Question about Refrigerators
How do you reverse door handles on Model 596.70002002
Have already reversed hinges but handles are a one piece curved metal, no screws. Owner's manual says call repair man. Don't want to spend $100.00 to change door handles
  • Anonymous Dec 04, 2016
    Why? What is involved?
    Top Expert:
  • Refrigerators Master
  • 78,010 Answers
You are going to need a tech to do this.
Posted on Dec 04, 2016
The doors open in the wrong direction
remove top screw for freezer door remove door then remove next hinge then remove fridge door reverse hinges when putting back on reverse handles to other side
Mar 01, 2014 | Thetford NORCOLD N641R - Norcold Finished...
I have whirlpool A CLASS fridge how do i reverse the door
  • I cannot confirm weather your fridge had reversible doors as you listed no model but the standard for fridges that can reverse the door swing are changed by doing this -
  1. You will see little plastic covers on the opposite side where the hinges and handles are currently located now.
  2. There are some little clips that hinge the screws on the top and bottom of each handle.
  3. Remove these little covers with a small flathead screwdriver.
  4. Now remove the screws holding the freezer and refrigerator handles on.
  5. Now pop the screw hole covers on the side of the frig/freezer you will using.
  6. Now place and fasten with screws the handles on the other side of the frig/freezer door.
  7. Now remove the top freezer hinge first by removing the 3 screws on top.
  8. Now pull up on the hinge (save the spacer).
  9. Now pull up on the freezer door.
  10. Now remove the screws on the middle hinge.
  11. Now pull up and remove the middle hinge while holding the frig door steady (save the spacer).
  12. Now pull up on the frig door and set to the side.
  13. Now remove the screws on the bottom hinge (save the spacer).
  14. Now put the screw hole covers you removed from the other side in the screw hole exposed from the screws you just removed.
  • The switch
  1. Start with the bottom hinge and place it on the opposite side (don't forget the spacer).
  2. Place the frig door on the bottom hinge and the place the middle hinge in the hole at the top of the frig door.
  3. Fasten the middle hinge.
  4. Place freezer door on the middle hinge.
  5. Put the freezer door in it's natural position to make putting the top hinge on possible.
  6. Screw the top hinge in.
  7. Job complete.
Regards, Tony
Apr 30, 2011 | Whirlpool Refrigerators
How do you replace drives side exeior door handel for 95geoprizm
1) Remove the plug inside the interior armrest and remove phillips screw.
2) Remove armrest and two screws that hold door panel to door frame.
3) Pop the outer cover off the interior door handle.
4) Remove the interior lock knob and remove door panel by popping out tabs connected to door frame and lifting up off of window ledge.
5) Remove the two nuts holding exterior handle in place.
6) Disconnect the L shaped linkage from the handle. The trick to getting the L shaped linkage into the new handle is to feed L shaped metal pole through hole in door where exterior handle was, leaving the lower end of this linkage in its slot.
7) Feed the end of L shaped pole through the plastic 'hinge' in new handle by folding the hinge over and pushing the end of the L through both sides of the plastic hinge at once. slide the lower loop of the plastic hinge down the L shaped pole to secure pole to handle.
8) Place new handle into door and reverse the process to reinstall interior panel.
Hope this helps Tim
Apr 17, 2011 | 1995 Geo Prizm
if you open the door and look to the opposite side you will see to white pieces, take the screws out and they will come out, do the same with the hinges and once the screws are off the hinges lift the door open and out, switch the hinges and the white pieces. Door is now reversed. Good Luck Tim
Jan 16, 2011 | Maytag Neptune MDG9700A Gas Dryer
Can't find any instructions - can I reverse the door from the left side to the right side?
Hi and welcome to FixYa. I am Kelly. The answer is YES you can reverse the door.
Here is the text of how to reverse the door:
The door assembly is reversible. It contains an inertial vibration damper comprised of a steel plate suspended with springs. The
damper is designed to tune out excessive vibrations generated by the machine during the spin cycle. Replacement inner door liners are
shipped with the vibration damper in place.
1. Open the door and remove the center screw of each hinge secured to the inner flange of the front panel in the door opening.
2. Grasp the door with both hands and lift the hinge area slightly. Draw the door assembly away from the machine. This will disengage the hinges from the slots in the
front shroud (Figure 5-1). If the hinges bind, press out on the plastic shroud near the hinge toward the cabinet.
Figure 5-1
1. Repeat the above steps and, remove the corresponding sheet metal spacers on the opposite side.
2. Remove the hinges from the door and relocate them to the other side of the door.
3. Remount the door into the new slots and secure with one screw into each hinge.
4. Mount the sheet metal spacers onto the side where the hinges were previously to cover the hinge slots in the front shroud.
That is the text without the whole service manual pictures.
Thanks for using FixYa.
May 21, 2010 | Maytag MAH6700AWW Neptune Front-Load...
We want to switch the door so it opens on the other side? Model # 596.72212200
Ii can not locate specific instructions or a manual for the model number you gave. Here is a general description of how to change the doors: If the doors can be reversed there should be mounting holes at the top and bottom of the doors opposite where the hinges are now. (They may be closed with plastic plugs that can be pried out.) Check also how the existing handles are mounted. There should be holes that correspond to having the handles on the opposite side. (Sometimes they are disguised by a manufacturer's nameplate over them.) If there are such holes then start at the top hinge of the door. Pry the (plastic) cover off if there is one. Remove the bolts/screws and remove the hinge support. There is a post on it that fits into the hole at the top of the door. Remove the door by lifting it up off the bottom hinge post. Keep track of any washers, etc. that may be there. Unscrew the bottom hinge support. Remove (and save) any plastic plugs and install the hinge supports and doors in reverse order (bottom to top) on the other side. If there are separate door stops on the bottoms of the doors near the hinges that keep the doors from swinging all the way open, make sure you move them also to the other side. Relocate the handles. Put the plastic plugs, nameplate, etc. in the old holes.
Nov 25, 2009 | Office Equipment & Supplies
Need help replacing handle on whirlpool microwave model MH1150XM
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2009 | Whirlpool MH1150XM Convection/Microwave...
How do i change which side the door opens
I have a different Bosch but changing the door over is straightforward.
1. Remove the plastic cover above the top door which fits over the controls. There are 2 screws under it holding it on. Lever it up from the back on top and it pops off.
2. Remove the hinge for the top door held on by 2 bolts
3. Take the top door off
4. Remove the central hinge between the doors held on by 2 screws
4. Lift the bottom door off
5. Pull off the bottm plastic cover
6. Move the post in the bottom hinge to the other side. It screws out
7 Replace the bottom door
8 Replace the central hinge on the other side (Take off any plastic caps covering the holes)
9. Unscrew the post on the top hinge (there are 2 possible holes left and right) and put it in the other hole.
10. Put the top door on
11. Bolt the top hinge back on the other side
12 Replace top cover and screws.
13 Move handles (unscrew and pull towards the door edge to get them off)
Jul 10, 2009 | Bosch Classixx KSR32623 Refrigerator
Microwave handle replacement
How to replace handle on GE Advantium SCA1001DSS.
Jul 29, 2008 | Microwave Ovens
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
