED, I GOT NOTHING. ?????
    Top Expert:
  • Miscellaneous Master
  • 8,204 Answers
Fixya has nothing to do with what you are asking
Posted on Dec 03, 2016
When it is six-thirty, how many minutes must pass
One minute. The minute hand makes one revolution of the clock or watch dial every minute or 60 seconds. When it is 6:30 exactly, one minute later, the minute hand will pass by the six again.
Aug 28, 2014 | Watches
How can I connect games to request facebook friends to join?
Phone Number:
1-650-543-4800
Average Wait: 12 mins
24 hours, 7 days
May 09, 2014 | Facebook Computers & Internet
I need diagram of firring orde for dodge dakota 3.9 six cilynders
3.9L V6 engine firing order is 1-6-5-4-3-2, cylinders on the pass side front to back are 2-4-6, cylinders on the driver side front to back are 1-3-5.
May 14, 2012 | 1993 Dodge Dakota
I need A new battery for my 2005 ford freestyl what kind should i get
Depending on your location, most Advance Auto, Autozone, O'Reilly's type places will install the battery for you and have a backup battery to plug into your OBDII Connector to save your settings. Either way, you'll probably need a wire brush to scrape off the corrosion on the battery leads.
There is nothing unique about Ford batteries. Any battery of the same physical size and electrical capacity. Personally I will use the Optima when I need a replacement (it is the one that looks like a six pack with cylindrical cells.) With the technician personal on Autoshop or Dealer, keep in mind that:
(1) They do a full check of the charging system before removing the old battery to verify the electrical system.
(2) They check the full system with the new battery
(3) They keep power on the system so you do not loose all radio, alarm and other codes.
(4) Most have a 5 year warranty.
(5) You can get it replaced many more places than there are Ford dealers.
(6) You can generally watch what they are doing.
(7) You can be in and out in an hour or less.
(8) It is no hassle if it is a warranty claim
(9) Instillation is included in the price
Additionally, you ca read this article: auto/maintenance/battery_cleaning.
Hope this helps (remember to rating this free answer and leave a testimonial comment).
Oct 11, 2011 | 2005 Ford Freestyle
I downloaded some design off of the internet on to my computer and then onto my pc card. Computer says they are on the card but when I put in machine the designs are not there.
There are several possible answers. On the pc card, you must have a folder called EmbF5. The sewing machine will put two directories onto you pc card when it formats it--Ord#5 and EmbF5. The embroidery designs are stored in EmbF5 and series of sewing stiches that you want to save are stored on Ord#5.
I have had the same problem. I have two pc cards which I formatted on the computer and placed the two file folders EmbF5 and Ord#5 on the disks myself. I cannot get the machine to read these. I suspect that the machine wants to format them itself; however, the literature on the subject suggests that you can format the cards on your computer. (You must use the FAT option.) Also, I cannot get the machine to reformat them, so maybe they are defective.
If you get a new disk, put it into your machine. It will format it for you and place those two folders on it. If it does not format it, go to the set option on the menu, go to the third 'page' and you will find the format ATA card.
Also, be sure that your card is 512 MB or smaller.
Feb 01, 2011 | Janome Memorycraft 9700 Computerized...
Oil leaks down the frame rail and onto the jack plate. I have looked under the car and there is no definite place that the oil is coming from.
Sorry hate to sound almighty but without having vehicle in front of me and giving it a good steam clean then running it to look for leaks i can only give you the normal places for oil leaks and thats the rear end oil seal,front end oil seal ,or the head gasket on a corner where the oil feed passes through the head gasket to lubricate the valve gear ,on a lot of vehicles its on a corner of the block and they do go fairly often especially citreons and peugeots .Best advice is ask neighbours and friends if they have a mechanic in the family and then ask them to have a quick look ,that way you may get a truthful answer so at least you know what to expect if you take it to a garage ,as a rear end oil seal involves a lot of work removing the gearbox to change a seal that take 5 mins to change and 3 hours to get at it.front end oil seal is about 2 hrs work after removing the timing belt ,again 5 mins to change seal and a good hour or so to get at it .
Jun 27, 2010 | 2003 Subaru Legacy
In receving folder there is nothing in the folder and sixe appear 4.8 MB
There may be any hidden files in it...or to get maximum utilization of space please try after formatting the memory card or phone memory..
Oct 23, 2009 | Nokia 6270 Cellular Phone
It beeps about six times every four hours,why?
Hi, press the "status" button for details on your problem. If it does not tell you press twice. do not remove this system till you talk to alarm company, if you have one, to place system on test. So police dont show up. Also you want to know if you are still under contract with them.
Jul 04, 2009 | GE Security Simon 3 Wireless Home Security...
Miscellaneous Logo
16 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
