Question about Pentair Pool & Spa
Clearing memory on Pentair vs pool pump - Pentair Pool & Spa
    Diehard:
    Visited the website for 60 consecutive days.
  • 121 Answers
To reset the pump;
You will need to hold down all four speed buttons for a few seconds, then release them, then push select twice, you will see "0" highlighted, push the arrow up button to "1" then press enter, then shut the power down to the pump for about one minute, then power it back up and your pump should be back to factory settings.
Posted on May 14, 2017
  • 61 Answers
SOURCE: my pentair controller will not shut the filter pump off
Chances are that you have a bad relay, but the problem could be the main logic board. If there is a spare relay in the box switch all the wires from the pump relay onto the spare. Remember to shut off the breaker, and also you will need to change the wires on the top of the relay too, or you will have to do some reprogramming.
Posted on Apr 05, 2009
SOURCE: pentair whisperflo pool pump motor replacement
No there is a cover on the other side of the motor thet comes off and with a 9/16 wrench holding the shaft - spin the impeller off
Posted on Jun 28, 2009
john224
  • 1378 Answers
SOURCE: I have the Pentair AT 251501 in-ground pool pump.
Yes, but not recommended. If you are going to use it on an above ground pump the system head will drop to a very low number and the pump will operate very high on its pump curve causing a couple of potential problems.
First, your filter will have to be rated for the high flow. I do not have Aqua Tools curves or numbers to give you an exact figure but if you have your horsepower you can look it up on the web. Your filter needs to be rated that high or you will have problems; even a filter failure.
Your pump will exceed the hose flow ratings and may require PVC plumbing to operate.
You should consider plumbing in a throttling valve on the pump discharge to help moderate these problems.
Posted on Dec 14, 2009
thepool
  • 78 Answers
SOURCE: pentair intelliflo variable speed pumps
Extensive information available is available from Pentair. Owners manual http://www.pentairpool.com/pdfs/IntelliFlo4x160and4x100OM.pdf Quick start guide http://www.pentairpool.com/pdfs/intelliflovsQSG.pdf
Posted on Apr 21, 2010
StepehnD
  • 78 Answers
SOURCE: wirng connecions for 110v pentair pool motor???
Next, as a suggestion. Purchase an Emerson Pool motor. The electrical connection is the same for 110/220 volts. All you have to do is move the switch by the electrical connections and select 110 or 220 volts. They usually come preset on 220 but I would check anyway. Also, don't forget the ground wire (green) and also connecting the bonding wire on the outside of the motor near the plastic cover for wiring. If you don't have bonding I would get it real soon! Hope this helps..
Posted on Jun 06, 2010
How to reset Pentair vs pump
open cover on motor reset button
Sep 05, 2017 | Pentair Pool & Spa
Pentair Intelliflo vs. Need bearing replacement for front and back bearings
Pentair WhisperFlo Pool Pump Motor Bearings Replaced ...
? 2:03
www.youtube.com/watch?v=qYRNMCh_7kM
Jul 10, 2012 - Uploaded by Pump Repair Supply
More Help & Information: https://pumprepairsupply.com Watch as Joseph shows you how quite your Pentair
Sep 27, 2015 | Pool & Spa
Pentair intelli flo vs+Svrs no display
see if voltage to switch and relay and to pump if voltage at pump bad controls or transformer
Jan 06, 2014 | Pentair IntelliFlo VS-3050 & VS+SVRS...
How to backwash a pool with a pentair intelliflo vs + svrs pump and pentair cartridge filter
if you want to backwash put in service mode after then put back online you cannot backwash a cartridge filter
Sep 02, 2013 | Pentair Pool & Spa
Pentair VS pool pump
what do you have speeds set at maybe too slow to keep prime
Apr 19, 2013 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Pentair vs pump has power but will not run and LEDs do not light up
How did you test for power? Is it proper amount of power?
Did you use a multimeter to test for proper supply power/voltage?
Jan 15, 2013 | Pentair Intelliflo 4x160 Pool Vs-3050 Pump...
Pentair IntelliFlo VS-3050 & VS+SVRS Variable Speed Pump -leaks from housing
Which part of the housing?
The back against the motor or against the strainer basket housing?
Parts break down for the Pentair IntelliFlo VS-3050 here.
If leak is on the back of the housing - shaft seal. Or if the leak is on the front the replace O-Rings #10 or #23 in diagram.
Sep 13, 2012 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Pool & Spa Logo
101 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
